Question about Gyration GO 2.4 Air Mouse/Compact Keyboard
GYRATION AIR MOUSE 2.4 GHZ
I HAVE A GYRATION AIR MOUSE 2.4 GHZ WHICH RECENTLY STARTED WHISTLING. IT STILL WORKS, BUT VERY ANNOYING.
WOULD REPLACING THE BATTERY FIX PROBLEM?
  • 3 Answers
The audible noise is an indication that the internal Gyro has failed. There is no field fix for this problem. If the mouse is still under warranty have Gyration exchange the defective device for you.
Posted on Jun 05, 2009
  • gsupport Jun 05, 2009
    The audible noise is an indication that the internal Gyro is failing. THere is no field fix for this problem. If the device is still under warranty Gyration will exchange it. You must contact Gyration Technical Support at 888-340-0033 or gsupport@movea.com for help.
4 Suggested Answers
SOURCE: Gyration mouse will not synch
Only part of keyboard works
Posted on Apr 16, 2009
  • 112 Answers
SOURCE: Do you have a replacement battery Gyration Ultra
I suggest you contact Gyration support directly. Their email address is:
support@gyration.com
Posted on Sep 15, 2009
Testimonial: "Thank you very much, I appreciate your time."
xfvag
  • 23 Answers
SOURCE: Where can I get an "AAA" battery caddy for the Gyration Mouse.
Try a big electronic store near you and get your mouse with you to test the caddy for fitting in.Hope that helped!
Posted on Mar 24, 2010
How do I turn the Safari Mouse off?
Hi Charles,
According to:
Product Description Color: Brown
The Maxell 2.4 GHz Wireless Safari Mini Optical Mice have more than cool looks. Since they are 2.4 GHz wireless optical you'll notice less signal loss. They also have 3 key buttons and a scroll wheel so you can speed through your computer programs. The Maxell mice are wireless so you don't need to worry about wires getting in the way. They can detect a computer up to 32 feet away. These are compatible with Windows 7, Vista, XP, 2000, ME, Mac OS 10.0 or above. Requires one AAA battery.
- So i do believe there is no on an off button on that mouse as I read on this site that says: "This one doesn't have an on/of switch, so in order to turn it off you have to disconnect the USB every time and store it underneath the mouse (annoying) . also, if it's idle for a minute (maybe less) the mouse goes in sleep mode and you have to disconnect the USB to wake it back up (super annoying) . The mouse works fine, it just gets old having to take it in and out all the time".
Amazon com Maxell 2 4 GHz Wireless Safari Mini Optical Mouse Brown...
May 03, 2014 | Maxell 2.4 GHz Wireless Safari Mini...
Gyration gc15m, fully charged, trigger works to move mouse, but not LED. connect button does nothing. Scott
It is the battery. It is probably not taking a full charge. Buy a replacement battery, charge it up, then give it a try. I did. It worked.
Sep 12, 2011 | Gyration Go 2.4 Air-Mouse Handset
Mar 24, 2010 | Gyration Ultra Professional Optical Mouse
The mouse has lost its air feature. Still works from a desk as an optical mouse. Produces a high pitched sound .
Sorry my reply is five years after the question but I really hope this reply can help anyone out. I have a gyration GYR3101US Media center remote.
mouse-lost-its-air-feature-still-works-nec1hkrws0ash25xby3rpbkt-5-0.jpg I love this remote/air mouse but after I dropped it about two months back anytime I would try to use the air mouse, it would emit a loud high pitch sound and put the cursor near the time clock unable to move it. Tonight I took it apart. this is what I found. There is one screw behind the batteries, then you have to pry it apart with a flat head. once inside find the gyration sensor
mouse-lost-its-air-feature-still-works-nec1hkrws0ash25xby3rpbkt-5-4.jpg CAREFULLY pry apart the sensor with a little flathead, there is a metal plate on the bottom of the sensor so DO NOT pry from the circuit board up that will break the sensor off. Put the screw driver between the metal plate and the outer casing you should see a little crack. also i cut most of that red tape off with a razor blade before prying.
mouse-lost-its-air-feature-still-works-nec1hkrws0ash25xby3rpbkt-5-7.jpg The red arrow is pointing at the part inside the sensor that had come lose from the drop and was moving about freely inside. I'm guessing it's a weight or magnet. After carefully and gently snapping it back in place, put your mouse back together enough to test it. at first it still had problems but i double clicked the mouse movement button and set it on a flat surface so it could calibrate itself. SUCCESS. I hope this helps my gyration is working fine now. contact me if needed john4628 AT gmail. (There are no fans or bearings in this mouse or any gyration mouse)
Feb 05, 2010 | Gyration GO 2.4 Air Mouse/Compact Keyboard
Do you have a replacement battery Gyration Ultra GP4102 Mouse.
Sep 15, 2009 | Gyration Ultra Cordless Optical Mouse
How do i set up my gyration wireless mouse ???
The Gyration air mouse is easy to use & install. Just plug in the USB receiver into available USB port, slide the Air mouse switch to on, press the connect button on the receiver & air mouse, your computer will automatically detect & install the device. “there are no drivers to manually install”
Please let us know if that was helpful enough.
Thanks
Shiv.
Aug 12, 2009 | RCA Gyration Wireless Mouse
Left mouse key button works intermittantly
Other than trying with a fresh set of known-good batteries, it might be defective out-of-box. Check with your place of purchase for repair or replacement options.
May 09, 2009 | Computers & Internet
Gyration GO 2.4 Air Mouse/Compact Keyboard Logo
567 people viewed this question
Top Gyration Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
solver2010
Are you a Gyration Computer and Internet Expert? Answer questions, earn points and help others
