Question about Honeywell Programmable Thermostat Heater
Temp shows 2 degrees warmer than what is was set to
Our rth230b was installed one month ago.we did not program it because we are retired and at home most of the day.we set the heat at 73 degrees,the furnace comes on until the 73 temp is reached.it then shuts off.when we checkthe thermostat it shows 74 degrees,why?also what is the setpoint?also what are theheating cycle lengths 10 12 15 20 or 30 minutes meaning?thanks
  • 34 Answers
Sometimes the furnace does a better job than anticipated, i wouldn't worry about it, especially if the furnace shuts off.
the setpoint is the temperature you want it to be
cycle lenghts are determined by how much recovery you are requesting. for instance, in the morning when you wake up, you want the temperature to be at its setpoint. what the thermostat will do is make the furnace run a limited lengths during the recovery process.
Posted on Nov 12, 2008
My rth230b temperature up and down control buttons are now not operable, ie they do not move any function up or down. whether it is a clock reset, or changing the temperature.
Verify your battery is good. Make sure it is in manual and not program by using the mode select button. Verify its set to heat. The first push will show the set temp. Push twice or more to change the temp. With that all said if it is still locked out you might have a short. If its been less than a year you can call the support number on your installer sheet and check for warranty info. I didn't see one in the instructions but to be safe make sure there is not a lock out feature too.
Feb 26, 2011 | Honeywell Programmable Thermostat Heater
I just installed a honeywell 5-2 progammable thermostate.. Everything is hooked up fine and I have my days, hours wake, sleep, leave...etc all set, but when it goes on.. for example, I have it set for...
You didn't include a model number, so it's hard to know for sure - but I'll take a stab at this one. Many of these t-stats have a programmable offset to reduce "hunting". This can be as little as 1 degree or more than 2 degrees.
This means if you set the offset to 1 degree and the room temperature to about 65 degrees, the furnace will heat the room until the t-stat registers a rising temperature of 66 degrees. The furnace shuts off and will not turn on again until the t-stat registers a falling temperature of 64 degrees. The average is 65 degrees, and prevents the furnace from starting and stopping numerous times instead of just once with the 1 degree offset.
You can further reduce the number of furnace start and stops by increasing the offset to 2 degrees. This would work like this when the t-stat is set to 65 degrees and the room is cool:
Room Temp Furnace
63 On
64 On
65 On
66 On
67 On
68 Off
The room is now warm and heat or furnace is off. The room begins to cool like below:
67 Off
66 Off
65 Off
64 Off
63 Off
62 On
With a 1 degree offset, the room temperature varies +/-1 degree (about 2 degrees total). With a 2 degree offset, the temperature about varies +/ -2 degrees (about 4 degrees total).
Also, when the thermostat shut the heat off, the heat that was made is delivered to the space instead of wasted by sending outdoors - so the room will get a little warmer even though no fuel is being burned. The same holds true at the other end. When the t-stat turn heat on, fuel is burned, but there's little heat until the source has reached the optimum temperature and then the heat is delivered to the space.
I hope this helps & good luck! Pleas rate my reply - thanks!
Jan 24, 2011 | Honeywell Programmable Thermostat Heater
Hello. Our RTH230B thermostat has a mind of it's
I think your feedback temp sensor has faulted, get it looked at.
Jan 24, 2010 | Honeywell Programmable Thermostat Heater
Message: "in recovery"
the "in recovery mode" is refering to a thing called energy recovery management its one of the features on your tstat what it does- when you are using the program on your tstat the "in recovery" starts your unit early so if the tstat is set to be 70 degrees at 8 in the morning when 8 o clock hits it will already be 70 degrees in your house you can turn this feature off if you want in the installation setup codes
Jun 24, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B a/c problem
if you set the thermostat on 70 and your house won't get ant cooler than 72, there is a problem with your system,not your stat. I'm thinking you are low on refrigerant if it is somewhat working. when the unit is running, if you can get your hand on the larger refrigerant line under the black insulation, it should be cold, about 55 degrees.
Jun 19, 2009 | Honeywell Programmable Thermostat Heater
How do I get my honeywell system up and going?
for now, put switches on thermostat to hear and press the up arrow button to the desired temp. All your programed temps will take more explaining and it would be best you secure a owners instruction book from home depot. oif anything, buy thr same thermostat and either keep it or return it . I'd keep it regardless, read the pmphlet,program you heat and a/c before returning for refund. Don't destroy packaging and give them back everything. You will also need two AAbatteries. Good luck.
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
I have my temp on C and I need to change back to F I have the RTH230B programable
May 30, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
398 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
