Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Blue spot I have just noticed that I have a faint blue spot slightly offset from the center of the screen. It is about 8 inches long and six inches wide. Any info on what the problem is would be appreciated. The tv is 1.5 years old.
  • 65 Answers
Light engine period
Posted on Dec 09, 2006
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Blue spot on screen center. Peoples faces and show blue tint
if you have a Sony LCD projection ..Theres good chance optical block needs replacing .This spot will get bigger and will eventually cover most of screen the longer you use it .needs repair.If there is no warranty on this unit..I would estimate repair around 6- 8 hundred dollars ..
Aug 06, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a Hitachi model 50V69A and have large yellowish spots on screen. It is most noticeable when watching programs with light background, like hockey games..
I havw a simialr problem mine is a blue stripe toward the center of the screen. The problem is most likely from the blue lens on mine or the yellow on yours. I was able to adjust it out somewhat and I am still tweaking it by using a setting in the technical menu called stripe.
You can access the technical menu by pressing the fowllowing on your remote:
MENU +MENU+ 8 + SELECT
Hope this helps
Jul 02, 2009 | Hitachi Televison & Video
Blue spot on my hitachi 50"rear projection tv model 2006 50vs69a
Do you have a center speaker near it? maybe move it, that is what I have done and it seems to have gotten better.
Jun 09, 2009 | Hitachi 50VS69 50" Projection HDTV
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
Screen appears blue
Try Moving The Speaker You Have There Away From It?
www.Myspace.com/CrossRoadsToNowhere2007
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
Curved blue lines on screen.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Zenith M52W56LCD blue spot in center of screen
It could be as simple as dust contamination in the LE or lcd chip. You need a clean room to work on this area of the unit and NOTHING you can do there would make that possible, short of spending a few thousand to build one. Before we added a clean room enviroment we simply pulled the LE and sent it in to PTS - who has one and reinstalled...
In your case take it to a qualified shop and you'll save yourself a lot of grief..
Bill
Nov 19, 2007 | Zenith D52WLCD 52" Rear Projection...
Blue Spot in top center of screen
same problem, guy said i need a COLOR DRIVE!! $1000, trying to find cheaper
Jan 07, 2007 | Hitachi 60V500 60" Rear Projection...
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
145 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
