Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
NO ICE - IC6
I have an Amana B2QORBL. It has the IC6 Ice Maker. I recently purchased the refrigerator from someone I know. The ice maker was never connected to a water line. I connected it to a water line several hours ago. So far, no ice. No water is coming into the ice maker. Please help. Thanks, George
  • Anonymous Mar 31, 2014
    Just trying to find out how I can connect my water and ice maker up
    I do not have a hose for it but I do have the connections
Mine was slow-to-none in ice making for a couple of years. One day for the first time I used the built in water dispenser. The long copper line feeding water was full of air gaps. After I bled that out, it has been perfect ever since.
Posted on Sep 09, 2007
    President:
  • 878 Answers
George, the ice maker will cycle about every 2.5 hours. Sometimes it takes a couple cycles to prime the lines. You can remove the white cover of the ice maker. On the module you will see two ports, one marked L and another marked V on the left side. Take a insulated jumper wire and jump these two terminals. You are now sending 120V to the valve. See if the water starts coming in. Also make sure the bailing arm is down. Catriver...post back.
Posted on Nov 05, 2006
Ic6 ice maker
Some models like yours came with a defrost control board and others came with a defrost timer. They should be found inside the fresh food compartment and behind the temperature control panel. You will need to inspect and let me know which you have. Unplug first. If the control board looks or does not look burned it could be bad. The timer can be turned clockwise until compressor stops and should remain stopped for about 25 minutes. and then turn itself back on. If these look good then we need to remove the rear panel inside the freezer and test the defrost element with one wire disconnected to check for continuity. Just to be sure the element has not burned out. The defrost thermostat is connected to the defrost element and will have open contacts inside it above 50 degrees.
Jul 16, 2013 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice cube from icemaker have recently had a bad taste. Filter to service? Amana Mod BG20T2W Ice maker IC6
Bad taste or odor from ice cubes most likely a filter problem. If filter has not been changed for at least 6 months, that is where I would start.
Apr 01, 2010 | Refrigerators
Water leak from ice maker
The fill line internal to the freezer is likely frozen up from the elbow inward.. When the icemaker calls for fill...pressure builds up on the plastic tubing causing it to pop out of the elbow. Check the tube inside the freezer by removing icemaker and running a long thin screwdriver or a rigid wire up into the tube until you feel ice or the plastic elbow outside.
Clear ice, if present, by squeezing hot water in from freezer side with turkey baster until cleared and water comes out back.
Aug 21, 2009 | Amana Refrigerators
No water comes automatically to the ice maker
What you need is a new ice maker the front gear is not engaging the contacts, you can buy the front module only ( what u put the wire in to on the l & v contact ) but a whole new ice maker assy is the same price.
Jan 10, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ic6 ice maker
sounds like your ice maker is working properly and that maybe you pinched the water line when you reinstalled it back into the elbow.. is the elbow clear of any ice build up or foreighn matter that would restrict the flow of water into the ice mold tray? If so..that's your problem.. ( thaw it out or melt it and then you should be OK) Hope that helps..
Aug 18, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
I have a AMA IC6 ice maker and the ice is stuck together form water running over into the catch tray.i have removed the ice maker and let it thaw then reinstalled and the same thing happened. any...
Having problemAMA IC6 Icemaker. Water leaking into tray as it is making cubes causing previous cubes to freeze together and to the bottom of the container. Trying to defrost to see if that helps. Any suggestions appreciated.
Jun 09, 2008 | Amana Refrigerators
IC6 ice maker
No, completly deforst the freezer for 24hrs this will resolve the problem, i know its frost free, but still try to defrost this usaully resolves this fault Regards Advisor
Aug 21, 2007 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
508 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
