Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
Working fine until psu packed in, replaced psu, begins power up
Comp was working fine,
psu packed in,
replaced psu,
begins power up but nothing at monitor and red and green lights both stay on at casefront,
fan working,hard drive spinning,
wont turn off at switch needs power cut
  • 33 Answers
The PSU dying may have destroyed the motherboard also. Try removing all interface cards and disconnecting all drives to make sure.
Posted on Nov 12, 2008
Hp pavilion slimline power supply
you bringing a marginal part or connection back up a working state. when it cools or voltage drops it goes to the non working state. hp power supplies are not good to begin with. replacing it will fix it till that one also fails
May 23, 2017 | Computers & Internet
I have a emachine that powers ou, power pack fan, cpu fan but not the hardrive. It shut down and now won't start up. No beeps
Unplug from AC, open the case, clean if necessary, reseat the memory mods, use Electronic Contact Cleaner spray on contacts, plug in, push the on/off button. Does it begin to start, and in a few seconds completly shuts down? No LED's , no fans, nothing? Sounds like a PSU failure. Mine went out in 6 years.
Jan 09, 2013 | Computers & Internet
When i plug in my power pack nothing happens, the green light on the pack is light at first then fades off.There is no power and i cant turn the comp on. Is this a problem with m battery, pc, or power...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 14, 2010 | Computers & Internet
I bought a brand new M4A785-M, I have all compatable parts, even swapped every piece out onto my comp with the same board and boots fine. The comp booted fine before, I swapped the single core Sempron (1.8...
Is your phenom Phenom-X3-8450e or AMD-Phenom-X3-8450 ?
8450e is suported by that mobo but in the asus suport page you wont find 8450.
Check here https://www.asus.com/Motherboards/M4A785M/HelpDesk_CPU/
8450e runs on 65w and 8450 runs on 95w.
Does your mobo run with your old CPU?
Apr 09, 2017 | ASUS M4A785M Motherboard
Won't Turn On At All
No its gotta be the PSU you have worked it out yourself! if it worked in the other pc then its gotta be the psu!
Jun 30, 2009 | EliteGroup GeForce 6100SM-M Motherboard
Solid amber light on front amber on mother board
take the PSU (Power Supply Unit) from a known working computer, preferable to be the same model and test with it. when you do so make sure you disconnect any peripherals e.g ( Printer, CD-ROM, Floppy).
Look closely at the memory bay for any bent pins, and test with one memory at the time.
Let me know if this is still an issue.
Regards
Dec 23, 2008 | Dell OptiPlex GX280 PC Desktop
Comp not firing up
Something may be shorting out the board. Try taking the motherboard out and turning it on without the case. Just put the motherboard and power supply on a non-static surface. A box works well. Then use a flathead screw driver to temporary "jump" the 2 power switch pins for the front panel connection (as you wont be turning it on while inside the case).
If that doesnt work, then replace power supply. You could also take one out of another working computer just to test.
Jun 18, 2008 | EliteGroup K7VMM Motherboard
Comp won't start
Sounds like the pc power supply is bad... U can replace it, but if supply went out it may have damaged the motherboard. In future, have monitor blank off automaticlly and install UPS to supply pc. HP has histroy of weak power supplies.
Dec 09, 2007 | Computers & Internet
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
85 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
