Question about InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector
Lamp will not strike error message
I have confirmed the bulb is good, however unit will start and try to light the lamp. It goes through count down, gets to 4 and reads "retrying". It does this several times then show the "Lamp will not strike" message.
Fan is on, red light is flashing above power button. Same problem, Lamp Will Not Strike. The projector worked just fine 10 days ago and has not been use since.
    Genius:
  • 1,847 Answers
This sounds like ballast or ignitor fault.
Posted on Nov 11, 2008
  • Legin Varghese
    Legin Varghese Nov 11, 2008
    The control channel (channel 14) needs to be set at 99% for 3 seconds
    and then down to 0%. The transistion has to be by absolute values and
    not incremental (by fader or wheel). Similarly the douse command is 66%
    on the control channel. Certainly with avo desks, the fixture
    personality has a built in macro under the ML menu for the control
    commands.
    I had a similar problem with some stock and a quick
    clean of the connections in the lamp holder assembly sorted out the
    problem. Also worth checking the pins on the 8-pin CPC connector on the
    side of the head. The pins do get loose over time and can get pushed
    back into the unit and not give a good contact.
    Cheers
    Kevin
    Brigadier General:
  • 3,614 Answers
Try to check and clean the unit. this could an overheating on the unit.
  • 685 Answers
You could have a short
Sanyo PLC-XU33 multimedia projector. Starts up, goes through countdown, stays on for a minuit after that, then bulb goes out and it goes into shutdown?????? Rob,
hi,
check the video inputs. if there is no video input then the projector will goes off after count down.
also check that is the lamp replace light lights up or not. if its lights then you have to change the lamp and then reset the lamp hour.
ok
Jan 19, 2011 | Sanyo PLC XU33 Multimedia Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Lp600 won't strike
If you replace the lamp but do not reset the lamp hours then the projector will not ignite the lamp to stop it blowing up the lamp and causing further problems. You can reset the hours without the image, on the x2 version you turned on for 1 minute then held down the volume up and down buttons for 10 seconds but all versions vary. The infocus website can usually tell you how though you may have to look for it a bit. Failing that try a firmware update available from the infocus website that should erase its brain so you can start again, hopefully you have kept the original leads it was shipped with to do this otherwise it will cost you another £20
Feb 11, 2010 | Office Equipment & Supplies
LP540 Projector Lamp Does Not come on> it has an error message; "Lamp didn't Strike". Does that mean the Lamp/Bulb is bad?
It's most likely the lamp is bad or the part that starts the lamp called a ballast is bad. The LP540 model has an issue with the ballast burning out. The ballast is a part that starts or strikes the lamp. The only sure way to test is to try starting it with a known good lamp.
You can check for signs of a bad lamp. Think about how long you've had your projector & estimate the total hours on your lamp. If it's over 500 it very well could be the lamp as they fail at any time. Remove the lamp cover door & pull out the lamp to visually inspect it. Look in good light & use a magnifier if available too check for any cracks or chips in the small bulb & look to see if the round part of the small bulb is covered with a lot of white or if it's not round anymore. If it's very white it means it has a lot of hours on it. If there's any loose glass inside (check by turning the lamp cage in different directions) then the lamp is bad. If it's nice & clear or has only a small white spot it's probably a good lamp.
I repair almost all Infocus models if you need a quote.
Thanks & good luck,
Jim
Jan 13, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
I have a 50 inch Sony Wega and the TV is not coming on,the TV flashes green for about 45 seconds and then flashes red. The lamp light is not lit up, and the TV sounds like it wants to come on but it does...
ok then, it sounds like it is trying to strike the lamp on some of these Sony projections it will keep trying to strike the lamp even though the bulb is no good. The lamp error detection may not be working correctly, there is a detector loop around the ballast and if it is not positioned correctly it cannot correctly detect a bad lamp. Try removing the lamp and see if it is physically damaged, if not it still may be bad and is the most common cause for a no error condition and no light problem.
Sep 02, 2009 | Televison & Video
Eiki LC-XG110 lamp going off
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
May 13, 2009 | Eiki LC-XG110 Multimedia Projector
this can sometimes indicate either an overheating issue, a lamp service life problem, or that the cover to the lamp housing has not been secured properly.
Dec 14, 2007 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus 540 lamp didnt strike keep trying
if mains is ok and fan running ok, could be a bulb service issue, all lcd projectors have an internal lamp life counter which counts down and once the lamp has reached the end of its life it will not fire up and a new bulb will be required.
Dec 01, 2007 | InFocus LP 600 Multimedia Projector
WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Sep 17, 2007 | Mitsubishi WD-62327 62" Rear Projection...
InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector Logo
904 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
