Question about Lexmark X2330 Printer
How do I install an ink cartridge in a lexmark x2330?
I lost the instruction book on how to install the ink cartridge into my Lexmark All In One x 2330. So I need some instructions on how to install the number one cartridge.
  • 685 Answers
If you go to there site it will tell you how to do it
Posted on Nov 10, 2008
How do I change the ink cartridge in a Lexmark x2330
  • Turn the Lexmark printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
  • 2
    Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps.
  • 3
    Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
  • 4
    Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
  • 5
    Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you've completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
  • 6
    Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
  • Jan 17, 2011 | Lexmark X2330 Printer
    How do i install my printer Lexmark x2330 without a CD
    Here's the link to the Lexmark X2330 printer drivers http://bit.ly/bNUsD2. Choose the correct driver compatible with your computer's operating system. If you are using Windows 7, use the Vista drivers.
    NOTE: Lexmark X2330 is not compatible with Macintosh operating system.
    Sep 12, 2010 | Lexmark X2330 Printer
    Lost my manual, need to change the ink cartridge, help
    1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
    2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
    3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
    4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
    5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
    Apr 24, 2010 | Lexmark C533DN InkJet Printer
    I HAVE A \LEXMARK X2330 INSTALLED ON AN xp PC. I
    I am assuming that the Win7 can "see" the Lexmark on the XP machine but not print.
    OK, on the Win7 laptop in question:
    Click Control Panel > Printers > Add Local Printer
    Create New Port = Local Port
    Port name is \\yourXPcomputername\Printername
    Now Win7 will install a print driver to work with the shared Lexmark printer.
    Jan 02, 2010 | Lexmark X2330 Printer
    I have lost the start up disc for my lexmark x2330 printer and want to install it to my new computer
    Go to lexmark.com support look up your printer x2330 check software downloads and should be the same as the cd to install.
    Nov 30, 2009 | Lexmark X2330 Printer
    Lexmark z2300 eplacing ink cartridges
    Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
    May 21, 2009 | Lexmark Z2300 InkJet Printer
    Installing ink cartridge in Lexmark X125
    The front panel is hinged at the bottom so grab the top and pull towards you.  Under that is a protective cover, the one with the 2 paper guides.  towards the bottom of that there is a hole in the middle.  Put your thumb in it and lift the cover up.  Your carrier for the cartridge is under that.  Please Rate!
    http://www.lexmark.com/publications/eng/x125/index.html
    That link will give you the manual..just in case you need it.
    Mar 11, 2009 | Lexmark X125 All-In-One InkJet Printer
    Lost disk to install
    Lexmark does not distribute replacement install disk for all models.
    Contact Lexmark here, to see if the disk for your printer is available.
    If you do not have the disk you must download the software from Internet, follow instructions below,
    Click here:Official Lexmark Drivers and Software
    A web page will open, follow instructions, select model, select operative system etc., and click on download .
    Chose to download the file in my documents when asked.
    Afterdownloading, find thefile,double click on the file, then if you get introubles, follow the instructions below to reset and reinstall drivers:
    • Unplug printer USB.
    • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
    • Download driver from website and run the file.
    • Follow driver installation wizard.
    • Plug back printer when prompted from installation wizard.
    Note:some printer does not work on Vista
    Oct 15, 2008 | Lexmark X2330 Printer
    I lost installation disk and need to install
    please follow the link below to download the driver for your printer directly from Lexmark.
    For Lexmark http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
    use the product selector to select your exact model and operating system.
    Sep 28, 2008 | Lexmark X2330 Printer
    No disc
    After downloading, find thefile,double click on the file, then if you get in troubles, follow the instructions below to reset and reinstall drivers:
    Dec 08, 2007 | Lexmark X2330 Printer
    Lexmark X2330 Printer Logo
    213 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
