Question about Lexmark Office Equipment & Supplies
I lost my printer when I did a systems shut down
  • Lexmark Master
  • 19,396 Answers
Unplug printer usb and reinstall software from printer disk, if you have lost the disk, then see the instructions on following link: How to install a Lexmark printer when the... -
Posted on Nov 10, 2008
When shutting down my Acer PC(Windows 7) my wireless connection to my printer is lost. Any suggestions?
What are you trying to do with your pc shut down?
You may have installed the printer as a network printer from your PC and not from the router.
If the router is not acting as a print server, then you will loose the connection from the printer when you shut your pc down
Oct 17, 2010 | Belkin Computers & Internet
Ink system failure & keeps shutting down & coming on its own.
Do the following, let me know if it clears or not:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printer disappears !
hi there are 2 types of wireless installation 1 is infrastructure and the other one is Adhoc in Infrastructure the computer and the printer are connected through a router this is a permanent sort of connection and remains even if the computer is shut down
but the Adhoc connection is a short duration connection in which the computer and the printer are directly connected and the connection is lost as soon as the printer or the computer is turned off
so its always recommended to connect teh printer using the infrastructure mode so that you do not face any problem
Apr 16, 2009 | HP Photosmart 3210 Printer
Lost connection between printer and cokmputer
you can go onto the makers web side and pick drivers and software , the put in your mobile number and then pick what system you want,, then download it ,, before you install it remove to old one first then shut down and restart pc then install new software ,, this should sort out your problem
Apr 06, 2009 | HP Officejet J5780 All-In-One InkJet...
Problem communicating with the Printer
i lost the software set up program for the lexmarkx1270 pprinter. can i download it to this computer .
Feb 16, 2009 | Lexmark X1270 All-In-One InkJet Printer
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Jan 25, 2009 | Canon imageRUNNER C2058 Led Printer
I have a Lexmark T632 that is used very often. Constantly printing over 1000 pages daily and I always get the error message Print head Error 934 - Lost Lock condition but once I shut down the printer and...
These error codes indicate a problem with the mirror motor circuit in
the printhead assembly or the mirror motor cable to the system board
cable or system board assembly. Check the continuity of the mirror
motor cable connected to J5 on the system board. If incorrect,
replace the cable. The voltage at J5-7 measures approximately
+24 V dc. If incorrect, replace the system board. If correct, replace
the FRUs in the following order:
• System board
• Printhead assembly
Dec 10, 2008 | Lexmark T632 Laser Printer
Cannot connect to printer/scanner, blinking orange light and have lost wireless connection. Have already done all that was prompted (ie restart computer, shut down and unplug, moved the atena, refreshed...
Let me know the Operating system running on your PC.
Also check if the USB connector setting do something to run printers.
Regards,
Ellin Scott
Oct 18, 2008 | Lexmark Office Equipment & Supplies
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
