Question about Zebra 105Se Thermal Printer
I need the configuration chart for a Zebra 105Se, dipswitches???
How do I set the dipswitches so that the printer prints in direct thermal, peel off mode.
  • 685 Answers
Http://www.thermalimages.com/pages/prd_zebra_printer_ribbons.html try this site
Posted on Nov 11, 2008
My zebra 105se printer got move to a different location and now it is printing very slow. Is there a way to set the speed faster?
Our company is an authorized reseller for Zebra printers, as well as labels & ribbon. You can adjust the speed and heat settings on your zebra printer, however your labels software will often override any settings. What software are you currently you using? If you can let me know, i will tell you how to change settings in your software- which will override the print to print faster.
Conti Systems
Bethany Miller
972 870 9400x105
www.contisystems.com
bethany@contisystems.com
Feb 15, 2011 | Zebra 105Se Thermal Printer
I am using a Zebra 105SE printer. When I print labels, I can not get the text to start at the top of the label. No matter what I do, the text starts half way down the label.
Label position may be off. Power on while pressing the cancel key for 10 seconds. This should print a configuration label. Use large label for this. Check the parameters, specifically top position and tear off position. The default is 0. You might also check the main drive belt for stretch or missing teeth. You need a user manual for that printer because there is no lcd panel. It is not user friendly without manual.
Nov 11, 2010 | Zebra 105Se Thermal Printer
Have a Zebra 105SE that prints the FEED test just fine, but will not print the PAUSE test nor will it print a bar code label from the computer. The FEED test prints vertical bar codes while the PAUSE test...
Check to see if the pause light is on also. Make sure you are using the correct printer driver. (105se)
Try in ZPL and then try in ZPLII.
Check Delimiter character 2CH
Check Format prefix 5EH
Check Control prefix 7EH
Aug 24, 2010 | Zebra 105Se Thermal Printer
Label peeling
Sometimes the peel bar gets worn out and isn't very sharp anymore (replace). This will affect the peeling. Also try increasing the printhead pressure with the printhead toggle.
Jun 03, 2009 | Zebra 105Se Thermal Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
Zebra 105SE label material will not retract in prep for next Lab
The platen is the driving force for the label. the main drive belt runs all functions in the printer.
Is the back feed turn on in the printer? Check the setup.
Also if the print driver is set(doc/properties settings on print depending on software) to use pirnter settings, and the back feed is turned off in the printer, it will not backfeed.
Feb 24, 2009 | Zebra 105Se Thermal Printer
Zebra 105SE configuration settings
Please scroll the printer parameter untill you fine LEFT POSITION parameter and adjust as you needed.
Nov 03, 2008 | Zebra 105Se Thermal Printer
No response from 105Se
if the data light comes on and nothing prints chances are that the serial settings are set improperly. all of my printers are 25 pin serial, not parallel. i don't have one in front of me but i believe the settings are 19200, 8, 1, none. hope this helps.
Mar 19, 2008 | Zebra 105Se Thermal Printer
Zebra 105 SE Printing Blank Labels
You need the correct driver for the 105Se. The 300 dpi SL driver is not compatible.
Unfortunately, Zebra does not make it's older drivers available online. You will need to locacte someone with the correct driver for whichever version of Windows you are using.
Steve
Feb 13, 2008 | Zebra 105Se Thermal Printer
ZEBRA 105S
http://www.scansmart.com/warehouse/images/zebra/105seug.pdf
Jun 14, 2007 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
280 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
