Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sound went out in the sharp tv we have
We had the cable company check everything out related to cable and everything checked oout he said it was in the tv, and we cannot find the manual for problems related to the sound. can you give me any ideas of what to check it is only 2 years old
vickie gildes
  • Any Guy
    Any Guy May 11, 2010
    Is the TV connected to the cable box with an HDMI cable?
    Problem Solver:
  • 17 Answers
If you had sound from the onboard speakers before and lost it (without changing any settings), then try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service (1-800-237-4277) and tell them that you already did the resets. There is a known problem with a heat dissipation pad for the onboard speakers and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case with my LC-32D6U.
Posted on Aug 23, 2009
  • 106 Answers
I have fixed several of these. The problem is the main board will have to be removed to access the audio amplifier. A qualified technichian should only attempt this due to the location of the main board.
Posted on Nov 26, 2008
Sound on Tv is turning on by itself
It (or something connected to it) is checking for firmware updates. Check the menu settings. Also check any device connected via scart to the TV.
Mar 13, 2014 | Televison & Video
The sound went out on My 3 year old 40 inch sharp aqous
have you been check the speaker if worn out. if ok you can hooked up a powered pc speaker at the audio output jack of the tv . now if you can get sound there the cause it could be bad amplifier circuit. but if you can not get sound there the cause would be bad sound processor in the main board.
Sep 30, 2012 | Sharp 32L-S400 32" TV
Sharp flat tv lc-32sb24u no audio was watching tv last night and the sound just stopped in the middle of a show. picture is perfect. is it worth to fix.
Sir try to check the cables connection at the back of your tv. and if you are using a digital receiver, try to use a dvd to check if there is a sound. If there is a sound the problem is the digital receiver, feel free to send feed back good day and best regards.
Aug 16, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Sharp TV-Remote not working correctly
You will need to complete a channel scan from the tvs menu. I assume you have basic cable and that your cable company is still providing analog channels for you to be able to pick up any transmission on this telvision with the digital changeover and all.
May 05, 2010 | Sharp 27C-240 27" TV
Code says check connections or power. RGBHV or YPrPb may be inval
Dunno. But if the tv has been 'reset' you will need to re-assign all devices (via NetCommand). Also complete the setup again to verify audio & video selections. If you can select "video" on the remote, you should see various video options...including brightness, etc. If need to get the right device assigned to the TV for viewing from cable box.
Apr 14, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Picture fine for 10min.-then flickers(clicking sound)& then colors gone yellow
Looks like it's a color wheel problem-found a cleaning walkthru online, but it doesn't get rid of the loud hum form the CW motor. Also, it is thermal related-when the colors went out I placed a fan next to the color wheel and everything went back to normal. Several design flaws here and for $3000 these companies should do better-severe problems after a couple years is not acceptable.
Oct 26, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
88 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
