Question about GE 30 in. Profile JP989 Electric Cooktop
The light on my ge electric glass cooktop won't go off.
I have a 2002-03 ge profile oven with a glass cooktop. The cooktop has 4 regular size knobs and 2 small knobs (I don't know what they are for). One of the small knobs is located before the first knob on the cooktop and the other small knob is in the middle of the regular size knobs. There is a light associated with the 2 small knobs when you turn them on. I have not turned either knob on, but the light is on and won't go off. It's getting dimmer and dimmer. I guess it's about to burn out, but I was wondering why it's on and what the 2 small knobs are for. I cannot locate a manual on anything but the oven and the microwave, nothing on the cooktop. I don't know if the product number is correct, but it is an electric cooktop. Please help!
  • rmpage7 Dec 30, 2008
    Tashedesign:
    Thank you for your response to my problem. To try and clarify: I have 2 lights on my cooktop. One of the lights is associated with the 2 little knobs. This is the one that is not working. The hot indicator light works fine. I would be most appreciative if you would upload the page that you mentioned. Again, I am not sure of the model number of our cooktop because the manual has been misplaced. However, most of these cooktops are probably similar so the page from your manual would probably help with my problem. Thanks again!
  • tashedesign May 11, 2010
    The two little knobs:
    a: the left side makes a griddle effect, combining the two round surfaces to make an oval
    b: the right side changes the size of the round, one way its small to accommodate a smaller pan
    If you really need the manual I can upload the discription page for you.
    I think you are having the same problems all the rest of us are having. Our hot indicator light is on and it won't shut off.
    Probably needs a fuse replaced. I'm going to leave mine until the next time I have a service guy for something else. It shouldn't matter all that much, you just won't know when the stove top is hot or not.
fridgetech
  • 473 Answers
SOURCE: ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Posted on Oct 26, 2007
reg501
  • 413 Answers
SOURCE: old kenmore gas cooktop with griddle
If the knobs will not push down and turn, this indicates the gas valve stem has become contaminated with cooking debris. The only solution to this, would be to replace the gas valves. With the cooktop more than 10ys old, parts may be difficult to find. If you can find parts, they will probably be prohibitively expensive.
Posted on Jun 29, 2008
  • 161 Answers
SOURCE: glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Posted on Jul 15, 2008
textonor
  • 130 Answers
SOURCE: profile gas on glass cooktop
Hello mkerfoot, I know the feeling. The same complaint I hear about on SS. I just sink type dish washing detergent to clean the grease off and a paper towel with vinegar water solution. For heavy staining on the burner area, apply the dw detergent full strenght and let it sit to loosen the debre. Hope this helps.
Posted on Aug 09, 2008
  • 8 Answers
SOURCE: GE Profile JP350 cooktop stopped working
OK, i think the problem took care of itself. definitely got water down in the infinite switch for the lower right burner. let it dry 12 hours and reset the breaker, now works fine. but, i know if i do that again, or if it happens randomly, i will have to replace the switch and seals (available at repairclinic.com)
to do that, you have to remove the cooktop (screwed down by a strap in the back to the back wall of the cabinet) remove the sheetmetal to access the switches and replace. just keep the wiring straight, and ALWAYS replace the seals, they leak over time.
Posted on Mar 01, 2009
How do i fix a squeaky control knob on a ge downdraft cooktop?
silicone spray works wonders !!!! and most silicone's are food safe too (look 4 it on label) so its safe to use around food prep area's, it however does not taste 2 good to the human palate so use sparely
Jan 05, 2016 | General Electric PP989TNWW GE Profile 30"...
What is ge error code 0225
I have the same issue and was told by GE that it will take a technician to fix it because it is not a known error code. Most error codes start with "f", F0, F1, etc. This the second time a tech had to come out for this cooktop. Probably the last GE I buy. Definitely won't buy anything electronic. I want regular knobs on the next one.
May 05, 2014 | General Electric Ge Profile Pp975bmbb 36...
GE Profile cooktop JP360. Trying to remove cooktop to install new granite countertops. Also have GE built in oven JTP 15 below. Called G.E. Customer Service today and was told to just pry the top off...
Hi marilynmcdon,
You can do it yourself. These cook tops are not glued to the granite at all (Or is not supposed to be). Simply lift is up slowly, start from the side, and lift it slowly. If done carefully you won't damage anything.
Hope this helps
JEDEMEYER1
* If this solution helped you, please rate it.
Aug 09, 2011 | GE 30 in. Profile JP350 Electric Cooktop
Why is ON light glowing with knobs on off GE PROFILE COOKTOP
That is to tell you that your Infinity Switches are faulty and no good.
So whatever one is lit, change it
Jul 26, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Knob is turned off but burner light is still on and burner area warm
If this is a glass top cooktop then yes the bunner light will still be on when you turn it off. Also the bunner area will be still be hot. The reason why the light is still on it is telling you that the bunner surfas is still over 95 degrees. Once the bunner area is under the 95 degrees the light will go off. It is a safty warning for people saying that the surface is still hot.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 07, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Large section of dual burner not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Jul 07, 2009 | GE 30 in. Profile JP989 Electric Cooktop
Electric Glass GE Profile Cooktop Burner popping
yes the knob is attached to a switch and the switch to the burner by way of wires..you can get into the cook top.but with your description of whats going on i would have the switch with me and then may only have too take apart once.there is a chance your burner is bad,but as you describe the way the switch is acting is seems pretty sure just the switch.you can order switch on line you need your model and ser#
Jan 30, 2009 | GE Profile JGP636 Gas Cooktop
Glass top
Jul 10, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Ge profile ceramic electric cooktop
Oct 26, 2007 | GE Profile JGP636 Gas Cooktop
GE 30 in. Profile JP989 Electric Cooktop Logo
295 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
