Question about JVC AV-27F702 27" TV
JVC 32" flat screen I Art AV27F702
Please Help! There are several rows of dash like horizontal white lines at the top of the tv. Some of the lines are steady and some flicker? Sometimes there are more rows than other times. At first they were only there sometimes but now they are there all the time. What could be causing this problem? I tried all the connections as I thought maybe it was some kind of interference but to no avail. If anyone has any kind of idea, I would greatly appreciate your help. Thanking you in advance, Lady D
  • Anonymous Jan 26, 2008
    i have a problem with my tv i hooked the cable up and the channels are still blue and the remote want change the chanel by up and down u have to manulay type the numbers in
  • Tom nl Oct 12, 2008
    1. Hi,
    My jvc tv AV 27F702 has the same problem, as you said change C410 (vertical section) with 220uf/50v, but i check the capacitor on the pcb is Metallized polyester film cap and written: 104j --- 2A. Is it the right location that i was looking or the wrong location, is it the V-OUT is the vertical section? i do not have the schematic, i need help, thanks.
    Tom
  • 93 Answers
Change the capacitor in the vertical section of your tv. and it is located in c410,replace it with 220uf/50v.
Posted on Oct 13, 2007
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
Our JVC AV-32F703 has a black screen when we turn it on. The sound works fine. What could it be? The tv was purchased in Jan 03
try up the screen bottom in the fly back. if yoy see a white horizontal line the tv have a cold solder in vertical ic or is bad.
Apr 14, 2010 | JVC AV-32F703 32" TV
32" philips flat crt PINK SCREEN
The set has detected a problem internally and does not "start" to precvent further damage. i would take it where you got it sweety
Sep 05, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 13, 2017 | Apex Digital GB43HD09 43" Rear Projection...
Thin white horizontal lines across top of TV
replace vertical out put ic and related capacitors
please refer to a qualified tv personal to check tv
Jan 17, 2009 | Televison & Video
White horizotal lines on the top of the tv.
if you have knowledge in electronics, change the capacitor value 100/50volts in vertical section or else all capacitors in vertical section.
Oct 14, 2008 | JVC AV-27F702 27" TV
JVC i art 32" flat screen
your tv is under shutdown state, there is a protecting circuit that prevent the tv from turning on when there is a short
Sep 10, 2008 | Televison & Video
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
JVC AV-32F704 32" TV Picture is blurry - cannot read any writing on the screen
You didn't mention if you saw fine white diagonal lines running through the screen from top to bottom. If so, you likely have a shorted Picture Tube which is not usually fixable. If there are no lines seen running through the screen, then it is possible the High voltage transformer which also has a screen voltage and focus control built in that could be bad. I would expect the cost of that part to be about $100, so the repair cost total could approach that of a new set I would guess.
Apr 12, 2007 | JVC AV-32F704 32" TV
JVC AV-27F702 27" TV Logo
159 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
