Question about IBM Office Equipment & Supplies
Printer won't print magenta color; prints appear yellowish green
We have a IBM Infoprint 8 color laser printer.
The magenta won't print.
We are not out of toner. We have cleaned the machine. Prints appear greenish-blue.
How can we fix this?
The 'belt' or 'ribbon' at the toner cartridge was loosened.
Posted on Nov 11, 2008
Need print driver for ibm 1120 using win 7 64 bit
You can download the BM InfoPrint 1xxx AIX Print Driver from the IBM support WEB site. Please click on this link and select your model printer to download :- http://www-01.ibm.com/support/docview.wss?rs=95&context=SRATEW&dc=D400&uid=psd1P4000313&loc=en_US&cs=utf-8&lang=en
Dec 12, 2012 | IBM Infoprint 1120 Laser Printer
HP Color Laser Jet CP1215: won't print at all since magenta is out. I changed printer to grayscale but just keeps blinking the magenta sing and the traiangle with ! sign next to it
I know the frustration being in IT for over 20 years working on various peripherals.
These printer MIX so that way there is a balance at the final phase. You have to purchase a magenta cartridge to get this working again. Bypassing this will make tis printer suffer and long term damage can cause a economical issue on your end in the long run.
Now if your at a critical point you can bypass but I do not professionally recommend this but here it goes.
1. Open the CP1210 Series Toolbox 2. OPEN System Settings 3. Then enable Cartridge Out Override 4. Then click apply
I hope this works for you, whilst you purchase a magenta toner. Please do not forget to leave a positive rating and feedback.
Best of Luck
Rulds2008
Jul 26, 2011 | HP LaserJet CP1215 Color Printer
How reset photoconductor ibm infoprint ibm1512 thank you
The instructions for IBM Infoprint 1412/1512 printer's photoconductor is the same as the Lexmark E342.
The instructions are located here: http://support.lexmark.com/index?page=content&id=HO2564&locale=en&userlocale=EN_US
Recap of Instructions:
To Reset Photoconductor page count:
1. Turn off printer
2. Press and hold the Select and Return buttons at the same time on the panel and turn the printer on (continue holding down buttons until printer screen displays "Performing Self Test" or "CONFIG MENU").
3. If "Reset PC Cnt" does not appear on screen, press the left or right menu button until it appears.
4. Press "Select" and the message "Resettting PC Cnt Value" should briefly appear indicating the page count is reset.
5. Turn off printer when "CONFIG MENU" appears again.
6. Wait 5 or more seconds and turn back on. Done.
7. It is suggested to check and verify that the PC Count is reset by printing a menu setting page:
a. Press left or right menu buttons until you see "Utilities Menu" and press "Select".
b. Press left or right menu button until you see "Print Menus" and press "Select".
c. This should print out the information. Look for "Cartridge Info" and the word "Photoconductor". It should indicate "OK" or close to 100%.
d. If not showing "OK", print 10-20 pages and Print Menu again to check. If still not, reset PC again and check again.
Jan 13, 2011 | IBM Infoprint 1512 Laser Printer
I am looking for a free Manual for the IBM Infoprint 20 Printer
hey welcome to fixya. i hope u'll be fine.
  • To download the manual foe IBM info print 20 printer just follow the following link
if u like the solution Kindly do Rate me
For manual Click Here
Keep using fixya
Thanks
Feb 09, 2010 | IBM Infoprint 20 Laser Printer
We have IBM Infoprint 1125 printer. The problem is that when You send a document from PC for printing it starts with printing and after a few seconds and several printed pages it starts to print very very...
Check the cassette, on certain printers if the cassette is set for the wrong size paper it will cause the printer to run slow, this happens on HP so it might be worth a try.
Oct 31, 2017 | IBM Infoprint 1125 Laser Printer
Infoprint 1512 prints blanks from int. and ext. print source
How to get on software to setup for printer , infoprinter 1512 ( Ibm ) .
tha for kind wondows ( wondows vista )
Aug 14, 2009 | IBM Infoprint 1512 Laser Printer
IBM Infoprint 1532
There is probably a small piece of paper in the back of the printer in the fuser. Shutdown the printer and wait a few minutes as this part is hot. You may need to remove a few screws to take off the back cover and check inside the fuser.
Jun 03, 2009 | IBM Infoprint 1532 Laser Printer
Infoprint 1332
in valid cartridge refill
Oct 21, 2008 | IBM Infoprint 1332 Laser Printer
IBM Infoprint 1512 out of paper message
It could be a problem with the paper feed roller above the tray or a sensor problem.
It should be looked at by a service technician.
Jun 12, 2008 | IBM Infoprint 1512 Laser Printer
Print Cartridge
Unfortunatly, no. This is the compatibility list for that part number: IBM2.gif InfoPrint 1352 / 1352n / 1372 / 1372n Laser Toner Printers
May 14, 2008 | IBM Infoprint 1332 Laser Printer
94 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
