Question about Boss RT-735 Car Audio Amplifier
Amlifer wont turn on
I have a boss rt-735 i just got from a friend and it wont turn on. i had an amp installed before and it worked no probelm. all wires and fuses are good could the amp be fried
    Problem Solver:
  • 15 Answers
Some amp has glass or plastic fuses along with a pic fuse a little green tear drop shape fuse on the board that plugs in like a fuse, see if yours has one of them if not then I'm sorry your unit is bad.
Posted on Nov 06, 2006
2017 Harley Davidson Road King Base Boss Audio Amplifier keeps blowing the inline fuse
Hi, Erik I suggest you follow the wiring directions that came with the kit, for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Boss MC600B System install
2017 Harley Touring Service Manual pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
2017 Harley FLHRI Owners Manual
Instant Tech Relief To speak to me personally for only a mere $6
May 18, 2018 | 2017 Harley Davidson Road King Base
My Dewalt 735 planer won't turn on. I blew the house fuse a few times, it would start after I came out. Now it won't start at all and it's been a couple days
The 735 draws 15 amps, which is the rating of typical lighting circuits in homes. The receptical in the wall is sometimes 15 amps although those circuits usually have 20 amp breakers. Since you said "fuse", it might be a bad fuse or even the wiring between the two. Circuit breakers go bad also. If you can confirm the receptical supplies voltage, it is time to check the 735.
Unknown if the device has a termal switch inside. I doubt it would go bad, but you implied a resting period allowed it to run several more times after the fuse in the basement was replaced. If it reset once, it should do it again. If you can find a diagram, there might be a fuse inside, but someone would have to take it apart to check.
A motor can get so hot that a solder joint inside can let loose and it will never run again. Sometimes the coil (windings of the motor) can short out (melt together) and this will increase how much current goes through it and also generate more heat and melt more windings together. Besides producing a smell, your house fuse would burn out real quick.
I had a chuckle over your 2nd sentence but I dare not say why. If it started after you came out (of the house), why did you not run it for a longer time?
A motor requires more power at the instant of turn on. 15 amps of running current will require 20 amps or more when starting. "slow blow" fuses (vs quick action) and circuit breakers can deal with the short period over current requirements.
Nov 23, 2015 | Dewalt Planer (DW734)
I just installed boss bv7340 in my car and it wont turn on i checked the ingition wire and ground to see if i was get 12 volts and i was i dont understand
From what ive seen alot of boss audio equipment are defect. You can try checking the fuses and if not return it and get another. Or another way is connecting it straight too the battery of your car (red and yellow together/positive) (black/ground) if it deos not turn on its your stereo.
Sep 10, 2011 | BOSS AUDIO SYSTEMS BV7340 Car Video Player
My amp still gets power but it wont turn on. i hook it up and it gives me a small spark but then the wires begin to get hot. it was working fine the other day and now idk whats up
the remote cable may be grounded. Check the power wires and you should have a fuse near the battery so make sure its not blown. Also check for blown fuses on the amp.
May 21, 2011 | BOSS AUDIO SYSTEMS CH700 Car Amp
I have a boss rt645 2ch 1400 watt amp would this amp properly push a pair of 12 inch mtx terminators.
That all depends on the wattage of the subs. also the independance of the subs. If your amp is 1400 watt, maximum you want is 2 600watt subs. if your subs are higher you will blow your amp eventually as your amp isnt powerful enough to pump out to that level.You should never have your amp fully turned up to max, 80% is perfect and will not make your amp blow. Hense why you want your subs less than the max output of your amp.
Mar 04, 2011 | Boss AUDIO RT-645 2-Channel Riot Series...
Won't work it's all hooked up right and the sub appears to look fine but it won't cut on
Check the power to the amp and work your way back to the subs. Also make sure the wires from the amp to the speakers are connected properly?
Sep 19, 2010 | Boss RT-125 Car Subwoofer
My red light on my 1000w amp wont turn on to power my subs. the blue one is the one one to turn on can anyone help me
make sure that you have a good ground, make sure you have the right amp turn on wire, and your power wire is fused, best solution is to have it professionally installed! Amp install is very basic if you are having a hard time with that, I wouldn't attempt to try it or have one of your buddies install it! FRIENDS DONT LET FRIENDS INSTALL!
Sep 11, 2010 | Kenwood KAC-7203 Car Amp
Car amp smokes when ground wire is installed?
Chances are the amp was wired up wrong and you hook up the ground you are allowing an already damaged amp fry.
Jul 30, 2010 | Boss RT-1035 Car Audio Amplifier
Boss RT-735 Car Audio Amplifier Logo
190 people viewed this question
Top Boss Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Philip Armitage
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
