Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite OASIS 27082 do not power up
Machine will not power up. There are no lights on. When I plugged the three-pin plug on the outlet, there is a spark.
  • 1 more comment
  • Anonymous Nov 23, 2008
    oasis he will not power up. outlet has power to it...??? Is there a reset button? a lid switch that will inactivate?...???
  • Anonymous Nov 24, 2008
    Started the machine up, started just fine, checked on it about 5 minutes later and now...nothing. No lights no power. Tried plugging into another outlet still nothing. Anyone know what to do?
    Thanks!
  • rme5280 Dec 18, 2008
    rme5280 fixed the problem by replacing the user interface board assemby as recommended in the service manual but did not work and finally made it work by replacing the machine/motor control board assembly.
The motherboard (controller) has died.
You will have to replace the motherboard.
This motherboard is the cause of the dreaded F1 error codes as well.
Look at some of the other posts here for F1 errors.
Posted on Dec 17, 2008
    Sergeant:
    Champion:
  • 324 Answers
Where is the spark? plug washer into another outlet to see if the machine works.
Posted on Nov 11, 2008
My kenmore elite oasis washing machine stopped mid wash there is no power at all. Model #110.28092700
first plug a lamp or something you know works into the outlet.if lamp does'nt work,check the breaker at breaker panel.If that is not tripped,it may be the onoff switch,or timer on machine.
Sep 27, 2014 | Kenmore Oasis HT High-Efficiency 4.6 cu....
Lid does not lock will not take cycle instructions
Kennmore Oasis washer; I just replaced the lid locking mechanism (8563937) with the upgrade (W10059230) from www.midwestapplianceparts.com
Jul 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Oasis HE 27082 Stainless Steel Top Load Washer: how do i soak whites in a kenmore elite oasis?...
There is not a program - you have to do it manually on this machine.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
The Kenmore Elite washing machine gets an F1 code on the digital readout then stops. Once the start and stop buttons are cycled a couple of times the machine starts running again.
Check to see if the screens for your hot and cold water connections are plugged with grit.
Or else the problem might be due to factory defect in the control circuit board of this washer.
Mar 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Elite Top Loading Washer with multiple errors
Yes - replace the ECU/Controller.
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
When I plug the machine in it either does nothing or flashes PF then acts as if there is no power. It is the machine not the outlet.
PF just means your house has experienced a power failure since you last used the machine.
Unplug it for 40 minutes to reset.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis washer will not turn on
I have the same problem. I used the unit 2 days ago and no problems- just bragged about the unit yesterday and now today it will not turn on and it is no longer under warranty. I also checked to see if power to plug and it is fine. Any suggestions?
Aug 01, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis washing machine is completely dead
discconect power for about 10 minutes,, then plug it back in should fix if not call repair possible control board failure ,,,,,,
Jul 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
236 people viewed this question
Sal De
fordexpert
Robert Rankin
