My Emachines_w2888 will not boot up. I get a, (NO SIGNAL INPUT).
The monitor shows, (NO SIGNAL IMPUT) onle briefly then the screen goes blank. The power supply fan is running, The case cooling fan is also running. The hard drive is running.
The wireless mouse and keyboard don't have any power input.
The system has been upgraded to 2GB , RAM, other wise it is in new condition.
System Model: emachines, Inc. D845GVSR
Main Circuit Board: Board: Intel Corporation
Serial Number:TGSR40603770
Bus Clock; 100megahertz
BIOS: Intel Corp. SR84510B.44T.0019.P03.0402081958
02/08/2004
Memory Modules:
2GB,s
Slot'J6G1 has 1 GB's
Slot'J6G2 has 1 gb's
Any help will be appreciated.
Thank you,
Dale J. Fetherland
  • 1 more comment
  • defeth1222 Nov 11, 2008
    I tried taking out the memory sticks and replacing it with the orignal memory stick but the same problem still exist. I also tried each new 1 gb sticks at a time to no avail,still orignal problem. The computer did not sound any beep tones and the amber hard drive light did not come on either.
    With power on the computer I turned off the monitor and then back on and still get the, (NO SIGNAL INPUT). I like the computer, but it's over 4 years old, so If the problem cost to much I might as well get a new one.
    Thanks for your help.
    Dale J Fetherland
  • sue_f1 Jan 07, 2009
    i have the same problem with no signal input
  • Anonymous Feb 14, 2009
    same here - different hardware. wondering if mobo BIOS out of box doesn't support 1066 RAM...
  • 345 Answers
If all you have done is upgrade the memory, take out one stick of memory and see if the computer will start up. If it acts the same way it has been acting, take out the other stick of memory and put the first stick of memory back in. You could have a bad stick of memory. Does the computer make any beeping noises when you try to start it? Those beeps are the BIOS way of telling you there is a problem. One BIOS beep means the system is starting if you have more than one beep, there could be a problem, the number of beeps along with the brand of BIOS will give you a clue as to what the problem is. Once you know the number of beeps and the brand of BIOS you can search the Internet for what the problem might be. Your monitor showing "NO SIGNAL INPUT" is its way of saying "I'm ok but something else is wrong".
Good luck
Posted on Nov 11, 2008
    Scholar:
  • 172 Answers
Motherboard blown, contact me for support at compdoctor2005@btinternet.com
Posted on Dec 05, 2008
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
I TRIED TO RESET THE RESOLUTION. THE SCREEN WENT BLANK AND THE MESSAGE ON THE SCREEN SAYS IMPUT SIGNAL OUT OF RANGE
I believe the max resolution this LCD can support is 1440 x 900 / 75 Hz. If you set your display resolution higher then that, you will receive the input signal out of range error. Your LDC turns off to protect it self from the invalid settings. If you can not change it back once your PC boots to windows, you may have to do it in save mode by pressing F8 once you power on your PC and before the windows loading screen starts.
Regards, Chris
Jun 29, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
Computer screen says imput not supported what do i do?
i believe at boot you should hold f8 for advanced booting options, and then select safe mode, which will start the computer in a lower resolution graphix. from there, set the resolution down on the display. right click on the desktop and select properties or personalize, then look for the display setings for screen resolution. its prolly set to 1680 x 1050, and needs to be set to something around 1280x768 or something: maybe its set to a different aspect ration or just plain different size.
Oct 09, 2009 | E-Machines eMachines Monitor E15T4
Input Screen shows a permanent image
resolution issue. reset the settings to factory default. if that doesn't solve it, make sure the resolution on the projector matches what is on the computer. and it should take mac ok. also check the cable.
Aug 27, 2009 | SharpVision XV-Z9000 Multimedia Projector
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Boot up computer. Nothing comes up on screen. Get a message:"information. No input signal." Everything is plugged in correctly.
  • check the cable on the monitor screen
  • if after removing the data cable from the computer and it has no vertical color screen then
  • try other data cable
  • try other monitor screen
May 02, 2009 | Computers & Internet
My eMachine momitor won't work with another CPU
Run a memtest to see if your ram is faulty. If it is replace and go.
Jan 20, 2009 | E-Machines eMachines Refurbished EMA...
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
No input signal
Check connections, Hertz rate, and settings (if you can read them). Otherwise, it may be time to whip out the cash and get a new monitor and/or computer.
Aug 17, 2008 | Computers & Internet
Computers & Internet Logo
230 people viewed this question
David Payne
David Payne
