Question about Velodyne SPL-1000 Subwoofer
Crackling sounds in my SPL-1000 ?????
Driver looks ok from the outside. Can I buy and replace parts for this ?
  • 124 Answers
Sounds like an amplifier problem.
Contact Velodyne or the shop that you purchased the unit from
Posted on Jan 04, 2009
Broken headphone jack on dell d630
Yes! if the plugin is not secure the connection will be poor causing unstable reception in the audio department.
May 10, 2012 | Dell Latitude D630 Laptop Computer PC...
Musical fidelity amp x-a2, one channel intermittent crackling / fading out, any ideas?! Tried swapping source and speakers... Many thanks -chris
hi,
This problem will occur when any one of the driver transistor is become faulty. You have to replace all the driver transistor of the same channel which make cracking sound . It is very difficult to tell which one is faulty. Because if you check the transistors with multimeter it will be ok. Replace all the driver transistor in that channel with same part number marked on it. The driver transistors will look like this,
ajin_g_6.jpg ok
May 20, 2011 | Car Audio & Video
Power cord doesn't work and crackles
STOP using it immediately, throw it away and replace it. You can buy a replacement from the manufactures website or go to BestBuy and buy a universal one. Be prepared to spend about $90, unless you can buy one on ebay. just look at the big black box on the power cord and WRITE DOWN THE VOLTAGE AND AMPS listed there. make sure the new one matches exactly.
PLEASE RATE THIS ADVICE WITH THUMBS UP!!!
Apr 23, 2010 | Computers & Internet
SPL 10BV - no output after a long session with volume control seat 5 (12 o'clock). Has it got a fuse?
Most powered devices have a fuse. Does it work after being turned down in volume? or is it completely dead with no signs of power? or does it show some indicator light but no sound? Check for blown fuse and then for blown speaker coil.
Mar 03, 2010 | Velodyne SPL-1000 Subwoofer
SPL8R Velodyne sub - Same probelm
Go to the Velodyne web site and check the service center locations.
They may have one in your area.
It sounds like the amp may be the problem. That may be all you need to send.
Best bet, Contact Velodyne.
Jun 08, 2009 | Velodyne HGS-10 Subwoofer
550x2 subs....SPL z2x-820 Amp
The 230 watt amp is a little small for your subs. They'll work, but if you are looking for max SPL, you won't get it. To push those Audiobahn's to their potential pavement shaking max, I would recommend an amp in the range of 500-600 rms (2-channel bridged) or 1000 watts rms monoblock.
Hope this helps.
Mar 28, 2009 | SPL Dynamics Z2X-820 Car Audio Amplifier
Cakewalk Sonar - Edirol UA-1000 crackles on playback!
That's a latency issue it sounds like.
There's a slider under "Audio" .
Move it in increments towards "slow", test it as you go.
Leave it at the highest setting possible that doesn't crackle.
I've heard this so bad that it sounds like a gun going off.
It scares the Hell out of you when it happens !
Jan 20, 2009 | Edirol UA-1000 External Sound System
Velodyne SPL-1000 II subwoofer only snaps, pops and hisses
Go to the Velodyne web site, look under the support section and check the service center listings.
Also you could try the place you purchased the unit.
Dec 30, 2008 | Velodyne SPL-1000 II Subwoofer
Starting problem with 1998 Saturn SW2
Ok I know that Coolant Temp Sensors are very very Common to Saturns, Only buy the Parts at saturn they are Calibrated Parts. Aftermarket do not work well.
You could have a work starter bendix Drive or a worn Flywheel that is causing the crackling sound you hear, To be totally honest I need to hear the sound to tell you for sure. If this information is good please Give me a Fixya! Rating and if there is anything more I can do for you please contact me .
Aug 26, 2008 | Saturn SW2 Cars & Trucks
Open Questions:
Velodyne SPL-1000 Subwoofer Logo
461 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
