Question about GE JBP71 Electric Kitchen Range
Oven temp oven ge will not go over 300 degrees
Electtonic control needed to be replaced
Posted on Nov 13, 2008
I recently ran the self-clean option on my GE Profile JK955B0F5BB. Now when I set the touch pad to 350 degrees or more, the oven heats up to beyond 500.
That is not a valid model number, the issue is most likely the thermostat has failed. The part is about 12 dollars.
Jan 07, 2017 | GE Ovens
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
Oven tempature is 10 to 15 degrees lower than set temp.Can this be adjusted? This is a electric oven. GE Profile Model VZ295971J.
all ovens very sometimes 10-25 degrees +/- depending on the brand..nothing you can, do set the temp a little higher if you know its off.
Jan 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Older ge spacemaker range, temps wont boil water on stovetop, oven takes hours to hit 300 degrees could it be wiring or thermostat? says pn PLT135-3 owners manual [dont have] PLT059-2 model number...
Check your breakers to the oven. It sounds like one of the two of them have tripped and you are only getting 120 VAC.
Do you have a volt-ohm meter, and know how to use it?
Dec 18, 2009 | GE Spacemaker JMP28 Electric Kitchen Range
You can re-calibrate the oven as follows;
press BAKE pad.
select temp of 500 degress or more.
immediately PRESS and HOLD the BAKE pad until "00" appears.
Then press the + or _ pad to adjust temp up or down 5 degrees at a time.
When fimished press the Clear/Off pad.
Mar 15, 2009 | GE JTP15 Electric Single Oven
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Preheat takes forever
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
Mar 01, 2009 | GE Ovens
Open Questions:
GE JBP71 Electric Kitchen Range Logo
97 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
