Question about Philips Magnavox 20MT133S 20" TV
Slanted picture i just bought this tv and noticed that when i watched a movie that was letterboxed that the whole picture was slanted diagonally downwards to the left. just a few degrees, but noticeable enough to chop off text that should have been in the lower left hand corner. is this something i could fix, or should i just return it.
    Novelist:
    Champion:
  • 236 Answers
Your deflection yoke (a coil around the neck of the picture tube) must have gotten turned. Your can turn the picture upside down by rotating this coil. If your set is in warranty, you should return it. When this "yoke" is adjusted the color is affected too. If you try this yourself you'd void the warranty and mess up your color. Stargazer
Posted on Jan 28, 2007
SOURCE:
Using standard on tv remote and normal on cable remote both settings crop the edge of the picture
TVs that use cathode ray tube (CRT) cannot display the correct aspect ratio for movies and modern TV broadcasts unless it is in letterbox form. Unfortunately most of the older CRT TVs do not have a letterbox setting.
Dec 08, 2014 | Televison & Video
Why are the movies half screen?
Movies that are created for "Wide Screen" viewing show up in letterbox on your TV. If you go to a theatre you notice it is a big rectangle. To be able to fit all of the widescreen movie on a TV it has to make the height smaller.
Because many people want to see the "complete" Movie, the "Letterbox Format" came about. I do NOT know what the word "Letterbox" actually means, or how that term was chosen. To get the complete Rectangle into that Square, they discovered that they could shrink the entire rectangle to fit that square. Meaning, what used to take 2 inches on your screen, now may only take 1.75 inches. Now a problem arrose. When you shrink the WIDTH to fit your dinky Square of a TV, the HEIGHT also has to be shrunk along with it, or else you're stretching the image as if it was on silly-putty ("Compression"). When the image was shrunk to fit the TV Screen, they were left with a gap at the top and bottom of the screen. So they simply fill it in with "Black". I guess the only alternative was to leave it snowy.
Nov 13, 2014 | Televison & Video
Some shows i don't get full screen picture about
You are watching a show or movie that was recorded in letterbox format, THIS IS NORMAL !
Jul 09, 2011 | Polaroid Televison & Video
I cant get the whole picture to fit the screen. When I watch games the score is cut off.
This is most likely a setting on your TV, like stretch, or fit, or possibly on your cable box, or dish receiver. look at your dish or cable box settings and turn off any screen adjustments. Example under wide screen setting is strech , zoom, letterbox (choose letterbox).
The TV has these settings as well.
Aug 24, 2009 | Samsung LN46B650 46/49.5 in. LCD HDTV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Letter box picture when viewing blue ray discs on Sony BR player
All blu-ray movies are in Widescreen format. So your tv converts the picture to make it look like letterbox. There will be some movies that will have those little black bars at the bottom. There will be some movies that don't. There is nothing to worry about it is normall.
Hope this helps
Jan 08, 2009 | Sony BDP-S350 Blu-Ray Player
Wide screen lcd simple question.
Hi pooing stone,
You may sometimes find that even with a television referred to as “widescreen,” widescreen movies still have letterboxing.
This is likely because the movie you are playing is still in the ratio used at a theater. While most televisions are 4:3 for the more square-type or 16:9 for widescreen, a theater screen is much wider still. Unless the movie has been reformatted specifically to 16:9 for your television, you will either see letterboxing or lose portions of the picture by zooming in.
If a movie is available in several ratios, I suggest thinking of all the options before buying. Although purchasing a movie reformatted to 16:9 will prevent the black bars, purchasing it without any reformatting of the size will prevent you losing part of the picture.
FYI: It is very common with Blu-Ray Discs that widescreen means original size, not 16:9.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 03, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
ILo-26HD Tv
take your set to a tech you are having problem in your vertical output circuit.leaky filter or coupling capacitor,or defective B+ regulator transistor or IC .buffer transistor or IC,or supply resistor, they need to be replace.good luck
Mar 26, 2007 | iLO 2600 Television
Slanted picture
THENION-IF YOU CAN GET FRONT SPEAKER GRILL OFF AND REMOVE THE 4 SCREWS TO GAIN ACCESS TO FRONT ENGINE YOU SHOULD BE ABE TO USE A SCREWDRIVER TO SHIFT ENGINE APPROPRIATELY.JOE TV
Jan 08, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Philips Magnavox 20MT133S 20" TV Logo
93 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
