HV block connector
I must have accidently disconnected a
plastic connector that has one black
wire coming out of it.the hv block part is
920p00501.The part has 4 prongs 2 vertically
and 2 horizontally. any help will be appreciated!
Thanks,Gramps
    Problem Solver:
I was able to get a picture of the block.
and found where connector goes.
Thanks,gramps
Posted on Nov 12, 2008
Hi, I have a sony rear projection TV. I am trying
The wire is the HV lead to the block or HV splitter.
At the splitter pull rubber boot back and press down and turn wire and it will come loose.
SD TECH
Jul 10, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
I have a f3 mag current error is coming.... and it is not heationg the sub enough...
F3 MAG CURR means you have a problem with the high voltage system in your oven, the microwave circuit.
The next part is extremely dangerous, if you have no background in electric STAY OUT. CALL A PRO you will be working with 5000 volts.
With that said you will need a clamp on ampmeter to measure the current to narrow down the problem.
Discharging can be done by unplugging the oven and then short across the red wire on each capacitor to the chassis with an insulated screwdriver.
1. Remove the top and right side covers.
2. Enter the test mode. (From the OVEN OFF mode, simultaneously press
BACK and ENTER keys, enter the code 9-4-2-8 and press ENTER).
3. Place amp meter on the brown "ct" wire for amp reading. Wire is coming from the primary side of the
HV transformers and looping through the black plastic current transformer on the main control board and back to the HV transformers.
4. Press and hold the MGTRON soft key on the keypad to energize the magnetrons.
5. Observe the amperage on the meter. Typical readings are:
NORTH AMERICA: 12-14 amps at 240VAC/13-16 amps at 208VAC.
If you are getting 12-16 amps then change the I/O board.
If you are only getting 7 or 8 amps then only one side of the of the HV system is not working correctly. You will need to figure out which side is bad by un-plugging the power wires going to one of the HV transformers. Then test again and if you get no amps you have found the bad side. Replace the HV transformer, cap and diode.
If you are not getting any amps then check the F3 fuse it will most likely be blown. Replace and start over
Nov 08, 2010 | TurboChef TORNADO Electric Oven
I have a HV-20G floor fan, And I have no contitnuity between the "white"--(common ) wire and the"red-low", "blue-mid", or "black-hi" wirres.I have 7.3 ohms between the blue&black and blue&red on a...
In that particular model, there is a small thermo fuse connecting the white wire and the yellow wire(there are 2 yellow wires coming from the capacitor). It's hidden in the coil so you can just cut the wick in that area an pull those two wires and you are going to see the fuse(small square shape one).
Sep 14, 2010 | Lakewood HV 18-c Floor / Box Fan
How do I remove the HV lines on the D board?
Do not cut them.
Push and twist thicker wire in HV block and pull out. HV block has 3 more wires going to 3 guns in TV.
Never cut this wire.
Feb 25, 2009 | Sony KP-61HS10 61" Rear Projection...
Removing the HV Wires from Flyback on RCA TV D52W19/
You really dont need it its only a wire.sliice and reconnect.
Feb 18, 2009 | RCA D52W19 52" Rear Projection Television
RCA HD52W59 HDTV arcing internal high voltage tower help
http://www.riddledtv.com/repair/RCA.html
http://serviceman.site88.net/index_files/Projection.htm
try these sites see if they help u
need to know chassi
Oct 03, 2008 | RCA HD52W59 HDTV Projection Television
Panasonic PT-53WXD63G Flyback, H.O.T., and Triper
The small wires are disconnected at the focus and screen control block, and the large HV cable is disconnected from the HV splitter.you may have to reuse the large red wire if the new flyback doesnt have the HV lead attached. The Hot is the horizontal output transistor its mounted to a aluminum heat sink near the flyback.
Jul 24, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Hi. Quick question.
Jerry,
I am assuming you need to get the HV lead out to remove the board. That model if I am not mistaken has the one large Red HV lead running from the flyback to the HV splitter where the other 3 large wires run to the CRts. If this is the case the trick is to remove the wire from the flyback at the splitter, I have found its easiest to slide the red rubber boot back then use a pair of pliers with tape on the jaws so as to not hurt the wire then grab the wire as close to the splitter block as possible then using a second pair of pliers like a hammer and hit the pliers holding the HV lead and thst will force the HV cable out of the Splitter block.
Jul 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Arcing noise in big screen tv 1996 rca
Probable bad HV block Part # 205064
Possible bad CRT = disconnect HV leads one at a time from
HV block until arcing goes away
Please rate this solution..........
Nov 14, 2007 | Televison & Video
Video blacking out...
Changing all the caps is not the right approach to problem solving.Works cold,but fails after hot is a thermal issue.After set warms up and fails,use cool freeze spray on suspect components to isolate.Determine whether CRT filaments are lit and/or if HV is present.Also,inspect jumper wire from transformer to HV block-if corroded,replace jumper HV lead & HV block w/Mits. parts.
Sep 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
