Question about ASUS P5PE-VM Motherboard
''CMOS Settings Wrong! USB DEVICE OVER CURRENT STATUS DETECTED
>ive undergo everything...unhooked the front panel USB, dettached all connected devices,,clear the CMOS, change the CMOS battery, only 1 stick of RAM use,check the memory module, remove and reset memory module, ive checked the jumper settings, update the bios to latest version..ive checked already the MoBo if there is short circuit,,.nothings happen!!
even i dismantle all components from MoBo, theres nothing happen..Always the error pop up....
What should i do?Does anybody knows about this type of error?
  • 6 more comments
  • jay_ar4
    jay_ar4 Nov 11, 2008
    Thanks for your immediate reply..Im already using the PS2 port for keyboard/mouse but still the error persist. I've checked already the jumper settings in USB front panel and the Front panel itself near the CMOS CLRTC, it seems there is a short circuit happened between the CMOS CLRTC and the front panel where the on/off jumper located. It happens when i clear the CMOS and then it automatically turning ON the PC..Is there a possibility that this will be the cause of error?
    Tnxs..
  • jay_ar4
    Yes, its an ASUS P5PE VM MoBo....
    Thanks again..
  • jay_ar4
    Recently, we changed power supply. Just in case, the problem was in the power supply..:)
    But unfortunately, nothings happen!. Still the error persists.. I've already give my time troubleshooting this type of error. Well i guess, i've encountered a serious type of error..
    Does anybody have a bright ideas? Any help would be appreciated.
    Thanks.
  • jay_ar4
    jay_ar4 Nov 12, 2008
    Ok. Thanks for your help. I apologize for this word "Does anybody have a bright ideas?", im just gathering any information on how to fix this type of problem.
    For additional information, i've try another MoBo P5PE VM for my PC. Actually, no more annoying error persists.
    Then, i have two options left. Whether im going to buy a new one or trying my very best to fix this one.:)
    For additional information again, i try to update my bios EZ FLASH to the latest one. Until now, it keeps updating. Correct me if im wrong, is EZ FLASH and AFLASH or AWDFLASH is the same?
    Because, at first im using AFLASH or AWDFLASH in updating my bios (im refering to ASUSTECH), it was the latest one. But then, it still the same, the annoying error persists. I think, im using the wrong one (AFLASH) because nothings happen after updating my bios. So, i try EZ FLASH for my bios now. So far, it keeps updating.I hope it works.
    Anyway, thanks for your help and spending your time with us.
    Thanks for FixYa!.
  • jay_ar4
    jay_ar4 Nov 21, 2008
    Yes, i've already checked the USB ports sockets then i've found out that the problem is in there because when i clear the CMOS with its CLRTC, it automatically turning ON my pc..
  • jay_ar4
    For additional information with my problem:
    By the way, my pc is 24 hours a day working then it happen one day when i shutdown, then restarting up again, it cannot proceed to startup menu..Then there is an error that is always prompting ...
    "USB DEVICE OVER CURRENT STATUS DETECTED!
    THE SYSTEM WILL SHUTDOWN IN 15 SECONDS"
    >it keeps prompting every restarting up....Why?
  • Anonymous Dec 21, 2008
    I have the same problem and nothing that i do helps. I think that we can't resolve this.
  • humes1965 Apr 02, 2009
    esystem ei 204 USB DEVICE OVER CURRENT STATUS DETECTED
    Sergeant:
  • 395 Answers
Have you checked all USB port sockets to see if any of them are broken? I mean inside the socket itself. It is easy to break the small plastic black tongue in these (e.g. by bending down on a USB memory stick. Then when you put another USB plug into it, the 4 contacts can get bent and the +5V will short out with the case.
Check all USB sockets.
Posted on Nov 16, 2008
  • Steve Si
    Steve Si Nov 21, 2008
    Disconnect the front USB sockets to see if this fixes it?
''CMOS Settings Wrong! USB DEVICE OVER CURRENT...
Posted on Dec 13, 2008
I experienced the same problem but tracked it down to a truly short circuited USB port on my *case* (i.e. not the on-board one). Take all USB connectors out. Inspect all ports and clean them carefuly to remove and debris that could cause short circuit. Disconnect any and all external (off-board) USB ports from the mainboard and clean those connectors as well (same as above). Then see whether this solved the problem.
Posted on Jun 03, 2009
My mothers House had termites and they were crawling inside of my sons PC. Termites were shorting out his video card previously. They got fried onto the card. This time it was the same thing. Termites. So, check for debris or bugs like roaches or TErMITES, LOL!
Posted on Jul 15, 2010
    Problem Solver:
  • 5 Answers
Just check the jumper settings my mb is p5ql pro, came with 1 jumper missing for usb and displayed the same error message, i've used one from my own stash and sorted
Posted on Feb 13, 2009
    Brigadier General:
  • 6,966 Answers
Offhand, if you are using either or both a USB keyboard and/or mouse, try using PS/2s instead. If problem is gone any of the the two has a defective circuitry (keyboard/mouse). Or for that matter any USB device plugged in when booting. If removed and problem still persists, then there is a short in any of the USB ports. The USB port has only 4 connections (terminals) with one end tied to the ground. The opposite end is the B+5. With the use of a continuity tester, you can try to isolate which port is grounded
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 11, 2008
Testimonial: "Thanks you so much.."
  • Louie  Role
    Louie Role Nov 11, 2008
    Hi again,
    Appreciate likewise the quick postback.
    Please confirm that your motherboard is an ASUS P5PE-VM.
    Cheers.
  • Louie  Role
    Have you checked with the use of a continuity tester (DVM or VOM) my initial post "The USB port has only 4 connections (terminals) with one end tied to
    Additionally, in your subsequent post "I've checked already the jumper settings in USB front panel", to my knowledge, there are no jumper settings for the USB, there are however pin connectors that would go to the front USB ports. Any jumper installed/placed on the front USB pins on the motherboard would be shorting those pins. If you placed any jumpers where there should be none, it may be necessary for you to reference the manual as to the correct locations of the connectors, where they should go to and which needs jumpers.
    Incidentally, since you are asking for assistance from others "Does anybody have a bright ideas?", this would be my last post. Good luck.
Dude, greats from russia. sorry for ugly sort of typing.
Take your motherboard away from the case. Plug all of your hardware and start the system. If all going good - the problem is in the circuts between your case and motherboard. That little places where screw-bolts wrapped up. I'm glad if this solution helps you.
Posted on Jul 15, 2009
  • MorrisAns Jul 15, 2011
    Hello,had this problem only when the system is mounted in the case. However outside the case the system works perfectly. What do you mean by the screw-bolt (is it the gold plated screw to align the motherboard in the case)? or could it be the cabling?
    plus i did try to connect the front connector while the motherboard is away from the case..it work great unless it is in the case which causes the problem.
    Scholar:
  • 113 Answers
The most successful solution to this would be to re-seat the motherboard. There is a good chance that it wasn't seated properly and is having trouble with the case. Make sure you have the PSU off when you do so.
Posted on Sep 07, 2010
Hi everyone, I HAD the same problem and tried every thung mentioned in all these forums until i read goitalone's post so I looked at my video wich is on board on a P4GC-MX\1333
It seems that one of my video srew bolts were really loose to where they almost came out with the monitor plug so I tightened them down and plugged back in the monitor and viola booted with the F1 to enter cmos I wentin and set all settings and it works just fine THAMKS A MILLION goitalone even just for the insight as my computer does not have termites hehe.
Posted on Aug 01, 2010
  • john wyke Oct 29, 2011
    Thanks for this solution - I have spent hours on this. I removed the chassis screw from under the Graphics card slot at the rear .... and IT WORKS - would you believe it??
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: CMOS Settings is Wrong! USB Device over Current Status Detected!
It would seem that you posted twice, pls see you other post.
When I go to boot up I get a message saying " USB DEVICE OVER CURRENT STATUS DETECTED CLOSE DOWN IN 15 SECs" is my motherboard now faulty?
Maybe but there are a few things to check before you call the Asus,
Check all of your USB ports and make sure that there is noting connected, stuck, broken, sticking out, sticking in, or falling out.
If you have front and back USB ports that is connected by cables to your motherboard disconnect them.
If issue still occurs then you have a damaged USB port on your motherboard, Call Asus for further instructions.
Dec 20, 2012 | ASUS M2N-MX Motherboard
Current status overload detected
Revert to Windows 7 .. Windows 8 is too 'new' to have all the bugs (and drivers) sorted out ...
Nov 12, 2012 | ASUS LGA 1155 - P67 - SATA 6Gbps and USB...
CMOS Settings is Wrong! USB Device over Current Status Detected! tried all references given here nothing happend, please help shreeramgodbole@gmail.com
Hi, you can download a manual and drivers here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Please select your operating system.
Download the asus update utility and upgrade the bios
its the easyest way to do that.
Unzip the file before you install it.
You can also reset the bios to factory settings.
Look in the manual how you do that and for troubleshooting also.
Aug 30, 2011 | ASUS P5PE-VM Motherboard
Acer P5Q-EM mobo. When trying to boot i get this message USB DEVICE OVER CURRENT STATUS DETECTED WILL SWHUT DOWN IN 15 sec. which it does, I am also unable to get into the bios, even before I get the...
Ive seen this a few times. Its either a usb device plugged into the board shorting a usb port out, or whoever put it together wired the usb ports wrong on the board. FYI its an Asus mb not an Acer.
Sep 07, 2010 | Acer Computers & Internet
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
CMOS CHECKSUM BAD USB DEVICE OVER CURRENT STATUS DETECTED SYSTEM WILL SHUT DOWN IN 15 SECS there is no shortcircuit in usb header 5v is ok i also upgrade bios but it did not solve this error
easy......cmos checksum bad =
dead battery ...buy a new cmos battery for £2 ..make sure you install correct way up...
from any pc shop or ebay...
you will have to reset date /time in bios afterwards...f2 or delete usually to enter bios settings..
regards tonster
Apr 05, 2009 | ASUS P5RD2-VM Motherboard
The dvd-rom cannot be found. cd or dvd emulation software has been detected.
hi there,
try to detect in the CMOS set up. restart your computer in booting process press F2 or Delete tab
and check if your dvd is detected if not you should check the cable/ power connection of your dvd. and then try again.
if detected if your using vista update dvd drivers for vista and then if it is xp you have a like this if you downgrade your pc from vista to old XP. you have this problem. update to microsoft the SP2 and SP3 updates.
Nov 29, 2008 | Computers & Internet
Nov 11, 2008 | ASUS P5PE-VM Motherboard
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
cheak bios settings diable serial port parrel and any onbord stuff u wont use ok
Feb 01, 2008 | ASUS P5LD2 Motherboard
ASUS P5PE-VM Motherboard Logo
11,135 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
