Question about Samsung Televison & Video
Have sound no menu no piture
Power button flash 4 times
  • 3 Answers
It has a card in it for the screen myen came lose some how titend it up and fixed it it is the thing the coax cable plugs in to cable tv
Posted on Nov 11, 2008
MATTEL POCKET UNO GAME INSTRUCTIONS (how to change the number of players)
Here is the information you requested:
GAME OPTIONS The default options for Electronic UNO® are a Level 1, 4-player game with the sound on. If you want to change those options, this is how you do it:
1. Press the Menu button and "New Game" will flash. Press the Select button and "New Game" will stop flashing-Press again and it will go out. If you press Enter/Play with "New Game" showing you will start a new game.
2. Press the Select button then press Enter/Play. The Player 1 icon will flash.
3. Press the Select button to cycle through the number of players, represented by the 2, 3, or 4 icons, and press enter when you choose the number of players you want.
4. After the number of players is selected the, Level will begin to flash. You may change the level by using the Select button to cycle through Levels I, II or III. When you see the level you want, press the Enter/Play button.
5. Once you have selected the level, you will see the musical note icon flashing. This is the sound indicator. You may turn the sound off or on by using the Select button to make the note appear or disappear and then press the Enter/Play button. If you can see the musical note the sound is on. The Hi Score will be displayed and the player that achieved it. Press Enter/Play to start or return to your game.
6. You may start a new game, check the Hi Score or turn the sound on or off at any time by hitting the Menu button.
Jul 15, 2017 | Mattel Toys
Menu pops on and off for about a minute when i first turn the tv on
the self diadnostic program in the tv is going bad.. may be time to replace the tv or dont shut it off completely
Jan 21, 2014 | Samsung LNT4665F 46inch 1080p LCD HDTV
The power on no piture
If the power light comes on (green) for a few seconds and goes off:
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Nov 06, 2012 | Mitsubishi WS-73713 73" Rear Projection...
I have a flashing orange light and cant find the manual, I have changed the inks but its still flashing?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Dec 02, 2010 | Canon Office Equipment & Supplies
Power button flashing on and off. Maintanence light is on and there is an E, 2, and 4 flashing in the print screen. What do I do? Pleas help!
MP160 resetting errors
button pressing
procedures below.
procedures below.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 20, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Mitsubishi projection tv picture and sound turn off but the power button remains on with no picture or sound turn tv off real quick and then back on and works for 2 mins then turns off again what could be...
Here's the basic troubleshooting:
  1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
  2. Disconnect ALL devices from the TV.
  3. Press the SYSTEM RESET button and hold for 10 seconds. Proceed if the problem still exist.
  4. Press and hold POWER and MENU buttons simultaneously for 20 seconds. Proceed if the problem still exist.
  5. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours.
  6. If it still shuts down, press the DEVICE and MENU buttons on the front panel simultaneously and hold it for 5 seconds to activate the Error Code Operational Check. The status LED indicator will then flash denoting a two digit code.
  7. Count the number of flashes then pauses for about a half second then flashes again. The first number of flashes indicates the first digit of the error code and the second number of flashes indicates the second digit of the code. For example, if the error code is "35", the LED will flash 3 times, pauses, then flashes 5 times. The error code is repeated a total of 5 times.
Please let me know the code you got and I'll tell where the problem lies and how to fix it.
Dec 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
It keeps flashing E and then 3. what do I do?
MP150/160 resetting errors
Do it : 3 times Orange EEPROM reset
button pressing
procedures below.
procedures below.
Sep 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Changed ink jets alarm flashing number 5800 showing
Hello Saron Girl,
its not 5800 its 5B00
7 times LED Blink Waste ink absorber full [5B00] - Ink absorber (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257)
<Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
4 times LED Green Waste ink counter resetting
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
Regards,
May 14, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Televison & Video Logo
46 people viewed this question
Henry  Thomas
Henry Thomas
