SOURCE: Threading a bernina serger
Here is a little jingle to remember as far as the order of threads to thread...
Upper looper, lower looper, left needle, right.
Usuall if you give numbers to the threads from left to right as 1,2,3,4 , you would thread it in the order of 3, 4, 2, 1 . Also when threading the loopers be sure the lower looper thread goes over the top of the upper looper thread as it goes out the back.
Hope this helps.
SOURCE: 2000DE serger manual
Can help you with a bernina 2000 manual at [email protected] or try www.janomestuff.com
SOURCE: I can't find my Bernina Serger 800 dl manual - how
From what I have read this manual is less than desirable. Neither is the one for the brand that I have.
You may have better guidance if you purchase and use Nancy Zieman's "Serge with Confidence". I have found it very helpful.
For the two thread rolled hem, the looper cover is used to "trick" the looper into "thinking" it is threaded.
On my serger (not a Bernina), this is referred to as a "subsidiary looper". It is a spring type mechanism that fits in a small hole at the top of the upper looper.
You use a rolled edge presser foot; right or left needle; stitch length @ normal or wider; stitch length @ 1mm for the left needle/0.5 for the right needle; differential feed @ normal; needle tension - tighten; lower looper tension - normal or looser; two thread looper cover - engaged.
Test and adjust the tension as needed before making the rolled hem on your garment.
I hope this helps.
SOURCE: I want to find a manual for Bernina Serger - Model
go to the Bernina website
1.on the home page look on the left hand side of the page toward the top & find the support tab
2.click on the tab
3.go down the middle of the page & find the out of print manuals
4.click on the tab
5.look in the middle of the page for sergers/overlockers
6.yours should be the last model number
7.click on it-downloads easy
SOURCE: Need manual for bernina serger 1300dc
I have a Bernina Overlocker/serger 1300DC having trouble threading the machine
