Question about HP LaserJet 3050 All-In-One Printer
I am having trouble with faxing information to another fax.
I enter the number that the fax is going to, the fax dials the number, the pages are put into memory ( it says) then when it is time for the fax to go through, it says dialing then there is a busy signal, then it says, no answer and prints out the info page stating the time of the fax, the date and then shows where the fax was not sent because of no answer
Please help as the all-in-one is used for our business
  • johnsnow696 Dec 01, 2008
    My 3050 used to fax fine, now I have the same problem, documents feed, number is displayed and dialed, a series of beeps, then a message that there is no answer which I know not to be true.
    Problem Solver:
  • 4 Answers
I have had this problem before. Either your fax is not hooked up properly or whoever you are trying to send the fax to does not have their fax hooked up properly. If it's not one of these problems makes you have the right fax number and that you are putting the fax number in correct. Some fax require the whole number to be entered 1 including the area code.
Posted on Nov 11, 2008
Iam getting remote fax error
Please try this approach:
1. Try to resend the fax. There may have been a problem with the quality of the connection.
2. Decrease the transmission speed of your fax modem. Press Setup button > Fax Setup > Dialing and Sending > Max Send Speed > 9600. Resend the fax.
3. Re-register your user information - fax name and fax number. Some fax machines block faxes without sender information. Press Setup button > Fax Setup > Dialing and Sending > Your Fax Name (re-enter your fax name). Follow the same steps and go to Your Fax Number - re-enter your fax number. Resend the fax.
I hope this helps.
Feb 20, 2012 | Lexmark Platinum Pro905 multifunction...
Need to know how to fax from mcf 210c
How to enter Fax mode
Before sending faxes, make sure (Fax) is illuminated in
green. If not, press (Fax) to enter Fax mode. The default
setting is Fax.
How to dial
You can dial in any of the following different ways.
Manual dialing
Press all of the digits of the phone or fax number.
Setup Send
3 - 2 SETUP SEND
Speed-Dialing
Press Search/Speed Dial, #, and then the two digit Speed-Dial
number. (See Storing Speed-Dial numbers on page 5-1.)
Search
You can search for names you have stored in the Speed-Dial
memories. Press Search/Speed Dial and the navigation keys to
search. (See Storing Speed-Dial numbers on page 5-1.)
* To search alphabetically, you can use the dial pad to enter the first
letter of the name you are looking for.
Fax Redial
If you are sending a fax manually and the line is busy, press
Redial/Pause, and then press Black Start or Color Start to try
again. If you want to make a second call to the last number dialed,
you can save time by pressing Redial/Pause and Black Start or
Color Start.
Redial/Pause only works if you dialed from the control panel.
If you are sending a fax automatically and the line is busy, the MFC
will automatically redial one time after five minutes.
If the LCD shows Not Registered when you enter the
Speed-Dial number, a number has not been stored for it.
Color fax transmission
Your MFC can send a color fax to machines that support this feature.
However, color faxes cannot be stored in the memory. When you
send a color fax, the MFC will send it in real time (even if Real Time
TX is set to Off).
Nov 02, 2011 | Brother MFC 210C All-In-One InkJet Printer
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
Is there a Fax modem available to be connected with scanner, copier and printer (three in one already with us.)
your unit has a fax installed in the unit.
Look at page 29 in your manual it will show how to send and receive a fax.
send a fax page 29
receive a fax page 32
print reports page 33
feature purpose
1 Phone Hook: the green LED in the shape of a phone indicates that the fax
line is in use when lit.
2 One-Touch Speed-Dial Buttons: use to access the first 6 speed-dial entries.
3 Auto Answer: when the green light is on, fax transmissions will
automatically be accepted.
4 Speed Dial: use to access speed-dial numbers that have been set up from
the front panel or with the HP Director software.
5 Redial/Pause: redials the most recently dialed number when in the ready
state. Inserts a pause (hyphen) when in the dialing state.
6 Keypad: use to dial fax numbers, and enter numbers such as the quantity
of copies or percentages when reducing or enlarging. You can also enter
text using the keypad for fax header, use speed dial entries, and specify
menu items.
7 Fax Resolution: use to set the fax resolution to Fine, Standard, 300 dpi,
or Photo. It will remain at the most recent setting until changed.
8 Start Fax - Black: starts a black and white fax.
9 Start Fax - Color: starts a color fax
Apr 27, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Cant install fax software for lexmark x5495 aio printer.
1. Unplug the printer from the PC
2. Uninstall all the software related to the All-in -One ( that is on the PC)
3. Connect the All-in-One again then follow the software instructions for reinstalling the printer.
From the instruction manual:
Sending a fax
Entering a fax number
1 From the control panel, press Fax Mode.
2 Enter a fax number using:
The text box Enter a fax number using the keypad.
Notes:
• You can include a calling card number as part of the fax number.
• Enter a maximum of 64 digits in a fax number.
• Press Pause / Redial to insert a three-second pause in a number you
are entering to wait for an outside line or get through an automated
answering system.
Speed Dial or Group Dial a Press Phone Book.
b Enter Speed Dial and/or Group Dial numbers.
• Press or repeatedly until the Speed Dial or Group Dial
number you want appears.
• Use the keypad to enter the number of the Speed Dial entry (1–
89) or Group Dial entry (90–99).
Notes:
• For instructions on how to add Speed Dial or Group Dial numbers
using the computer, see “Setting up Speed Dial” on page 118.
using the control panel, see “Using the Phone Book” on
page 108.
3 If you want to send a fax to a group of numbers (broadcast fax):
a Press .
b Repeat step 2, using any combination of the previous methods, until a maximum of 30 fax numbers have
been entered.
Sending a fax using the software
You can scan a document to the computer and then fax it to someone using the software.
1 Load an original document facedown in the Automatic Document Feeder (ADF).
2 From the desktop, double-click the Productivity Studio icon.
3 From the right pane of the Welcome Screen, click Fax.
4 Select the Document option.
5 Click Start.
6 Enter the recipient information, and then click Next.
Note: A fax number can include up to 64 numbers, commas, periods, spaces, and/or these symbols: * # + - ( ).
Faxing
103
7 Enter the cover page information, and then click Next.
8 If there are any additional documents that you want to send with your fax, add these now, and then click Next.
9 To send your fax:
• Immediately—Select the Send now option.
• At a scheduled time:
a Select the Delay sending until option.
b Set a time and date.
10 If you want a paper copy of your fax, select Print a copy of your fax.
11 Click Send.
Sending a fax using the control panel
1 Make sure the printer is on.
2 Load an original document facedown into the ADF or on the scanner glass.
Note: Do not load postcards, photos, small items, transparencies, photo paper, or thin media (such as magazine
clippings) into the ADF. Place these items on the scanner glass.
3 From the control panel, press Fax Mode.
4 Enter a fax number or press Phone Book to select a number from the Speed Dial or Group Dial list. For more
information, see “Entering a fax number” on page 103.
Note: To set up Speed Dial, see “Setting up Speed Dial” on page 118.
5 If you want to send a fax to a group of numbers (broadcast fax):
a Press .
b Repeat step 4 and press until a maximum of 30 fax numbers have been entered.
6 Press Start Color or Start Black.
Sending a fax while listening to a call (On Hook Dial)
The manual dialing feature lets you dial a telephone number while listening to the call through a speaker on the
printer. It is useful when you must navigate an automated answering system or enter a calling card number before
sending your fax.
2 Press .
3 Press or repeatedly until On Hook Dial appears, and then press . You can now hear the dial tone of
the telephone line.
4 Enter a fax number. For more information, see the related topic, “Entering a fax number.”
Note: Press the keypad numbers to use an automated answering system.
5 Press Start Color or Start Black.
Faxing
104
Sending a broadcast fax at a scheduled time
You can send a fax to a combination of up to 30 people or groups at a time you choose.
1 Load an original document facedown into the ADF or on the scanner glass.
2 From the control panel, press Fax Mode.
3 Press .
4 Press or repeatedly until Delay Fax appears.
5 Press .
6 Press or repeatedly until Delay Until appears.
7 Press .
8 Enter the time you want to send the fax.
9 Press .
10 If the printer is not set to the 24 hour mode, press or repeatedly to select AM or PM.
11 Press to save your settings.
12 Enter a fax number, or press Phone Book to select a number from the Speed Dial or Group Dial list. For more
13 If needed, repeat step 12 and press until a maximum of 30 fax numbers have been entered.
14 Press Start Color or Start Black.
Note: At the designated time, the fax numbers are dialed and the fax is sent to all of the designated fax numbers. If
the fax transmission is unsuccessful to any of the numbers on the broadcast list, the unsuccessful numbers will be
dialed again.
Receiving a fax
Receiving a fax manually
1 Make sure the Auto Answer light is off.
2 To receive the fax if you have not set up a manual answer code:
• Press Start Color or Start Black.
or
• Press * 9 * on the telephone after you answer it and hear fax tones.
3 To receive a fax if you have set up a manual answer code, enter the code on the telephone after you answer it
and hear fax tones.
Note: For information on how to set up a manual answer code, see the related topic, “Setting a fax manual answer
code.”
4 Hang up the telephone. The printer receives the fax.
Faxing
105
Apr 15, 2010 | Lexmark X5495 All-in-One &USB...
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
the key will glow green.
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
The machine starts scanning the
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
Dial the fax number.
If you press Black Start, the
machine starts scanning the first
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have a lexmark x4270. Having problem sending fax. Sending local number, it's OK, but sending a different area code, it uses the local area code then the first 7 number of that number. Because someone...
Hi zoaj,
More then likely you have the fax set up to USE A DIALING PREFIX.
Therefore it is automatically doing this, regardless of what you input.
Follow the proceedure below ( which comes directly from the users manual for your printer type ) to change this. Delete the " USE A DIALING PREFIX " information.
once that is done, it will no longer automatically add the prefix for you. :)
I have BOLDED the relevant information below that pertains to this.
Please take a moment to evaluate my solution. Your appropriate rating of my solution would be greatly appreciated.
Thank you,
Using the Fax Setup Utility Use this utility to adjust the fax send and receive settings. When you save these settings, they apply to every fax you send or receive. You can also use this utility to create and edit your speed dial list.
  • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Fax Setup Utility.
  • From Lexmark All-In-One Center All-In-One Main Page, click Fax Setup Utility.
The following table describes the Fax Setup Utility tabs:
On this tab:
You can:
Send
  • Enter your name and fax number.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Choose whether to use error correction.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report.
Receive
  • Choose whether you want to print a footer (date, time, and page number) on each page.
  • Automatically reduce an incoming fax to fit to the paper size loaded or print it on two sheets of paper.
  • Select whether you want to forward a fax or print it, and then forward it.
Connection/Dialing
  • Select the number of times you want the machine to redial and the time between those attempts if the fax cannot be sent on the first try.
  • Select the phone line format you want to use (Pulse, Touch-tone, Behind a PBX).
  • Enter a dialing prefix.
  • Choose how (manually, if fax tones are detected, or after a certain amount of rings) you want to answer incoming calls.
  • Select a distinctive ring.
Speed Dial
Add to, create, or edit the speed dial list.
Group Speed Dial
Create a group number and name, and then add phone numbers to the group.
Oct 11, 2008 | Lexmark Office Equipment & Supplies
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
Won't send faxes
did you put the originals page(s) in the machine FIRST to fax, then enter the number then press start?
If you enter the phone number 1st BEFORE putting your originals in the feeder, the machine thinks you want to make a copy.
The FAX Mode is the setting for incoming faxes.
Try that and let me know if it works.
There should also be a button called "Hook" or "speaker" or something that you hit and you will hear the dial tone.
Once you hear the dial tone, you can dial the number, (make sure the pages you want to fax is in the feeder.
Once you hear the fax high pitch noise, hit the start button.
Hope this helps.
Let me know if it does and also remember to leave a feedback and rating if I have helped you.
Thanks and good luck.
Mac =)
Feb 19, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
HP LaserJet 3050 All-In-One Printer Logo
214 people viewed this question
Ben Johnson
