Question about Kenmore 72802 Gas Dryer
Kenmore gas dryer
The bulb lens cover is broken on kenmore model # 11097292100---need too replace it--ty
  • 5,911 Answers
If you are talking about the drum bulb, the lens is available at Just go to the website and type in the model number you provided. Look under the "Bulkhead" heading on the next page for item number 35 (part #3395196). The part costs about $7. I hope this helps you. Let me know if you require additional assistance. NOTE: If this is NOT the item in question, please post back and let me know.
PS You may consider item number 11 (part #309100) as well if the mounting screw has been lost.
Posted on Nov 11, 2008
How do I change the light in gas dryer
there is likely an access spot on the back of the dryer that allows you to change the bulb without taking the entire dryer apart. the most you may need to do is remove the back panel of the dryer to access the light socket. it should either pop out with a clip or twist out 1/4 turn like the headlamps of most cars then you can replace it with a high temp appliance bulb as they last longer than standard bulbs
Nov 12, 2014 | Kenmore 74602 Gas Dryer
I have gas dryer, model SDG4606, and the light inside drum does not work. How do I replace it?
When you open the door on your dryer your light bulb is located at the top of the opening. There will be a clear plastic cover over it that is held in place by one screw. Remove the screw and allow the cover to hinge away from the opening. The bulb is Maytag part number 67001316.
Sep 17, 2010 | Maytag SDG4606A Gas Dryer
Need to replace the tail light cover for Chrysler 300, driver side. Bulbs are ok. Clear part of cover assembly is broken. How do I do that?
Generally, the cover, lens, and reflector assembly are all one piece (glued together) and you must replace the entire assembly. I would check with an auto recycler (junkyard) for this, as I'm sure the dealer wants a small fortune for it.
If you open the trunk and (if needed) remove the liner, as if you are going to replace the bulbs, you will be able to see the fasteners around the perimeter of the reflector. They may be screws, they may be some kind of clip or push-pull fastener, depends on the model. Remove all the bulb sockets (label them for the correct position) then remove the fasteners, remove the lens assembly (usually pushes out toward the back of the car), then reverse to install the new one.
You may need some sealant around the perimeter of the lens assembly (to keep water out of the trunk), you can use kitchen and bath silicone caulk.
Sep 05, 2010 | 2006 Chrysler 300
Light inside dryer does not light up.
Your bulb has burnt out. Go to put in your model number, in schematics on left side of page select #5 tumbler, bulb is part #7 cost $5.60. easy to replace, you just have to remove lens cover and replace bulb.
Aug 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Light in tumbler not working Model SDE4606AYW, can I change it?
You can indeed replace the cylinder lamp (part number 67001316). Disconnect power to the dryer and open the loading door. Remove the screws securing the lens cover to the bulkhead and remove the bulb by unscrewing it counterclockwise. Install the replacement bulb then secure the lens cover back into position to the bulkhead.
May 24, 2010 | Dryers
Replacing coils on a dryer
Their are 2 screws to remove and the cover comes off and then those coild simply slip off, unplug em no wiring to do. Thats the cover to the left and the 2 screws.b44bc92.jpg
May 21, 2010 | Kenmore Dryers
Kenmore gas dryer problem need help please
hope this help U
was this helpful?
May 11, 2009 | Dryers
Belt replacement
Take the belt with you to an appliance store and they will match it up. Much like a fan belt on a car. You won't necessarily need the model if you have the belt. Next, it sounds like your assembly is broken. If this assembly looks to be in pieces, you may need a new one.
Feb 03, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at
Oct 20, 2007 | Dryers
Kenmore 72802 Gas Dryer Logo
55 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
