I thought it was the AV component cable because the video went out in thge m,iddle of playing a game. I'm still getting sound and it is responding to the 360 controller. I've tried replacing the AV cable, but I still get the same result( no picture ). PLease help me if you can, or recomend some advice about fixing vs. replacing cost-wise.
Thank you for your help. ---tyrehater---
Hello tyrehater,
You mentioned the sound still works and you have changed the cable, right?
Do you have another TV at home? Maybe the input panel on the TV is the one damaged.
If you have another TV at home, can you try your Xbox360 on the other TV and let me know what happend?
Good luck,
Dahaka
Initially, might not be a video cable or 360 problem. have you considered the probability that it is a TV problem? Could you pls try the TV using regular cable or with another audio/video source such as a DVD player?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
This problem has already been discussed in fixya
Click this link to get more information
http://www.fixya.com/support/t647901-no_picture_or_sound_tv
Try unplugging the pds for ten minutes.
If this does not work, hold the start button while you plug pack the power cable.
