Question about Garden
Tractor not starting , I do not see any gas in fuel filter
My tractor has always started (SABRE by JD) 20 HP B&S Vanguard OHV, recently it will not start; it turns over fine but I do not see any gas being pumpedinto fuel filter. I too fuel filter off and turned engine over but still did not see any gas spilling out of fuel hose. Could the problem be in the fuel tank or is it in the carburetor, fuel pump, etc. I did use my air hose and blew out fuel line back into gas tank and observed air getting in that way.Thanks, Dan
  • AL Turcotte May 11, 2010
    Hi, Did you say that you herd the air blowing into the gas tank? and did you hear a bubbly sound
    Silly question! Do you have any gas?
  • Anonymous Mar 13, 2014
    tractor died and would not start. I drained gas tank and bled fuel lines. Tractor ran then died again after 5 minutes. Kubota serviceman suggested debris as the problem.
    Sergeant:
  • Garden Expert
  • 417 Answers
Maybe a leaf or small twig in the tank keeps floating to the hole?
Posted on Nov 21, 2013
If fuel line from fuel pump to carburetor is dry, you need to replace the fuel pump.
Check your gas cap to make sure the tiny air/breathing hole in the top is clear.
Posted on Jun 08, 2012
  • 37 Answers
Hi, can you tell us if your problem has been solve?
Posted on Nov 23, 2008
  • 36 Answers
I would suspect the fuel pump. Those thin diaphragms wear out every few years. But you can also make sure there is no obstruction in the line from your tank at the same time!
Posted on Nov 13, 2008
My jd 111lawn tractor wont start was mowing it just slowly died.now it will turn over but wont start
Sounds like a fuel issue. Check and make sure your gas tank has fuel in it. Then check fuel filter to see if it is allowing fuel to the carb.
Aug 15, 2016 | John Deere Garden
Jd gx345 20 hp kawasaki water cooled. turns over will not start Both coils have juice to bath termals at the same time with the key on or off.
Drain fuel completely from tank, fuel line, and carburetor... Change fuel filter, change spark plug(s) add FRESH gas... Not 1 week, month or year old gas... (Can't be contaminated, or mixed with old fuel) there will be a drain screw on the carburetor (at the side of the bowl) You may need some quick start to get the engine to initially start up and keep it running with the spray until the fuel system fills up with fresh fuel and stays started.
Sep 16, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
I have a B & S vanguard 20 H.P. vert. shaft, 8 years old on Simplicty tractor. Keeps fouling plugs. Clean or replace plugs and it runs fine for about 1/2 an hour then starts to miss, blacksmoke, and...
Anti-foul plug adapters might be a temporary solution (treats the symptom and not the cause).
Personally, I would take it to a good, reputable, small engine repair shop that has verifiable references, and have them repair it.
Aug 03, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I am considering purchasing a used Exmark with a 23 HP Vanguard engine (~70 hours on the engine). I've not been too pleased with Briggs (have one on my John Deere garden tractor - hot natured and...
yep its a briggs and normaly there very good ploders
if your john deere spluters and back fires it needs a good looking at check the valves first,,,a hand full of bolts and the heads off and if your carfull you can still use the same head gasket again,,,also check the carb there very finiky and need to be kept clean the air filter is a joke,,,but clean it anyhow and they like new plugs,,,every ten years or so? iv worked on 100s of brigss and stratons/vanguard. there good engines but there ploders not sprinters there ok in a tractor but no good in a tank there to darn slow
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Vanguard (Briggs) 20 HP V Twin Mower Engine
pull the tank first and inspect. if u still find nothing, you might want to check your coil
Aug 22, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
344 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
