Question about Amana Refrigerators
When compressor clicks on it makes funny electrical humming sound and then makes click sound and does not get cold. the compressor feels hot.
    President:
  • Amana Master
  • 2,651 Answers
Sounds like a bad compressor to me, you should have 5 yr full warr on compressor, if over 5 years you can try to replace the overload relay assy attached to the side of the compressor
Posted on Nov 11, 2008
My f&p Frigidaire keeps clicking every 10-15
If it is clecking it will need to be tested. Feel the top of the compressor to see how hot. Can you keep hand on top of compressor? Too hot to keep hand there? What is the model number of your refrigerator? Thanks Sea Breeze
Dec 09, 2012 | Refrigerators
Loud humming noise from compressor
If sounds are from compressor I don't think compressor will start with humming. It is possible the compressor start relay and run capacitor are defective. If humming and not cooling the compressor is most likely overheating. Plull away from wall and unplug, remove lower cover over compressor and feel top of compressor. If too hot to keep hand there you will need to leave unplugged until problem is resolved. Click Here=> Service Manual Hopefull the compressor has not been affected so click here for=> Tech Sheet were we can go throug some test steps find exactly what is going on, Thanks, Sea Breeze
Dec 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
This unit was purchased new 61 months ago. First instance of any problems, ever, today it seems food isn't being kept frozen solid. We suspect the compressor is having a problem. There was no sound...
Yes it is a very big concern.It sounds to me like your condenser is dirty and the compressor gets hot and goes off on overload.You can tell by putting your hand NEAR the compressor.Be careful as the compressor can be very hot
Sep 14, 2010 | Frigidaire Freezers
Buzzing from lower area - replaced relay and cap - not freezing - staying cold but not freezing - Synptom: Click -humming for 15 sec-click cycles like that every 5 minutes Compressor is warm to Hot - fan...
If the defrost cycle was stuck on then the compressor would not be humming trying to start. You may have a shorted compressor. Especially if its a frigidaire they are known to have the worst compressors. You can use a meter to check your compressor windings. You can check for a short by scratching the paint off the compressor and checking from each terminal to the bare metal on the compressor. If you have continuity then its shorted. Also check continuity from each pair of pins on the compressor. Good Luck _MJ_
Mar 14, 2010 | Jenn-Air JCB2282H Side by Side...
I purchased an Amana refrigerator that has been making a humming noise and will not keep food cold or frozen. what' wrong? The model # is ABB1924DEB, and I purchsed it in 2005. is it included in their...
The recall was for units that had embraco compressors. the relay would burn up and not start the comperssor. (hum and click) some amanas had tecumseh compressors. They would just scize up and not run (hum and click)No recall. remove the back cover and see what name is on your compressor. If its hot and trying to start, Embraco needs new relay, Tecumseh needs to be replaced with a embraco compressor.
Dec 01, 2009 | Refrigerators
My side by side refrigerator and freezer artent
ALWAYS CHECK THE EASY THINGS FIRST,LOOK LISTEN AND FEEL. PULL THE FRIG OUT AND CHECK THE COILS AND CLEAN IF DIRTY
2) LISTEN TO HEAR IF THE COMPRESSOR IS TRYING TO START, WHERE THE POWER CORD GOES INTO THE COMPRESSOR YOU SHOULD SEE A LITTLEDOMM SHAPED COVER THAT HOUSES THE CONNECTIONS LISTEN TO SEE IF YOU HEAR A HUM THE A CLICK.
THE HUM IS THE COMPRESSOR TRYING TO START THE CLICK IS THE OVER LOAD TRIPPING OUT FROM TRYING TO START THE COMPRESSOR, IF YOU HEAR THE HUM AND CLICK THE COMPRESSOR IS LOCKED UP AND CAN BE VERY COSTLY TO REPAIR. IF YOU HEAR THE COMPRESSOR RUNNING FEEL THE LARGER OF THE TWO COPPER LINES ON THE COMPRESSOR AND SEE IF IT IS VERY HOT, WHEN I SAY HOT I MEAN HOT SO JUST LIGHTLY TOUCH QUICK. IF THE LINE IS VERY HOT THE COMPRESSOR IS BAD AND PUMPING HOT GAS BACK TO THE UNIT. THIS ALSO IS NOT CHEAP
3) IF THE LINE IS WARM YOU MIGHT BE SAFE IT COULD JUST BE LOW ON A CHARGE THIS CAN BE REPAIRED EASILY SOME TIMES, ALL DEPENDS ON WHERE THE LEAK IS IN THE UNIT.
IF YOU DON'T FIND ANY OF THESE THINGS WRONG AND YOU HAVE ELECTRICAL TRAINING YOU CAN START AT THE POWER CORD AND WORK YOUR WAY THRU THE UNIT FOR ANY BAD COMPONENTS. OF WHILE THE UNIT IS PLUGED IN DOES THE LIGHT COME ON. UNLESS YOU ARE CFC CERTIFIED AND HOLD
A CARD FOR THIS NO YOU SHOULD NOT TRY AND REPAIR THIS YOUR SELF. ELECTRICAL TROUBLE SHOOTING YOU CAN DO
WHEN EVER YOU HAVE TO CUT INTO THE REFRIGERATION SYSTEM ITSELF I WOULD SAY NO UNLESS YOU HOLD THIS CFC CARD THE FINES ARE UNBELIEVABLE IF YOUR EVER CAUGHT
tstewart1956
Aug 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer not freezing on m,aytag mfd2560hes
hi andy, based on your story, i think the humming sound is coming from the compressor trying to start and the clicking sound is when the overload trips and make that clicking sound to turn off the compressor but it does resets itself so it would humm again after a few minutes and tripps off again..try to unplug the unit for a day to cool off the compressr and then plug it back. if it will happen again, you need to replace the compressor. i hope i was able to help..
Jul 07, 2008 | Maytag MFD2560HES Bottom Freezer French...
I moved our 18 month old samsung fridge freezer Model SR281NW and one week later it has stopped working. The freezer fully defrosted and the fridge, even though it has the light on, is not cold
Is the compressor trying to run at all. Are any sounds coming from the area of the compressor? Like a hum and a click sound in that order? If the compressor is cold to the touch it could be a control problem. If the compressor is cold there are two things that shut its power off. The thermostat which controls the temperature or the defrost system. If the compressor is hot the problem is compressor related.
May 18, 2008 | Samsung Refrigerators
Refrigerators Logo
145 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
