Question about Sharp LC-26D6U 26 in. LCD Television
LC26D6U Sharp Aquos Audio Problem
I am having the sound problem on this LCD TV and wanted to know if you have found the fix.I read that you thought it was the capacitors and wanted to know if that was the answer .If you can help that would be great.
  • 16 Answers
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the
PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ‘2502 Heat Kit’ is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from circuitcity.partsearch.com for $19.95. However, it’s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. Please note that board replacement for this problem is almost never necessary, so if you’re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with
electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ‘important service references’ by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ‘buried’ under other boards. Please refer to post # 373 at avsforum.com/avs-vb/showthread.php?t=647174&page=13 for pics of the information detailed here.
My knowledge of how to solve this issue came primarily from finding the research efforts of ‘Aureius’ on the AVS forums, and particularly from his taking the time to post the solution publicly so that others might save time, money, and aggravation. I'm just passing along the information. Thanks Andy!
I also wanted to mention that a couple of other very pesky common problems with these series of Sharp TV's involving symptoms of random powering-off and/or powering-on, and 'function lock-ups' of various sorts are easily remedied through two firmware updates (Main CPU: PH1UU112, Monitor: MD1UA104). These are not available to end-users via the internet but it may be possible to get the files from an understanding factory-authorized repair tech. They are installed using an SD memory card (don't use the HC high capacity sort, use only those that are NOT HC) which is inserted into a special slot in the back of the machine. For those of the DIY persuasion, information about how to check whether your TV has old firmware in need of an upgrade is readily available through internet search.
Posted on Feb 16, 2009
Whoever posted this info is awesome, the link info in the above paragragh led me to the additional info and pictures necessary to have a quicker solution and trouble shooting rally to the end result which is a working tv with sound. thank you guys out there who help guys like me who are ready and willing, but untrained in such repairs.
Posted on Feb 22, 2010
Sharp aquos dolby digital tv has sound but no picture
go to source on your remote then click down to the second one like HD ONE.
Feb 21, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp Aquos LC-26D4U sound problem
Yes this is a common problem. You have to have it refered to a TV SHOP. I can fix it for you but in CA. the wiring on the speakers needs to be upgraded to a thicker wire. The gauge is to small for the current needed to flow evenly.
$75.00 Fix
Feb 13, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Nov 24, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
I'm trying to hook up a sharp aquos tv to an rca surround sound receiver and it won't work? any suggestions? I have tried turning off the speakers on the tv....
First thing to do is get the owner manual for each and start checking both settings and actual hookup---usually a surround system will work on all types of sets---when in doubt read the owner manuals.
If need either manual Google that model number with "manual" to try to locate it.
As far as the set goes it may require either a variable audio output source or in some cases the out to be a fixed level.
May 23, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC46lE700UN How do I adjust the audio. Manual says that the Output Select to Fixed, but it still does not allow me to adjust the audio
If the RCA audio out put is set to 'FIXED' it means the signal at the RCA jacks will not be controlled by the Volume control of the TV, but the TV speakers will still be controlled by the TV volume control, if you want to make the RCA AUDIO out to be adjustable by the TV volume control, you will have to set it to 'VARIABLE'.
Nov 03, 2009 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
Picture but no sound
main pcb needs to be cleaned were audio ic is. there is black gunk
Jun 01, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Mar 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Audio Problems with Sharp Aquos T. V.
Just talked to a fellow at Audiotronics regarding Sharp Aquos.
This is a widespread problem with audio on their TV's, The tech. said there may be a full recall regarding this problem!!!
Nov 10, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp LC-26D6U 26 in. LCD Television Logo
778 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
