Question about Optoma EP716 Multimedia Projector
Power for optoma ep 716
I plug in the power source and connect to projector. But it is dead when it press the power button.
  • 1 more comment
  • davecrawfoot Feb 18, 2009
    plug it in, push power button and nothing
  • tlischko Mar 25, 2009
    Mine powers up occasionally but not all the time.
  • Anonymous Apr 10, 2009
    Plug into power outlet and the projector lights blink once. Where they use to blink more than once. Then the green light continued to blink.
    The projector will not power on.
    Any suggestions?
    Thanks
    RK
    Problem Solver:
  • 7 Answers
TAKE TO THE AUTHORIZED SERVICE CENTER OF OPTOMA
WANT ADDRESS goTHROUGH WWW.OPTOMA.COM
Posted on Jan 30, 2009
My Optoma EP 719 DLP shows a message saying D-Sub 2 source block, my remote is missing and it wont bring up the menu when i press the button on the device
I would look and look and look for that remote .unless your dog ate it then I would try the manufacturer's website tech support
Apr 25, 2015 | Optoma Office Equipment & Supplies
OPTOMA PROJECTOR hd25e LOCKED CENTRAL PANEL AND IR DISABLED HOW TO FIX
Your problem same like me,just hold on the ENTER button 7 second and than press the SOURCE button,the projector will auto reset.
Dec 17, 2014 | Optoma Office Equipment & Supplies
Projector powers up as normal, bulb comes on, displays Optoma logo on screen and menu will show on screen. The issue is that although I have 3 devices plugged into the HDMI port of the device using a HDMI...
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
Aug 11, 2011 | Optoma HD20 DLP Projector
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
Feb 25, 2011 | Optoma HD20 DLP Projector
Optoma 716
on the projector, restart your laptop/computer, this will detect automatically. if not then try display settings to 800x600.
Dec 13, 2008 | Optoma (BL-FU180A) Projector Lamp for...
EP716 Optoma Projector Fuse
There is no fuse. I took my EP 716 apart to find out why it died. I found a resistor had blown on the power board made by the Tiwan co. Quazarpower.
Dec 11, 2008 | Optoma EP716 Multimedia Projector
I have anoisy fan on Optoma EP 716. Are replacements available
ok u have a projector and i thing that the fan on that unit is installed on the projector lamp board and if it is this is the part number for it # ep 716 the bad news is it cost about 300.00 dollars. now if it is not then u are lucky u ccan take the fan in to any electronice parts house and get another one with n/p. and i wish that i could tell u all u have to do is put a little grease on it and that would work but the unit is sealed. i hope this helps marty
Oct 13, 2008 | Optoma Televison & Video
Help needed for Optoma EP 719 DLP PROJECTOR
It's a setting in the menu. A few minutes poking around will fix it.
Jun 12, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Unable to Connect DV10
Hello!
Which are laptops? I use IBM R40e and HP laptop and I usually connect them with DV10 for conferrence. It's well! I have just a problem with Asus EEE. It unable connetc with DV10. I try use Video jack to connect. Result: It can display but the quality is very bad. Now I try to find another way to connect them together. Some information to share with you. Thanks you!
May 03, 2008 | Optoma MovieTime DV10 Multimedia Projector
Optoma EP 738
You can test the power source if you are getting any power input from the power cord itself. Plug in your power cord and use an eletronic meter on the other end to see if you are getting the proper voltage (110/120) reading. If not, then the power cable is bad in itself. IF you are getting power from your cord, it could also be a fuse inside the Optoma and/or where the power plug on the Optoma meets the actual power source is out of alignment or may also be not making the proper contact to the main circuit board on the Optoma. Hope it helps....JGUAM
Jan 28, 2008 | Optoma EP716 Multimedia Projector
Optoma EP716 Multimedia Projector Logo
500 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
