Question about GE XL1800 1100 Watts Microwave Oven
Can't clean the inside of the glass door--the screen blocks it
The inside of the door gets dirty and I can't clean it because the screen is in the way and I don't know how to get it off. Do you know how to do it?
Have to replace the door. You probably removed the protective plastic cover inside the unit intended to keep material from passing through the screen into the area where the glass is located. That was my problem. I thought the plastic was shipping material. My Bad! No way to clean the glass from the inside because they "never imagined" someone would remove the plastic cover.
Posted on Jan 07, 2009
Clean the oven door
You can put a bowl of water in the oven, with a few drops of lemon juice in it, Microwave 2 mins, then see if the glass will wipe clean.
Feb 15, 2015 | Magic Chef Microwave Ovens
Our oven door has become dirty from juices spilled and has got in bewtween the glass on the door. Can this be taken apart and cleaned out????
Depending on the make and model of microwave it should be cleanable.
If you have countersunk screws along the outer of the door edge, unscrew the screws and then the plastic from should pry off allowing access to clean the inside portion or let you remove even more screws allowing access to the inside.
Some have a plastic bead on the inside of the door that covers up the screws. That is held on by long plastic clips, covering the screws that hold the front on.
Hope that helps.
Dec 10, 2010 | Microwave Ovens
How do you clean inbetween the oven glass door?
To clean between you need to remove one of the pieces of glass...usually the inside is the best....
There are a few screws on the inside of the door theat hold the frame, which holds the inside glass...
remove the frame and carefully remove the inside glass... clean the inside of the outside glass, then clean the inside of the inside glass and then reinstall the froame over the inside glass...
Now you have a clean ove glass again...
heatman101
Nov 16, 2010 | Microwave Ovens
Can't clean microwave oven door
you can change this part easily... if you want a fresh look, or using a degreaser that is available in home depot...
cheers
Nov 24, 2008 | Microwave Ovens
Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Oct 01, 2008 | Maytag MMV1153A Microwave Oven
GLASS ON THE DOOR
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 30, 2008 | Whirlpool MH1150XM Convection/Microwave...
Microwave door has burn spots on the glass of the door...
i have the same problem, there is a brown spot about 3 inch
by 2 inch at the bottom of the glass, I cannot clean it, it looks
like its in between the glass.
May 01, 2008 | Whirlpool MH6150XMS Microwave Oven
Dirty Door Glass inside the choke - how do I clean it?
Its very hard to take apart the doors They normally have a lot of screws. May have a plastic snap on cover that's covering them up. Some of them are even sealed and can not be taken apart.
Anytime you work on a door you must check it with a microwave leakage meter. The door has metal gaskets and a screen that blocks the microwaves upsetting them will cause it to leak.
This is not a do it yourself repair.
Dec 24, 2007 | GE JVM1870 Microwave Oven
The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
Jun 25, 2007 | Goldstar MV-1501 Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
360 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
