Question about Roper RES7648E Dryer
Can't remove the blower fan from the motor shaft.
The dryer won't work at all checked the thermal fuse that was good want to have the motor checked but can't get it removed from the blower fan is it just pressed on
    Genius:
  • 1,028 Answers
Blade turns clockwise to remove..but ck door switch first also are you referring to small white fuse on blower housing or the one on element ..the one on blower will cause it not to run other heat only..also possible timer contacts ..motors are least likely to cause problems ..if unable to remove fan will need to be broken o0ff to remove
Posted on Nov 11, 2008
Whirlpool dryer wont heat
Hi Marlene Hatcher
Here are a few more things to check, you have checked some of these already:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
Bud
Oct 17, 2012 | Whirlpool Dryers
Series 600 kenmore electric dryer wont heat got power timer looks good however does the thermal cut off fuse keep heater coil from heating up because the coil has power but no heat
Hi onewyldeilli
Here are a few things to check:
Check your Wiring
Bud
Oct 09, 2012 | Kenmore 600 6965 Electric Dryer
Maytag dryer won't turn on and start cycle
Hi Calvin D Robinson Jr.
**************************************************************************ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check your Wiring
Bud
Oct 07, 2012 | Maytag SDE4606A Electric Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
see this causes and fix it. God bless you
Sep 28, 2012 | Dryers
Won't start roper dryer door closed properly still
Hi bootywatcher...
Check your Wiring
Bud
Dryer on kenmore stacked unit dryer won't dry
Hi clay1984
Check your Wiring
Sep 27, 2012 | Refrigerators
Admiral dryer 4475tq1 runs but no heat heater and all fuses check good
Hi gary williams
Check your Wiring
Bud
Sep 26, 2012 | Whirlpool LER5636P Electric Dryer
Keeps blowing thermal fuse even after complete cleaning of dryer door and blower and housing. changed vent to bucket and water lint trap. still blew fuse during fourth load.
have you check the fan blades?, is the fan loose at the motor shaft?, check inside the pipe of the blower housing for blockage. did you replace the thermal fuse alone or as a kit?, are ALL the seals in place including the blower seal?. after checking all that try to run dryer without the vent pipe attached and see if it hold.
Feb 12, 2011 | Maytag PYE2300AY Electric Dryer
Dryer heats sometime but clothes do not dry well....vent pipes seem to be clear of lint up to dryer...blower doesn't come on...no air blowing out of dryer...
thats the reason your clothes aren't dry.Have to have air moving through tub. Check fan motor probably a thermal overheat fuse that has blown or if motor is turning, look at the fan and see if it has a set screw or retaining ring that holds it on the shaft or both fan may not be turning with the shaft. More than likely though the blower motor overheated or just plain worn out.
Sep 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
227 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
