Question about Olympus Camedia C-700 Ultra Zoom Digital Camera
Olympus c700 digital camera battery door replacement instructions
How to remove and replace the battery compartment door on an olympus c700 digital camera
  • 1 more comment
  • Anonymous Dec 29, 2008
    Battery door will not stay locked.
  • raysonja Jan 03, 2009
    Battery door pops open and will NOT lock. SRS-
  • alexis24 Feb 19, 2009
    C-750 Ultra Zoom battery door is broken can I fix it or get it repaired
  • 130 Answers
SOURCE: Why does my lens close automatically after i turn on my Olympus Digital Camera D-500???
Does it beep or do anything other then turn off? what does it do in play mode? Does it have a good memory card in it? hold the memory door down tightly and try it. Akalines on these older smart media card type cameras just dont cut it they need ALOT more power then you think. NiMH rechargables are the only thing i would recomed using anymore. Dont listen to the tv NiMH are what you need. If you notice on the memory door when it open, there is a little plastic tab that stick out. This tab goes into a little slot on the camera, that slot pushes a button that tells the camera when the door is open and closed. These buttons can sometimes cause problems. So make sure the batteries are NiMH and the door is fully closed with some pressure on it. Also see what it does in playback mode. If it stays on fine in playback mode it may have a lens problem. The mechanism for the lens to move in and out could be jammed
Posted on May 06, 2006
bmwrider
  • 215 Answers
SOURCE: Olympus digital camera wont turn on
If any digital camera is subjected to extreme humidity or just plain dampness it's a fairly ggod bet the battery terminals within the battery could become corroded. Check them before blaming either the camera or batteries. Quite often a vigorous rub of the battery terminals themselves with a sheet of printer paper(especially aa type)is enough to cure the problem. With most cameras you will need a torch to check the lower contacts in the camera and any corrosion will be easy to spot but even if you can't see any it's always a good idea to use a little piece of wet and dry wrapped around you index finger to rub the tops of the contacts. So don't forget, check the batteries AND the camera contacts. A good way to check to see if the batteries have had their day would be to pop them in a torch or other appliance after cleaning them to see if they work. BMW
Posted on May 14, 2006
SOURCE: olympus stylus 710
I have one that I will sell you for $10.00 shipped. I had a parts camera and can ship it to you.
Posted on Dec 13, 2007
SOURCE: Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Posted on Oct 07, 2008
  • 70 Answers
SOURCE: Instructions for replacing Olympus Stylus 820 battery door
Give a call to 305-653-7355 they can help
Ask for Zack
Posted on Apr 15, 2009
Can battery compartment be repaired when tabs are broken off which hold lid down?
possibly...if it is the body where the tabs are broken off the manufacturer (Olympus) might be able to replace the body shell. I'd check with them.
Aug 16, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
How i can mount a new battery cover on Olympus SP-560 UZ
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Jun 18, 2010 | Olympus SP-560 UZ Digital Camera
Hi. I have an FE210 digital camera. The battery compartment lock is broken! How do I fix this? Does duct tape work? Will I be able to get it replaced?
Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $47.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 07, 2009 | Olympus FE-210 Digital Camera
How do I replace an Olympus Stylus 710 Battery Door?
Please visit this site and order a new batterydoor for your Olympus camera www.lutoncameras.co.uk
regards Rob NL
Apr 15, 2009 | Olympus Stylus 710 Digital Camera
Ask for Zack
Apr 15, 2009 | Olympus Stylus 820 Digital Camera
Camera won't power up even with new batteries
The problem you are describing is a problem with a sensor in the battery compartment. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $56 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 11, 2009 | Olympus FE-110 Digital Camera
Olympus stylus 710
I just wanted to follow up that we ordered the replacement part from the website another poster listed:
http://www.digitalcamerapartsdepot.com/Olympus_Parts/VK127200.asp
The part came in three days and it was SO EASY to replace. You just need a tiny Phillip's head scewdriver and about three minutes. Remove the three small screws that attach the faceplate to the camera (one on the bottom, two on the side). The faceplate pops right off and exposes the hinge that holds the battery door in place. Remove the final screw that holds the hinge in place. Reuse the original spring, pop the new door in place and then replace the faceplate.
Just like new! :)
Nov 09, 2007 | Olympus Stylus 710 Digital Camera
Door problems
i need the battery door for my camera because its not working anymore , hope you give me a quick answer
                                                               greetings
Aug 15, 2007 | Olympus Camedia C-3030 Zoom Digital Camera
Olympus Camedia C-700 Ultra Zoom Digital Camera Logo
212 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
