Question about ASUS P5PE-VM Motherboard
CMOS Settings is Wrong! USB Device over Current Status Detected!
I have an Asus P5PE VM MoBo, when i starting up my pc, there is an error message appear
"CMOS Settings Wrong!
USB DEVICE OVER CURRENT STATUS DETECTED!
SYSTEM WILL SHUTDOWN AFTER 15 SECONDS!!"
>ive undergo everything...unhooked the front panel USB, dettached all connected devices,,clear the CMOS, change the CMOS battery, only 1 stick of RAM use,check the memory module, remove and reset memory module, ive checked the jumper settings, update the bios to latest version..ive checked already the MoBo if there is short circuit,,.nothings happen!!
even i dismantle all components from MoBo, theres nothing happen..Always the error pop up....
What should i do?Does anybody knows about this type of error?
Tnxs...
Heres my email jay_ar4@yahoo.com
    Brigadier General:
  • 6,966 Answers
It would seem that you posted twice, pls see you other post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 11, 2008
CMOS Settings is Wrong! USB Device over Current Status Detected! tried all references given here nothing happend, please help shreeramgodbole@gmail.com
Hi, you can download a manual and drivers here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Please select your operating system.
Download the asus update utility and upgrade the bios
its the easyest way to do that.
Unzip the file before you install it.
You can also reset the bios to factory settings.
Look in the manual how you do that and for troubleshooting also.
Aug 30, 2011 | ASUS P5PE-VM Motherboard
I have a Asus P5PE-VM. When i turn on PC it gives me following error and shuts down after 15 sec. Cannot even get into Bois. "USB device over current status detected"
Couple of things will cause this:
1] a problem with the front USB connectors - you can try just unplugging them from the motherboard and see if this will help
2] a short circuit caused by the metal raisers that is used to hold the motherboard in place - sometimes - just loosening the screws that holds the motherboard in place will do the trick, but if u have the patience, you can remove the motherboard and look for any place that the metal from the raisers that holds the motherboard in place is touching tracks on the motherboard.
3] I don't think i should have to mention this but of course, if you plugged something into the USB port that is drawing too much current - just remove it.
Feb 07, 2011 | ASUS P5PE-VM Motherboard
USB Over Current Status Detected, Computer will shut down in 15 seconds
this message popped up because one of the device which you connected to the usb of the pc was overdrawing current i.e more than 5V DC. Hence, the built in system security gave this message and will shut down your computer in 15 seconds. In order to avoid this message first remove all the usb items connected to it and then connect one by one and detect the faulty one and replace.
Jan 29, 2011 | ASUS P5PE-VM Motherboard
Usb device over current status detected shotdown in 15 second. cant acces the bios
Pull the little battery on the motherboard, and unplug the PC, let it sit for a minute or so. Put the battery back in and turn it on, BIOS should be reset.
Oct 01, 2009 | ASUS P5PE-VM Motherboard
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
CMOS CHECKSUM BAD USB DEVICE OVER CURRENT STATUS DETECTED SYSTEM WILL SHUT DOWN IN 15 SECS there is no shortcircuit in usb header 5v is ok i also upgrade bios but it did not solve this error
easy......cmos checksum bad =
dead battery ...buy a new cmos battery for £2 ..make sure you install correct way up...
from any pc shop or ebay...
you will have to reset date /time in bios afterwards...f2 or delete usually to enter bios settings..
regards tonster
Apr 05, 2009 | ASUS P5RD2-VM Motherboard
''CMOS Settings Wrong! USB DEVICE OVER CURRENT STATUS DETECTED
Have you checked all USB port sockets to see if any of them are broken? I mean inside the socket itself. It is easy to break the small plastic black tongue in these (e.g. by bending down on a USB memory stick. Then when you put another USB plug into it, the 4 contacts can get bent and the +5V will short out with the case.
Check all USB sockets.
Nov 11, 2008 | ASUS P5PE-VM Motherboard
Asus p5pe-vm
"USB +5v" = VCC
"USB_P5-" = -D
"USB_P5+" = +D
"GND" = GND
May 15, 2008 | ASUS P5PE-VM Motherboard
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
Motherboard related problem
you need to update your bios for the later stepping proceesors from asus, download to a floppy disc and insert before you start up your system http://support.asus.com/download/download.aspx?SLanguage=en-us
Jun 14, 2007 | ASUS P5PE-VM Motherboard
ASUS P5PE-VM Motherboard Logo
2,688 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
