Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
Maytag oven doesn't light, broiler comes on instead
I have a Maytag MGR4452BDW gas range that the oven does not light any longer. When we push the Bake button on the control pad, the broiler comes on each time instead. Is this a problem with the control pad? Thanks!
  • Anonymous Mar 24, 2014
    lights sometimes
  • 5,911 Answers
On some gas ranges, the broiler comes on with the bake selection during warm up. This allows the oven to preheat much quicker. More than likely, the control pad is functioning properly and your bake igniter is bad. Igniters become weak with age and eventually go bad. Since the bake feature is used more frequently, it typically goes bad more often. The following link provides you with some guidance on oven igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Remember: just because an igniter glows, does not mean it is good. If they become weak, they will not draw the required current potential to open the gas safety valve.
If you determine the igniter to be bad, you can obtain a replacement at searspartsdirect.com. Just type in your model number and go to the "Gas Controls" heading and look for item number 14 (part number 74007498). If the igniter plug does not match the plug you have on your oven, the instructions will guide you to cut the wires and splice the ends together. There should be ceramic wire lugs that come with the igniter kit. CAUTION: Make sure you only use the ceramic (heat resistant) lugs that come with the kit. Splicing with regular wire lugs or electrical tape will melt due to the heat. Additionally, make sure you UNPLUG the appliance before replacing the igniter. Live voltage potentials are still present with the range shut off.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 11, 2008
Model# mgr4452bdw The surface burners light but the oven and broiler do not. when i set it for 350 degrees it stops at 100 degrees and no flames or heat. Do you know what the problem could be? Thanks...
You will need and ignitor to correct this problem, part number 12400035, or click on the link below.
Ignitor
When they become weak, the can extend cooking time and sometimes create a gas odor. One number problem is your unit is over 3 plus years and you do alot of baking. Normally is a 20 min replace job.
Good luck
Aug 17, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
MODEL # MGR4452BDW SERIAL# 16419405NA The oven turns itself on and cannot be turned off with the digital controls. I have to unplug the oven from the wall outlet to turn it off.
their are two possibilities causing that,
1) bake or broil button on the touch pad has shorted out causing the touchpad to act as if it were being pushed to turn on.
2) a relay on the control board has shorted out and constanly sending power to the element
Gene
Aug 05, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
I have a maytag MGR4452bdw gas oven. it will not heat up above 350 degs, what's wrong? please advise
first thing to check is the ignitor,remove the racks and remove the bottom inside floor,if anything else is there remove it so you can see the ignitor,set the oven to 350,if the ignitor glows but doesn.t ignite the flame in 40 seconds change out the ignitor,the reason why i say this is if the sensor or anything else would bring up an error code.hope this helps.
May 16, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
Our Maytag oven, the ignitor works, but no gas comes through. The broiler works and the top range works. So what can be the problem?
On a silicone carbide ignition system, the design is simple. The ignitor glows and changes the resistance in the circuit. When the resistance is right the gas valve will open and you will have ignition. So what goes wrong? The ignitor gets weak and no longer opens the safety valve. Here is a video which show how it works:
Dec 02, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
The oven won't heat up anymore. It was fine and now doesnt work. The broiler works fine and stove top is fine.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 29, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
Slow to heat up
Most likely your ignitor is going bad. This is the part that glows before the gas comes on. It has to draw the proper amperage to allow the gas in the oven to light and burn. Some ignitors glow and look good but are not drawing enough amperage for the gas valve to open, with the problem you are describing.
Very fragile part, easy to break,
good luck.....
Feb 24, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
I just replaced both the igniter and safety valve for the oven. When I plug in the oven, the oven comes on and stays on without setting the bake temp. The flame wont go out unless I unplugthe power
Your electronic oven control(clock) has failed in a short circuit mode.
Approximate cost is $120.
Go to repairclinic. com and enter your model number for a replacement electronic oven control.
Jan 10, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
333 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
