With broadband connected I can't hear a thing on the phone. We get lots of static, voices are very quiet. I have a phone line splitter on the line.
  • 35 Answers
If you have DSL for your broadband connection, you need a filter on every phone jack. These filters are provided by your DSL provider
Posted on Nov 11, 2008
Can you set up a zte720 wireless home phone to a Motorola NVG589 U Verse wireless router for Boardband service?
There is no port for broadband(RJ45) output in ZTE720 so if your phone line terminates at ZTE720 then Motorola cannot be connected to it.
On the other hand if you terminate the your phone connection at Motorola NVG589 then you will get broadband and no output to connect to a phone line.
However there is a way and that is the phone line coming to your home can be connected to a splitter (it has one input and 2 outputs, one for phone(ZTE720) and other for router(MotorolaNVG589)).
Splitter will provide output for both devices and they can work simultaneously.
Your connection.
Phone line coming from outside-----splitter------ZTEwirelessphone
Motorola ADSL2+ router
Jul 25, 2014 | Computers & Internet
RE : Panasonic KX-TG6461 I installed this phone
thats an hardware fail , you need a service shop to fix it
Sep 13, 2013 | Panasonic KX-TG6461ET DECT Corded and...
Buzzing on phones
Maybe your modem is too weak. Contact provider immediately!
Mar 16, 2013 | Arris Comcast Touchstone Telephony VOIP...
Bt hub 2.0, the internet light is red, but the telephone line works, although it's very noisy/crackly. have changed the micro filters but still cannot connect to the internet.
It sounds like you have a fault on your phone line which is affecting the performance of your broadband.
As long as you haven't added any more phones to your house without a splitter, then I would go with the problem being your phone line.
You might want to give BT Broadband (assuming you have BT broadband with the BT Hub) on 0800 111 4567 they will be able to advise you further, failing that, you may need to log a call with BT about the phone line itself, which is just 151 from the line that you are having problems with. It is always best to phone from the line that you are having problems with, so they can hear that there are problems with the line.
Hope that this information helps! :)
Nov 08, 2010 | Computers & Internet
Hi I have a laptop of Dell & i have a phone of Samsung Mode GT-C3053 Handset GPRS Compatible I want to connect my phone to laptop for using internet Can you have any solution
Are you hooked up to the net through your phone company? If so, all you need to do is plug a phone cord into the right place on the PC, & be sure to hook up a filter they sent you from the company, if there will be phones hooked up to the same line. If you have a line dedicated ONLY for internet use, just plug in the cord, run the disk they sent you, & you're set. Do you have dialup or broadband? That also makes a difference. Dialup you can do the above & add a phone running from PC also, np. BUT if you have broadband & you want to have a phone & PC hooked up to same line, you want the phone to come off a line BEFORE it gets to the PC, as the filter thing is important. Put filter on the phone line. If you have broadband & a phone that runs off line from PC, you will hear horrible sounds louder than voices on the phone. Ask my ears, I tried that. :) If all that doesn't help, ask again & tell us lots more about it, OK? :) More info helps a lot.
Sep 18, 2010 | Samsung Computers & Internet
Constant static and noise on the cordless, have not had this problem with other phones in the same location. I have tried the frequency scan- no difference. The noise is so bad the cordless cannot be used.
The main causes of Hissing Noise on phone line
* Weather:
Precipitation can leak into phone lines and cause disruptions. Lightning, even at a distance, can damage the connection.
Checked the connections the cable and the Sockets
If you have the Test socket or the First Socket where the Telephone is is entering .. check the Connections there
* Electrical interference:
Check the Power lines,
Check radio or television transmitters, transformers and other electronic devices may causing noise on the phone line.
* Other phone devices:
Check for the Connection to the FAX check by unpluging the FAX Machine or answering machines,
Disconnect the other phones and line splitters --
Disconnect the Splitters or devices that allow two phones to fit on one phone jack -- can cause phone line noise.
* DSL services:
The high-frequency signals coming from DSL (digital subscriber line) devices sharing the phone line can create problems for other technology connected to the line.
Note : high-frequency signals coming from DSL helps for FAST Internet Connection speed which sometime cause the problem to the Phone or Voice signals for this need to contact to ISP to check the Voice margin .. that may effect your internet Speed
IF the above wont work..
You can try keeping the device near Heater .. it could be the Moisture which might causing this issue
Show the Device to the Service provider to repair it
Jan 22, 2010 | GE Telephone pr521w
When I am talking to someone on the phone i get a lot of static.
see what TTY mode your phone is in. TTY mode is under call settings or go to voice command and say TTY mode. I keep mine off. This mode is for people who are deaf, and people who are hard of hearing and use hearing aids.
Dec 12, 2009 | Plantronics Discovery 925 Bluetooth...
My new LevelOne WBR 3600B router does not eyncronize
Hi, If you are using dsl line, then try to add SPLITTER or FILTER between wall jack and phone.
When you connect splitter you will have one input line and two output line, one is called voice which you connect to phone and the other is data which you connect to router.
you can use LAN cable to connect modem and computer. before you set the connection please remove all the connection from wall jack to computer, wait for 2 mins and then re connect, like this it will remove if any static charges stored. If you are able to see the DSL light is up and no more blinking, Then your problem is solved. Hope this information will help you
Nov 17, 2009 | Computers & Internet
Have new lexmark 4800....wireless printer etc How do I receive fax w/o a phone line attached to equipment??
you cannot, you have to still have a landline connected to the fax, as the broadband is a different thing altogether, just get a double splitter adaptor from your wall socket and then connect the landline in one and your broadband filter in another, or just unplug the broadband and plug in normal phone line when you need to fax
Sep 01, 2008 | Computers & Internet
Help my internet connection is driving me mad
Hi, What you probably need is a line filter/splitter. This will effectively split your line into voice and data partially isolating one from the other. An example is PROLINK DSL Splitter. IF your ISP has already provided you with one, perhaps it may require replacement. You can also bring your concern to the attention of your ISP/Tel company. Hope this be of some help/idea. Pls post back how things turns up or should you need further information. Good luck and kind regards.
Sep 21, 2007 | WiFlyer - Portable, shareable WiFi base...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
