Alpine CDA-7865R won't play CD and won't eject it either.
  • Terry Rodgers Jr.
    Terry Rodgers Jr. May 11, 2010
    what is it telling you on the display(generaly this will give you a problem code,or at least give me a starting point.a little more imfo will go a long way.(such as when did you use it last,when did it start acting up,was it doing this every once & awhile then suddenly all the time ect.....)i mean if someone stuck a peanutbutter waffle in it,i need to know(just joshing you)ha ha ha.our answers are based totally on the imformation you give us.the more imfo you give us the better we can help you.thanx for using FIX-YA.
On the face, where the buttons are that control the tilt of the face there is a small reset button (In between). I pressed this whilst the unit was off, and when I switched it on again, the CD started playing but I couldn't tilt the face and eject the CD, so I hit the reset button again and it all worked!
Regards,
Posted on Nov 11, 2008
My Alpine cd receiver CDA 7837 wont play any music discs i burn. ive tried using nero which automatically converts them to cda but it wont play them it just ejects the disc. it works when i put it in my...
You may want to try a different brand of blank cds. I had an alpine that would not play sony white label cds, but played most everything else.
Aug 30, 2011 | Alpine CDM-7833
There is a cd stuck in the deck. It wnot eject and won't read. How can I get it out?
the best way to get it out is to take the deck apart if you can see th cd try tweezers or needle nose id bet there is more than one in it i hope this helps
Jul 04, 2011 | Alpine CDA-9857 CD Player
Alpine cda-7838 loads cd but then immediately ejects it
Try using a CD-AUTO Automobile Lens Cleaner kit. Keep in mind you pay for what you get. Try using a name brand cleaning kit.
Hope this helps, don't forget to vote.
Nov 16, 2010 | Alpine CDA-7838
Cd wont play or eject but button beeps when i hit eject
try disconnecting power to the radio for a few minutes.
Jun 24, 2010 | Alpine CDA-9885 CD Player
I got a Alpine cda-9851 cd player today. I popped the face plate off to see where the cd goes in, but theres not a slot for it! Do i have to have a 6 disk changer for it?
this is a motorized deck. just press the eject button and it should open. the eject button should be on the lower right hand corner of the face.
Dec 10, 2009 | Alpine CDA-9851 CD Player
I have an alpine cda-9883 cd won't eject & error
try detaching the "face" and there should be a little button that you can only push in with some kid of really thin stick,maybe a pin that will reset the cd player and hopefully work
Oct 27, 2009 | Alpine CDA-9883 CD Player
Hold is on and nothing will will work how do i turn off hold on a alpine cda-7892 cd player
Try resetting it. Also if it won't reset using the reset button found behind the faceplate. Take off the negative battery cable under the hood this should reset everthing. Then replace it. If it is old and the motor is having trouble kicking the cd out then stick a used no good cd in on top of the other cd and use it to apply pressure to the cd in the player then pull it out after pressing eject
May 31, 2009 | Car Audio & Video
Stuck cd
press & hold the eject button
Feb 07, 2009 | Alpine CDA-7863 CD Player
135 people viewed this question
 Grubhead
Grubhead
