Question about Linksys Wireless-G WRT54G Router
I think we bricked my WRT54G router
I flashed came back and said it was successful...but after a full reset the test and labels were gone from the display...
so we attempted to FTP the flash version into said it was successful...but we unplugged it too soon <5 minutes.
now i cannot access it from anywhere, anyhow.
WRT54G Ver. 2
Flash version: WRT54GV4.0_4.21.1_US_code.bin
SN: CDF50DA13485
is there a place i can send it...or should I send it to the trash heap...
  • mark.vanderd Nov 11, 2008
    that is exactly what i needed...thanks
  • Linksys Master
  • 6,487 Answers
This router has a 3 year warranty from Linksys so if its still under warranty you can still have it replace from Linksys, you just need to contact Linksys tech support and they will have the router replace, this is their number 800-3267114.......
Posted on Nov 11, 2008
I have a whirlpool cabrio and the lid will not lock the light keeps flashing and it keeps making the lock clicking sound
BEFORE ASSUMING THE LID SWITCH NEEDS REPLACEMENT TEST WITH A METER, BUT FIRST TRY TO RESET CONTROL BOARD EVEN RUNNING A DIAGNOSTIC TEST WILL REVEAL THE SOURCE OF THE ERROR.. 1. Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). 2. Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: a. Press/hold 3 seconds. b. Release for 3 seconds. c. Press/hold 3 seconds. d. Release for 3 seconds. e. Press/hold 3 seconds. ? If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. ? If indicators do not display as described above, the press/hold/release procedure above may not have been performed within the time frame necessary for successful entry. Repeat step 2 to ensure this was not the cause. If still unsuccessful, see Diagnostic: Unsuccessful Entry, at right. 3. The test sequence continues by checking for saved fault codes: ? If there are saved fault codes, see Diagnostic: Saved Fault Codes, page 2. ? If there are no saved fault codes, all indicators on the console will momentarily turn off, then turn back on with 88 displayed. After 5 seconds, the Automatic test, below, begins.
TEST #8 Lid Lock Perform the following checks if washer fails to lock (or unlock). 1. Perform Manual: Lid Switch and Manual: Lid Lock tests on page 2. 2. Remove the console to access the machine/motor control assembly. See Accessing & Removing the Electronic Assemblies, at right. 3. Visually check that the P12 connector is inserted all the way into the machine/motor control. ? If visual check passes, go to step 4. ? If visual check fails, reconnect P4 and repeat step 1. 4. Check the lid lock motor winding and switches by removing P12 from the machine/motor control and checking the resistance values shown in the following Lid Lock Resistance table:
Feb 11, 2017 | Whirlpool Washing Machines
Reset power on password
If you feel comfortable doing so, remove the back panels that cover the wireless card, RAM, hdd, etc. You're looking for a small button-cell battery with two wires connected to the motherboard. If you see one in plain sight, you're in luck. Disconnect it from the board, remove your laptops full size battery, and make sure it isn't plugged into any power source at all. Leave it for 1-3 minutes. Reconnect the button cell battery (This is a CMOS battery and stores BIOS passwords ), plug the other battery or your charger in, restart laptop. Password should be reset, however some BIOS' hold it in flash memory.
If this is the case, look on the bottom of your laptop and attempt to find a serial number on a white label. it may be labeled s/n or something like that. Type this serial number in at ( and attempt to generate a master unlock password for your laptop. This works about 50% of the time for me. If it allows you to get into the laptop, the password generated will allow you to change all passwords in BIOS.
Dec 17, 2013 | HP Compaq nx6110 Notebook
Sony bravia KDL-46EX725 6 flashing red light
Check the power supply. IT might have bad caps.
Aug 30, 2013 | Televison & Video
How can I make printer recognize refilled cartridge on lexmark prevail pro 705
Refilled cartridges will not reset the ink levels. The printer will still recognize it as empty.
Please be advised that refilled/remanufactured cartridges could damage your printhead and will not be covered under warranty.
Nov 27, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
How do I set time etc on a coleman sports watch, have manual but doesn't make sense, it's model 40-408
The watch has four buttons. The lower left button is labeled MODE on the face of the watch. There are four modes and pressing the MODE button will step through each mode until you return to the mode at the start of the process. Start at the "Normal" timekeeping mode and press the "MODE" button three times until the digital display rightmost two figures for seconds flash.
Press the lower right button labeled RESET until the item you want to change is flashing. Pressing RESET cycles through seconds, minutes, hours, day, month, day of the week in the top sub-dial and then back to seconds again.
When the item you want to change is flashing press the top right button labeled START to step the displayed item to the value you want. When you are satisfied all the settings are correct, press the lower left button marked MODE to return to normal operation.
Coleman 40-408 User's Guide
Nov 03, 2009 | Bulova Watch
I recently did a eeprom reset on my Samsung D900
I would say flash the firmware. Do a full flash, it sounds like whatever reset you did caused a problem. If flashing isn't' the culprit, it could be a loose cable or bad part. BUT, if you can make it "go bserk" at the same time, like every time you SMS or something, that will prove that it is not hardware, but is firmware and a flash should do it.
Oct 24, 2009 | Samsung SGH-D900 Cellular Phone
White Display on Nokia N 70
With lose of full function display. First remove the battery and leave it out for approx 2-3 minutes to attempt to reset the connection.
Also if possible use either your AC connector or another battery to check if your battery itself isn't the cause of the malfunction.
If that doesn't correct it call your service provider for them to attempt to reset the display functions on your menu setup from their remote location.
Last but not least if not from factory defect or impact shock from having been dropped or condensation. Wear on parts may have come a time to repair or replace the phone.
Jul 27, 2009 | Nokia N70 Cellular Phone
8500 radar display
I take it that pressing the 8500's City button won't switch sensitivity modes? If so, and if performing a RESET doesn't resolve this problem, then either the firmware is corrupted or (most likely) the micro-switch for the City button has gone bad and needs to either be replaced or possibly resoldered so that its two terminals are once again making full contact with the solder pads on the circuit board.
May 18, 2008 | Passport 8500 Radar Detector
Won't print labels
Ended up being the heating settings - they were to low, so when I hit would spit out a label but nothing would be on it.
Problem solved!
May 14, 2008 | Datamax DMX E4203 Printer
Ti-83 Plus weird display problem (detail included)
Warning the following tip will erase apps and programs from calculator!
The following will run the self-test mode
Press mode then press alpha then press s then press enter
If you want to get out of the self test press the on button in case you want to attempt to save/transfer apps, programs, variables etc.
The calculator will start to test itself it'll countdown and display numbers on the screen. It can get better sometimes other times a replacement of both the cr1616/cr1620 lithium battery and the 4 AAAA batteries work. Also ensure that you've attempted to clear out all the memory and reset the calculator. To delete all variables, tables, graphs, etc: Press 2nd button then press MEM then press 2 then press 1.
To reset the calculator press 2nd button then press MEM then press 7 then press the left arrow then press 1 then press 2.
Jun 03, 2007 | Texas Instruments TI-83 Plus Calculator
Linksys Wireless-G WRT54G Router Logo
97 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
