Question about Samsung Televison & Video
My son hit the tv with a ball and now there's no
  • jdwalker1961 Apr 07, 2012
    this is a samsung plasma PN51D6500DF 51'' the tv was hit with an object that put a small crack in the right bottom corner of the screen and now the TV want power on. when using the remote to power on TV you just see a flashing red light in the power source window on the front of the TV. on the back of TV towards the center of the TV there is a blinking green light with the # code 2061 under the flashing green light does this code indicate the problem or is a number they use for installing parts. is there any method i can use to get the TV to power back on or do i need to take it in for repair which can be very costly. what does that blinking green light indicate or mean? help please thanks.
  • Author Rehman
    Author Rehman Apr 08, 2012
    the circuit is fine because the green light glows. the problem is only in the bottom right corner,may be the ball hit ******* the panels.you can take it for repair and i dont think it wont be much costly.
    Master:
  • 392 Answers
Did the ball hit the screen and is there any cracks on the screen or the screen broke? what had happened.you can get the power back,it needs some repair
Posted on Apr 07, 2012
SOURCE:
SOURCE: magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Posted on Mar 27, 2009
  • 208 Answers
SOURCE: lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Posted on Feb 05, 2008
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
SOURCE: 55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Posted on Sep 28, 2009
SOURCE: LC 32D43U power and OPC green light flashing set does not come on
get the usb (flash drive) and go to sharpusa.com customer support / product downloads / software download find your model# then select firmware (last 30 days) download files, save it and transfer files to usb flash drive. Unplugg the tv and put the usb on the back the tv, plugged back in and turn it on. Should work, for sure.
Posted on Dec 05, 2009
Son hit tv with ball no sound but....picture is fine
Perhaps you check all cables and connections. And look if all switches are in the correct position. He could heave accidentally have hit the mute button, or a button to switch to other speakers.
I almost can't believe something is defect inside the TV.
Nov 15, 2014 | Sony Televison & Video
My son hit the tv and now it wont urn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 27, 2014 | Emerson LC320EM2 32" LCD HD Television
My son threw a golf ball at our Sanyo LCD - 42" -
I assume you meant the screen is now broken.
Some things to consider:
1. Replace the son with one who does not throw golf balls in the house. Ha ha! [jk]
2. Check to see if the warranty (usually online if you don't have the original paperwork) covers screen breakage, or ask the store where you bought the tv if there is anything they can do.
3. If the warranty is a no-go, contact the tv manufacturer and see why they may do... what the cost would be to repair etc. Some screens are covered in case they crack, but it is probably obvious it wasn't a manufacturer's defect if a golf ball hit it.
4. If those steps don't work out, check videos or info online to see if this is a job you or a techie could do - (in last case scenario).
5. If none of these check out, sadly, you might be left with a very large, expensive doorstop.
Good luck.
Sep 23, 2012 | Televison & Video
My son was playing the wii and his remote hit the TV. Now the tv will not power on and the power light and opc lights are flashing? Anything I can do?
You probably damaged the panel. If it's under warranty contact Sharp and request service. sharp does not replace panel under warranty . they usually replace the tv. It's worth a try.
Aug 31, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My 1 year old son hit my 42 inch with a remote control were can i buy areplacement screen for it please he;p.... my screen has a spider web looking crack that is in tha back of the scren it broke
Cost same as a new tv,to replaced the LCD screen.There are hundred or more sell for parts because Broken LCD screen sell in Ebay.com.The TVS industries well not sell out LCD Screen cheap or resonable price.
Jan 03, 2010 | LG Electronics 42 in. LCD Tv
Sony Bravia 32" KDL
Your pannel has damage by the hit, the only way is to replace the pannel. It is costly if you are in OOW. If it is still in warranty, call service right away and claim for an replacement.
Aug 18, 2009 | Sony BRAVIA KDL-40V3000 Television
Power button flashes blue continously and TV will not turn on.
The lamp is probably gone. Part # TS-CL110U. Easy to change yourself.
Apr 15, 2009 | JVC HD-56G787 Television
Open Questions:
Televison & Video Logo
135 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
