Question about Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor
Incorrect Color Display
My monitor displays correct colors on the left side but on the right side it displays the color turquoise. Changed out cables and they were fine. Changed out monitors and that checked out fine too. Is there anyway to repair my monitor.
  • 22 Answers
I think it has magnet on the other side of your monitor try to locate the magnet and removed it. magnet can change the color and display of monitor. or contact an expert technician of monitor.
Posted on Feb 20, 2008
Yellow screen
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Color
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
http://www.adobe.com/education/pdf/cib/ps7_cib/ps7_cib17.pdf
Jul 21, 2013 | Acer Computers & Internet
Choppy video playback pc
Which operating system ???
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.Hold down the "Fn" key.
Color
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop down menu.
Click "OK" to exit the Graphic Properties Application
Click "Driver."
Rather doing a driver hunt which can take hours
http://ct.download.com/clicks?t=1179231350-ce770fd4fbc57664a08aea1a8f03b80d-bf&brand=DOWNLOAD&s=5
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
If the video playback on your Windows Vista-based PC is choppy, fix the issue without replacing the graphics card.
Tweaking the video driver can smooth video playback.
This is accomplished by changing the hardware acceleration settings of your PC.
Changing the hardware acceleration settings tells your computer that video is more important to you than other background tasks, such as defragmenting software or other third-party programs.
Right-click anywhere on the desktop and choose "personalize."
Click on "display settings," followed by "advanced settings."
Click "troubleshoot," followed by "change settings."
Move the notch on the performance meter to the left one section over.
This will change the Hardware acceleration settings to optimize video playback.
Play your video.
If performance does not improve, continue moving the performance meter to the left until playback improves.
Jun 15, 2013 | Acer Aspire Computers & Internet
Basic "background" colors are wrong:
Kathy...have you tried connecting another monitor to the same video card and computer? It could be...
1. Video card defective
2. VGA cable from computer to monitor defective...look for bent pins in plug.
The VGA cable from the computer video output carries three distinct colors...red, green and blue. Likewise one of these colors may not arrive at the monitor correctly or at all. The results being that all colors are incorrect.
Apr 13, 2011 | Westinghouse L1975NW Monitor
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Monitor turns green
This sounds like a problem with the cable. Monitors have Red, Green, and Blue signals. I have seen it where the cable has a short, or the plug has a bent or loose pin, and this causes the monitor to turn green.
It is also possible, but doubtful, that the video card is trying to run it as a Black and White monitor. B&W signal is sent over the green channel.
Jul 29, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung samtron 55v display problem
assuming that u r a professional..
i guess there is no problem with ur monitor, it sounds like itz due to graphic adapter..either the adapter on ur system main/mother board/agp/pci/pcie is damaged or itz simply 'driver corruption'..
don't panic..check for driver update/download n reinstall graphic/display driver..
however, 1st make sure that the Screen Resolution (1024x768 or as applicable) and Color Quality (32 bit or as applicable) is correct..from Display Settings->Settings tab..
always better to contact system admin/vendor....
Dec 30, 2008 | SAMTRON 55V 15" CRT Monitor
My monitor displays yellowish color instead of original color
yes please take the power on self test means disconnect signal cable and monitor will give
display without cpu if display appears then monitor ok fault is in cpu if not then fault is in monitor move signal cable and look display changes or not if changes then cable faulty replace it
Nov 11, 2008 | SAMTRON 55V 15" CRT Monitor
Display color has been changed to rainbow.
AS hit the monitor on its top the color changes to normal. so what can i do AS IT COMES TO normal position after hitting that cleary indicates that there is no parts failure. 1 there is a loose contact in or near crt base. 2 loose contact in connector. 3 computer to monitor cable loose.
Sep 15, 2007 | SAMTRON 55V 15" CRT Monitor
Need solution for the yellow display of my monitor
You can see one ic in right of crt base,plz resolder it (90%sure)
Sep 14, 2007 | SAMTRON 55V 15" CRT Monitor
Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor Logo
124 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
