Question about RCA Lyra M2030 MP3 Player
Won't play music!!!
I press the on button...RCA comes up...please wait comes up and it takes like 5 minutes to go to my songs!!!
5 Suggested Answers
  • 13 Answers
SOURCE: rca junk
When RCA first came out with the Lyra series the only way to get music onto the device was by using musicmatch jukebox that would convert your mp3 file to mpy before downloading it to the device. But now RCA has come out with a new firm ware update for these mp3 players that improved the players playback quality plus enabled it to use .WMA files. so first go to RCA support http://support.rcaaudiovideo.com/select.aspx?u=downloads and find your player and download the firmware upgrade and install to your player its very easy and instructions are at the same site. You can now convert your music to .wma or use the free Real player that will convert mp3 to wma at the kbps that you request before loading it on. If your music is all ready in wma format you can use windows media player to send the files to your player. One last thing the .wma files that you put on your Lyra player need to be at least 128kbps or higher enhanced playback quality of wma files (160 kbps to 256 kbps).
Posted on Feb 04, 2008
  • 10 Answers
SOURCE: rca pearl does not play all songs loaded on it
there may be a problem with formet use converter and place correct formet in it...........
Posted on Feb 26, 2008
GSAN
  • 106 Answers
SOURCE: mp3 player plays back songs too fast
First step is trying to do a firmware upgrade from RCA.COM. Go to the support page and look for your Lyra by model. Let us know if this corrects the problem.
Posted on Jun 27, 2008
SOURCE: RCA mp3 player music speed malfunction
mine just started doing that today as well!!!!
is there a way to fix it or do i have to buy a new one?
Posted on Jul 19, 2008
WiredExtreme
  • 281 Answers
SOURCE: My Ipod classic 80G has stopped playing music.
Make sure that you got all of your songs off of itunes, or that they have been converted through itunes correctly. This is caused by songs being the wrong format, or that the song itself is corrupted. Try restoring the unit through itunes, and loading the songs back on. If you are running with your unit while trying to listen music this can also cause the unit to freeze up when playing a song. Any type of continuous motion can cause your ipod to not play songs. This is because the ipod has a hard drive inside of it, and when you move alot with a hard drive it cant read correctly. If you want to run with your unit, i would suggest getting a flash drive based mp3 player (ie itouch). If you have any further questions feel free to contact www.wiredextreme.com.
Posted on Nov 15, 2009
I had jxd in it songs are not playing i copied songs in jxd in audio file songs r appearing in jxd but not playing i pressed play button "file type error" coming why
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Aug 23, 2012 | Acer Audio Players & Recorders
Hii, I have sony mp3 player, model NWZS616F. It will transfer the songs from the Computer, but when I unplug it to use it, the songs are simply not there. Can you please help me on the same ASAP.
If you're getting a "Library Error" type message, you can try the following fix, but it will DELETE all music files currently on your player....
(1) Go to the main control screen (press BACK button for about 2 seconds)
(2) Select the SETTINGS icon (looks like a briefcase)
(3) Press PLAY button
(4) Select COMMON SETTINGS
(5) Scroll all the way to bottom and select FORMAT
(6) The player will ask if you want to delete all data. Select YES each time to delete all songs (takes about 1 minute to complete)
(7) Reload ONE tune only and see if the player will now play it
(8) Reload all your other tunes
(9) Finished ! :-)
Jan 22, 2011 | Sony Walkman NWZ-S616F MP3 Player
I erased all the songs from this mp3 play to put new ones on after erasing the songs the play won't be picked up by pc and am unable to put new songs onto mp3 plaey the players just displays please wait...
yes...unplug from pc shut mp3 off for a minute...plug it to pc (did it come on turn it on)...please get into the habit of disconnecting any usb connection with the safety disconnect...(green icon in task bar when usb is connected)...since you already deleted all files (format it now) start fresh...now you are able to put your songs on it...but to disconnect do not....do not just unplug the usb
Jun 20, 2010 | RCA M2000 MP3 Player
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
May 02, 2010 | Element Electronics GC823 MP3 Player
How to put songs in this gogear mp3 player?
Open Windows Media Player. Hit the "Rip" tab at the top and put in the CD(s) you want to record. You can put in as many as you have hard disk space for. Each one takes 3-5 minutes to "Rip". When you are through, you will need to plug in your player via the included usb cable. Let the computer "find" it. Then, you will go back to Media Player and hit the "Sync" tab at the top. When it comes up you will see a list of the all music you recorded. You can drag and drop music from the center column to the right column under where your device is listed. If you drag whole albums, whole albums will be transferred. Once you are done, hit the "sync" button at the bottom right and wait for the fireworks to end. The "syncing" process goes very quickly. Now play music!
Mar 11, 2009 | Philips GOGEAR SA6045 MP3 Player
The pictures on my sansa mp3 8gb
I didn't realize the sansa clip supported pictures - are sure you posted in the right section?
Just giving you a hard time. If you have a Sansa Fuze 8GB:
Looping a Slideshow
1. Press Submenu button while viewing photos.
2. Scroll to Loop and select it.
3. Use the thumbwheel to select Loop on or off.
4. Press the Select button.
5. Press the |<< button to return to previous menu.
Specifying the Slide Duration
1. Press Submenu button while view photos.
2. Scroll to Slide Time and select it.
3. Use the thumbwheel to highlight and select the desired duration (from 2
seconds to 30 seconds).
4. Press the Center button.
5. Press the |<< button to return to the previous menu.
Selecting Slideshow Music
2. Use the thumbwheel to highlight Slideshow Music and select it.
3. Select Current Song (if a song is currently playing) or Music Go List
(plays music from the Go List) then press the Center button.
4. Press the |<< button to return to previous menu.
-Tha Mp3 Doctor
Jan 06, 2009 | SanDisk Sansa Clip MP3 Player
Stopped playing music
Since you have a MAC, your probably using ITUNES, ITUNES are MP4 format which this unit doesnt play, you have to make sure what your putting on is MP3 audio files:
Here is a guide on how to convert songs to MP3 on ITUNES:
http://www.wellesley.edu/Computing/Idocs/Itunes/convertMP3.html
Once you get the audio files converted, drag and drop on the drive from where they are saved on your computer.
To play the audio files:
hold the play button until red light comes on, then press Play again, light should blink which means its playing.
Jul 31, 2008 | Coby MP-C883 MP3 Player
Deleting Songs
well what i did was turn it on.in the main menu..go to the box that says MSC (music)..press mode..it should say please wait.then you should either have a screen with different icons..if not then the screen where the song is playin pops up..if that is what happens press the stop button, then the mode button taking u to that screen with all the different icons..Press the >> button until u get over to the delete all folder..press mode..in the top right of the screen it should say no...if it does press >> once to go to yes..then press mode..and if its already yes then press mode..then after that it should say empty card when you try to go play songs.
Mar 15, 2008 | GPX MW6815DT MP3 Player
RCA M202A
I found the best way to delete your mp3; go to start..find you device in "my computor" it will be a generic drive. right click and go to "format" click and it will prompt you to delete "playlist".."audio" or "music". However it will erase everything on your mp3 and allow new downloads. if you want to save some files; Plug mp3 in usb port..you will get prompt to define which system to play files. I use realplayer. scroll down until you can select "rca (G)" click "view" your mp3 will load and display all songs..you can then select and delete any or all, right click and choose option. To load; choose burn/transfer scrool down on the leftside to rca (G) and you can choose from you music menu ( I suggest making a playlist first to indentfy what songs you prefer, you can always add more from all music menu. add any files that you like until full. depending on song generally about 50 to 65 son on the 512 model. Do not worry about too many songs.. NO harm....they just won't fit.... I hope this help anyone with this problem
Nov 20, 2007 | RCA M2000 MP3 Player
HELP! plz!
It sounds like your Friend,Try to load something to your Player,Take the model 3 and make and Put it in the Browser and look for the Proper Software For it you might lose the music you have on it,But at least,It will Work
Jul 19, 2007 | RCA Lyra RD2217 MP3 Player
RCA Lyra M2030 MP3 Player Logo
35 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
