Question about Philips Magnavox 51MP392H Rear Projection Television
Magnavox 55'' Projection - Sides come in and out
When I first turn it on for about 20 minutes the sides cycle in and out, about 1 per second, about 6 inches in. Oddly, it especially happens with white or light images, but a dark image will stop it. After about 20 minutes of use, it stops. I'm guessing it is some sort of power supply regulator, or convergence issue.
    Scholar:
  • 33 Answers
Sounds like Convergence issue.... I have some pictures of the bowing picture TV on the link below...
I'll post you my general message which is for a similar Philips Magnavox 51 inch TV, you'll need to check the manual verify the correct IC convergence chips and resistors, the manual link is below as well... usally the IC's are STK392-120's or 150's and the resistors are 6.8 ohm 12 of then...
anyway read the general post below it will get you headed in the right direction.
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted
pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got my parts that worked:
Suburban Electronics
http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC
chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
Posted on Nov 20, 2008
Not Ready for Smog test
it is not how many miles but the type of driving.
here is a OBD2 drive cycle test.
Generic OBD II "Drive Cycle" Most OBD II ("On-Board Diagnostics II") diagnostic monitors will run at some time during normal operation of the vehicle.
However, to satisy all of the different Trip enable criteria and run all of the OBD II diagnostic monitors, the vehicle must be driven under a variety of conditions. The following drive cycle will (theoretically) allow all monitors to run on (??) vehicle. (Note: Drive cycle specifics vary by vehicle!)
  1. Ensure that the fuel tank is between 1/4 and 3/4 full.
  2. Start cold (below 86°F /30°C) and warm up until engine coolant temperature is at least 160° F (typically requires at least one minute; up to 3 minutes).
  3. Accelerate to 40-55 MPH at 25% throttle and maintain speed for five minutes.
  4. Decelerate without using the brake (coast down) to 20 MPH or less, then stop the vehicle. Allow the engine to idle for 10 seconds, turn the key off, and wait one minute.
  5. Restart and accelerate to 40-55 MPH at 25% throttle and maintain speed for two minutes.
  6. Decelerate with using the brake [or the clutch!] by coasting down to 20 MPH or less, then stop the vehicle. Allow the engine to idle for 10 seconds, turn the key off, and wait one minute.
Jun 04, 2010 | 2001 Kia Sephia
Magnavox tv
try degaussing the screen... if your tv doesnt have that option, here are some ways to achieve that http://www.wikihow.com/Degauss-a-Computer-Monitor
Jan 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
I have a 2001 nissan pathfinder 4w. The OBD system-readiness status: Says catalytic converters, NOT READY; oxygen sensors, NOT READY; evaporative system, NOT READY. So did not pass inspection, I was told...
You have to re-set the obd via using Nissan's approved drive-cycle which is;
1. Start the engine when the engine coolant
temperature gauge needle points to C. Allow
the engine to idle until the gauge needle
points between the C and H (normal operating
temperature).
2. Accelerate the vehicle to 55 MPH (88
km/h), then quickly release the accelerator
pedal completely and keep it released for at
least 6 seconds.
3. Quickly depress the accelerator pedal for a
moment, then drive the vehicle at a speed
of 53 to 60 MPH (86 to 96 km/h) for at least
5 minutes.
4. Stop the vehicle.
5. Accelerate the vehicle to 35 MPH (55 km/h)
and maintain the speed for 20 seconds.
6. Repeat steps 4 through 5 at least 3 times.
7. Accelerate the vehicle to 55 MPH (88 km/h)
and maintain the speed for at least 3 minutes.
8. Stop the vehicle and turn the engine off.
9. Repeat steps 1 through 8 at least one more
time.
If step 1 through 7 is interrupted, repeat the
preceding step. Any safe driving mode is acceptable
between steps. Do not stop the engine
until step 7 is completed. If you cannot or
do not want to perform the driving pattern, a
NISSAN dealer can conduct it for you.
Nov 15, 2009 | 2001 Nissan Frontier Crew Cab
Turning off by itself
This TV probably needs the convergence amp IC's replaced. When they go bad the TV will not turn on.Call a good TV Tech and tell him you want the IC's upgraded to STK 392-150 instead of the original STK 392-120 and check all resistors in the circuit for proper value. They could be burned or open.
Jul 30, 2009 | Philips Magnavox 55P9271 55" Rear...
Picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Feb 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a 10 year old phillips magnovox 55 inch tv
yes you can take off the cover but carefuly and in the back of your tv you will see the flyback and has 2 button one fro focus and other G2 then rotate the focus button till you will see no blurry
that is all if you dont know how bring some frend who can and tell him to do that
Dec 10, 2008 | Philips Magnavox 55P9271 55" Rear...
TV power problem
Does anything else work in the same outlet?
Also do you have it plugged into a power strip?
Unplug it wait about 20 - 30 seconds and plug it back in see if it resets its self
Jan 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Picture problems
Convergence IC's need replacement,moderate technical ability
needed......cost about 400.00 to repair..................T.
Nov 17, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
97 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
