Question about Samsung Televison & Video
I can not connect my pc to my samsung dlp - Samsung Televison & Video
    New Friend:
  • 125 Answers
Not all TVs have video inputs to directly connect the computer output. Some computers have video cards that have separate outputs(usually S-Video) which you can use. Or you can purchase a video card that has the proper outputs.
If your computer has a DVI output, and your TV has an HDMI imput, there are cheap adapters that you can buy, as HDMI can process the DVI signal directly, just the cable is different.
If you need more assistance, we would need to know the models/outputs/inputs of both the computer and the TV.
Best Regards
Posted on Nov 11, 2008
No picture
Check the lamp contacts, eventually remove lamp and fit back in, chack that you did not burnt new lamp when mounting it in, you need a multimeter to test lamp.
Aug 10, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Connect pc to dlp tv
You would have to determine from the TV owner manual if it can be connected--some can and some cannot----the model listed here is old enough that if it does connect it may not look very good.
Aug 27, 2012 | Samsung HL-R6167W 61" HDTV
Samsung HLP4663W DLP 46' tv: Just replaced with new color wheel and the lamp is newer -6months old. When I plug in the hdmi cable, I get picture but no sound. However, if I plug in the coax, I get...
You still need to get an audio Left and right connected from the video source.And for the digital reception from the antenna source is not possible because your unit is not equipped with a digital tuner(it is NTSC or analog reception only)it needs an add on digital tuner that has an hdmi output.Newer ones now are equipped with digital tuners.
Oct 27, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Had one last week and now there are 6. they are
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Nov 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Odd sound from Samsung DLP TV
Buzzing could be related to the lamp/ballast connection. Try removing and reinserting the lamp look for arching marks on the contacts that would suggest that the connection wasnt good.
Mar 29, 2008 | Televison & Video
Samsung DLP Vertical Hold
Problem is either bad connect inside or heat-related failure....
also called thermal will need help from a knowledgeable SAMSUNG tech.....prefer authorized service
center, then you can give feed-back to SS customer service if needed.......................T.
Dec 10, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
