Question about T-Mobile Sidekick ID Cellular Phone
Battery I just bought my sidekick off a store and it doesnt turn on like i charged it for more that 6 hours already and it still doesnt turn on but the orange light on the side turns on as if it was charging and i have placed the battery correctly and tightly.....what should i do?
    President:
  • 625 Answers
Nomad182-
So did you buy it new? If so take it back. If not, then you got a used one that has a bad charginfgport. The sidekick 3 is notorioius for it and the sidekick ID has an issue with it as well. The orange light comes on but the connection that charges the battery itself is broken. Check out www.cellulardr.com. They charge about 75 dollars for the repair or you can do a workaround that charges the battery seperate form the phone.
The following link shows it for the sidekick 3 but the sidekick 3 and sidekick ID batteries are the same.
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
I would also recommend a second battey so you can have one charging at all times. They runa bout 5 dollars on ebay.
Posted on Nov 20, 2008
My sidekick 3 won't turn on and i just got it today
Oooh, bad news. You probably got a sidekick 3 that had a bad charging port. Return for a refund if you can.
the Sidekick 3 has a charging issue thatcrops up after awhile. It will just not charge the battery.A good way to tell is if the orange light comes on but the phone never charges.
You can get an external battery charger for the sidekick for about 25 dollars that will allow you to charge the sidekick 3 battery separate.
Check out the following link to see what I am talking about.
Sidekick 3 external battery charging cradle
Jul 13, 2009 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3 will not turn on
Your sidekick 3 will NOT charge anymore .
even if the orange light is on & it says charging
it WILL NOT charge . Try using an old sidekick
&just charge the battery on it & then when its
done charging switch the battery back to the other
sk3 .
Feb 28, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 Charging Question
I can tell you the sidekick 3 will not operate properly with out a back cover. In fact, if you remove the rear cover while powered on, it will post a warning message on the screen.
Because you tested and successfully operated the phone with out complication with a back installed I fell confident you should have have any problem with the phone when your back cover arrives.
Good Luck
sponsored by Cell Phone Technicians
Dec 20, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My side-kick LX will not turn on
Try this, though is used for when the device is randomly rebooting aswell, it might help you to force your Sidekick to come back on:
  1. Check the device's battery level for at least two bars of strength.
  2. If the battery level is low, charge the battery.
  3. If the issue is not resolved, remove the back cover.
  4. Remove the battery.
  5. Wait 10 seconds.
  6. Press and hold the W key.
  7. While pressing down the W key, re-insert the battery.
    • The device restarts and after approximately 15 seconds, the 'Recovery' screen appears.
  8. Select the desired language.
  9. Select Reboot to restart the device.
  10. Your Sidekick should go back to the main screen as normal. Good luck
Dec 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekcik Lx will not charge.
Try a new battery for it.
Sep 09, 2008 | T-Mobile Sidekick
alright..my sidekick does he same thing but i fund a temp fix....the guy at the store says its the charging port..idk.....first plug it in....let it charge 4 ten min....then try to put in on...it will say the low battery sign...dont worry...then t8 sumting pointy and push it in the little reset hole behind the screen as you swivel it...as soon as you see the little box with the circles in it you press and hold the space button... hopeully it will start by showing the four butttons....if it does start and cuts off at the tmoblie sign jus let it charge longer and do it agian....hopefully it will work on yours it worked on mine....gud luk
Jul 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 battery problems :(
what you do is get a new battery and if that does not help the situation then take the phone into a service center to have it check.
Jun 17, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3
Maybe it's battery. Try to use another maybe helps.
If not it's problem with software in it, what is connected with power point-battery and its showing low battery and switching off.
Second what you can do is to clean connection inside maybe it's stuck something and not giving the power in.
Jun 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick id
Try a master reset.
1. Remove the battery and the SIM card from the device.
2. Flip the sidekick open; press and hold the letter 'r' on the keypad.
3. While holding the letter 'r', place the battery back in the device. DO NOT INSERT THE SIM CARD YET.
4. The sidekick will restart itself twice. Please make sure not to let the letter 'r' go until it has fully rebooted.
5. Once it has fully rebooted, remove the battery, re-insert the SIM card and battery and power up the device.
6. Once the device has fully rebooted, all prior information should be erased from the device and it should be restored back to the default factoy settings.
Dec 22, 2007 | T-Mobile Sidekick ID Cellular Phone
My problem is with the sidekick III, it wont charge, What should I Do?
dnt drain the batteries of your phones...if that happens pls buy multicharger or battery shock,remove the battery..... charge it for about 5min or shock the battery if ur using battery shock...be sure u positioned it ryt....den put it back on ur phone then charge it or continue the charging on the multicharger until its full !!!!im pretty sure of it....im encountering the same prob as urs before and thats what i did and it work!!!!
Jun 09, 2007 | T-Mobile Sidekick II
T-Mobile Sidekick ID Cellular Phone Logo
167 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
