Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Samsung HCN4226W 42
My television began showing a red sceen with horizontal lines. Finally all of a sudden sound stayed on and screen went totaly dead. I tried adjusting the F/S adjuster and the HV adjuster but no result. Manufacture date is August 2003, serial number 3CEW800594A. Your help will be greatly appreciated. After reading some of the posts, I finally decided to order the convergence amp board.I replaced it with the old one, unfortunately I am having the same problem. Aditional help would be greatly appreciated.
    Problem Solver:
  • 7 Answers
Check to see if you have the 117 volts you need to power the Flyback Transformer. You can test this at the connector labeled CN801 at TP61 and grd. If you do not have power here check the fuses around the T801S Transformer. They are little green components that look like resistor and labeled with an FD.
Posted on Nov 10, 2006
My tv sumsung hcn4226w 42 inch rear projection will not turn on
either the lamp is burned out or the ballast and power supply board need to be replaced. can call 1-800-samsung for nearest service center.
Dec 11, 2009 | Samsung HCN4226W 42" Rear Projection...
My Samsung hcn4226w won't stay on.
There are many protective circuits inside the set that will shut it down if a problem is detected. It sounds like there are intermittant detections of problems and the "restart" temporarily clears the problem. If the unit is no longer under warranty, open up the back with the set unplugged and try reseating all of the boards and connectors. The trip may have jared a few things loose. Update this with the results.
Thanks,
Dan
Aug 20, 2009 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W "image pinching"
The convergence IC has gone out and is located on the Main bd or the Power supply bd depending on the specific model and must be replaced and a Full convergence alignment must be performed to return your tv to a watchable condition. Only a Samsung trained tech can do this.
Jul 16, 2009 | Samsung HCN4226W 42" Rear Projection...
Samsung LN-T4065F
clicking sound coming from television
Jun 18, 2009 | Samsung HCN4226W 42" Rear Projection...
My samsung hcn4226wx rear projection tv
IT SOUNS LIKE YOU NEED THE Convergence Module BP9500415B BP95-00415B
Feb 28, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCL552W
these have been know to have bad convergence ic but that would only be a guess as to whats wrong i would have someone give you and est.
Jan 14, 2008 | Samsung HCN4226W 42" Rear Projection...
Screen is blank
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Nov 08, 2007 | Samsung HCN4226W 42" Rear Projection...
Red line fault
Aug 07, 2007 | Samsung HCN4226W 42" Rear Projection...
MY Samsung HCN4226W have perfect sound but no picture
I had the same experience with my set. I noticed there were 2 new cables attached to the new board and looking carefully noticed the connectors were different from the old. The new connector fit perfectly into the new board but wasnt the same as the old. I replaced the old cable with the new and the TV remained bad. I then flipped the connector to the main circuit board (bottom left) and the new board worked fine. I know nothing about Tv repair, but this new cable seems to be a universal connector in which the contacts are open on 2 sides...allowing them to be flipped if necessary. Now if I could get that solid line out of the display I'd be set!
Nov 05, 2006 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
89 people viewed this question
Jerry Greenberg
Jerry Greenberg
