Question about Sansui HDLCD3200 TV
Diagonal lines i need a manual for a sansuihdlcd3210 tv. why do we have diagonal lines on the lower channels.I have tried all the connections and none are loose?
If the diagonal lines are not on all your channels, the most likely problem is with your cable signal coming into your home. Contact your cable supplier.
Posted on Feb 05, 2009
I WANT CODES SO THAT COULD LINK MY DVD USING THE REMOTE.
Posted on Nov 26, 2008
I bought the Sentry RMC10 Big Universal remote, but I lost the manual. I am not able search code for a Sanyo plat panel tv, Model DP26640-26" Diagonal LCDHDTV
The codes for Sanyo TVs are as follows.
  • 004
  • 013
  • 049
  • 108
  • 110
  • 180
  • 209
If none of them work, you can try the manual code search feature.
MANUAL CODE SEARCH:
If your product does not respond after you have tried all the codes for your brand, or if
your brand is not listed, try searching for your code by following these steps:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then
release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red Indicator
blinks off once.
4. Face the remote control directly to the device you want to control (TV, VCR etc).
5. Press the ON/OFF button repeatedly (up to 300 times) until the device to be
controlled changes channel. The red indicator blinks off with each button press.
6. Press and release ENTER to install the code.
Nov 28, 2013 | Sanyo Televison & Video
Just got an antenna to pick up local HDTV channels. I scan the channels and none are found. does it matter if I connect to "Ant1" or "Ant2"? neither seem to work. Thanks.
According to the user's manual on page 16, press Menu and open the Setup menu. Highlight Installation and press Enter. Open the Terrestrial menu and highlight Input Configuration. Select the ANT1 or ANT2 (whichever the antenna is connected to) and select input source Antenna [not cable]. Highlight Done and press enter. Now rescan your channels. If you still get nothing, try relocating your antenna to a better place. Digital TV is highly dependent on line of site signals. So if you are in a mountainous region or surrounded by a lot of high rise buildings, you may not receive a good enough signal to register channels on your TV.
Feb 06, 2010 | Toshiba 56HM66 56" Projection HDTV
Diagonal stripes on Television can it be repaired
Yes. You are losing a capacitor in the vertical hold circuit. Once replaced the lines should disappear.
Sep 12, 2009 | RCA TruFlat 27F520T 27" TV
Mitsubishi diva cant tune in
well .... no online user manuals for thoseTVs
you will need to use a digital seck top box and use that units remote to tune the TV
if there are any (needs a user manaual)
use the buttons on the TV lower casing
to tune up
none of the all in ones remote buttons work for all TVs functions
you are lucky if it turns on and off
and changes channel
Apr 29, 2017 | Mitsubishi VS-45609 TV
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
Video channel has diagonal lines
check the connections from your video to your tv, sounds like you have a loose wire,
If not re-tune your tv , it might have lost the tuning a bit , but its probably a loose connection
Feb 28, 2008 | Televison & Video
Input for cable
Most tv's dont need to be on an input for cable. Just channel up and down or change from LIne1 or Input1 to TV or CATV.
Dec 10, 2007 | Televison & Video
Diagnal Interference Lines
the diagonal lines represent some low frequency interference (close to the supply frequency - 60 hz). Try to keep the unit away from other appliances, especially the left back zone - where the tuner is. Also, you have to do some experiments on the cable connections: disconnect other cable devices (internet modem, home phone, other tv/tuners), one of them might inject these signals into the cable. Keep me posted
Aug 25, 2006 | Toshiba DR4 DVD Recorder
Sansui HDLCD3200 TV Logo
251 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
