Question about Cobra 29 LTD CB Radio
Cobra 29 ltd classic
I had this radio given to me, it does not turn on. i took my test light and check the internals of the radio and got power inside the radio. i then went on the the next step and replaced d 23 so im lost and would like some guidance. help please thank you jon
  • 1 more comment
  • magnum383 May 11, 2010
    Are you using a 12 volt test light to probe around the inside of your radio? IE the same type you would use to test your trailer wiring on?
  • Don Reiman May 11, 2010
    I could still have power in some parts of the radio if only the diode on the neg side went if he has the antenna connected and is grounded to the vehicle if he his checking this inside his vehicle.
    Is this being checked without the antenna wire connected.
  • Goober Pyle May 11, 2010
    If you have power inside then the polarity diode would be ok and not shorted. Did you check for power at the front panel power "on" switch? +12v in and +12v out when on?
  • 20 Answers
Hi there!
These repairs can be a little tricky to fix with out seeing the radio and the right equipment. Try replacing also D8 and or C123in between both diodes but first make sure on the other side of the trace side there are no burned out traces and they all look good. These traces can have a very small crack that you cant see with the naked eye so use a good magnified glass. Also is is there any lights on at all on the radio when you plug it in?? Because some times TR23 will go out and the radio wont come on but there will still be a meter light or green RX light!! Hope this helps a little let us know if you have other questions!!
Posted on Aug 29, 2009
How to fix the dimmer light ona cobra 29 nw ltd classic
Feb 04, 2011 | Cobra 29 LTD CB Radio
29 ltd classic wont transmit
Great radio when it works.
If you have your settings on CB - not PA - -be sure that your Cobra has that setting selected.
If CB -is selected and still nothing - be sure you have a working mic. These wires are fragile and can break internally. One easy way to check is to borrow a cobra mic or even drop by a CB repair shop and ask them to do a mic check with the mic - it is free.
If you have a bad mic replace it and all should be well.
If your mic is good and it still doesn't transmit you will need to replace the finals in the unit. It is common that these burn out of you got too close to someone with too powerful a radio. The CB shop will need to look at it further and repairs should not be over about 40.00.
Good luck with your Cobra.
Mar 31, 2010 | Cobra 29 LTD CB Radio
I have a Cobra 29 NW LTD Classic I have power going to radio but no power when i turn on knob. i have looked inside for a fuse but can not find one.
did you look for power comming out of your power switch....
dont tell me that you hooked it up backwards. if you did check the imput diodes
Aug 29, 2009 | Cobra 29 LTD CB Radio
Cobra 29 LTD Bluetooth
You got your radio peaked? Most likely, however, the pot for the antenna warning indicator is VR6. I always check that after peaking a radio.
Jul 28, 2009 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic not transmitting or receiving
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
Dec 05, 2008 | Cobra 29 LTD CB Radio
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
Cobra 29 issues
Check D23 and D28. They are polarity protection diodes. It could also be the power knob.
Nov 09, 2008 | Cobra 29 LTD CB Radio
Cobra 29 Ltd
Appreciate the direct "Ask Me" again.
The initial posting would still hold true, best would be:
  • remove TR18;
  • replace 2SC2069 with 2SC1969; and
  • adjust L12, 13 & 14.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 07, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
181 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
