Question about X-Micro Technology XWL-11gCAG 802.11g/b (xwl11gcag) Wireless Adapter
XP-SP2 hangs on boot after installation
CPU Intel Core2Duo E6300; M.Board Foxconn P9657AA; OS XP-SP2 I installed the X-Micro driver (from web) for the XWL-11GCAG to a clean XP-SP2 installation, and turned PC off, inserted PCI card and rebooted. XP seizes up during boot and hangs. If I turn PC off and remove card, XP boots correctly. I previously had an AMD Sempron 2800 system which worked very well with the same XWL-11GCAG card. Does anyone know if the XWL-11GCAG and driver is compatible with the E6300 Core2Duo? Many thanks in advance
  • 2 more comments
  • Stephen Hallett Nov 05, 2006
    Many thanks sandrew - good advice. Unfortunately the PC still locks on bootup. Installing card and booting ran 'Add hardware' which found drivers and installed. It is then on rebooting I get hang. There is a motherboard ethernet controller and even uninstalling drivers for that makes no difference). Incidentally, the X-Micro manual says clearly to install drivers THEN the card. So certainly a conflict somewhere - time to get a new card ;)
  • breidt Oct 05, 2008
    Same with Core2 Quad P6600 ...
    Solution does not seem to work (at least for me)
  • Anonymous Oct 19, 2008
    here too.
  • Anonymous Feb 05, 2009
    same for me e8400 ep43-s3l
    President:
  • 2,961 Answers
I think maybe better uninstalling driver, but leave card in and boot system and let windows find the card(hardware) first instead of wot sounds like windows looking for driver and freezing in the boot up process as it will look for a connection to internet for an update or driver. Normally any usb periferals should be connected after driver installation, but any pci or agp cards inserted first, then driver.
Posted on Nov 05, 2006
  • andrew pester
    andrew pester Nov 05, 2006
    Maybe you would be better using a usb wireless device, incase it is a board problem.
    Good luck
Does dual core processor support Foxconn P9657AA-8EKRS2H mother board
The Foxconn P9657AA-8EKRS2H motherboard has a LGA 775 Socket. It will support Intel Core 2 Quad, Core 2 Extreme, and Core 2 Duo processors with an FSB of 1066 (800MHz). Thus is should support the dual core 775 processors. (Some Pentium 4, Pentium D and Celeron D CPUs may also be compatible with the board.)
I hope this helps.
May 06, 2012 | Foxconn P9657AA-8EKRS2H (6938279104065)...
Repeated failure to load Windows 7 HP
Hi.
Foxconn don't have this board on their list of their Windows 7 supported chipsets (which is hardly surprising), but as you state all your individual components should be perfectly OK with Windows 7 .
I suggest you flash the Bios because Foxconn had to produce a new Bios for Vista in order for that OS to run correctly.
Best of luck.
Jan 31, 2010 | Foxconn P9657AA-8EKRS2H (6938279104065)...
Virus massage comes and when i click ok my pc hangs
Try booting up in Safe Mode - press F8 function as the computer boots up, then use a WEB based virus removal to clean out the virus.
Use these links :-
WEB-based Virus Scan
Trend Micro HouseCall
http://housecall.trendmicro.com
Symantec - Norton Security Scan
http://security.symantec.com
Dec 26, 2009 | Intel Core 2 Duo E6300 / 1.86 GHz...
Cant detect my flash drive
Have you tried installing the driver for it on your computer?
May 13, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
D-Link Airplus DWL-G520 problem with windows server 2003
D-Link Airplus DWL-G520 on PCI drivers do NOT support Server 2003. It will only support these OS
Windows 98/Me/2000/XP
If you boot your XP is it still working ?
Mar 15, 2009 | Intel D101GGC Motherboard
Windows XP Pro hangs on reboot after installation
Try removing your AGP card and enabling the onboard graphics again. It is possible your Radeon is a 3.3v, but this board only supports 1.5v cards. Take a look at the manual at ftp://download.intel.com/support/motherboards/desktop/D845GERG2/BV2RG2_English.pdf
Dec 29, 2008 | Intel 845GE Motherboard
Windows Xp sp 2 installation problem
check the cpu fan or remove it then put it again
Nov 08, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
Pci device driver issu intel d945gcnl desktop board
plz try by reloading the sound driver from *********** board cd,plz post your findings
Jun 13, 2008 | Computers & Internet
Please help me in my RAM
If your PC boots up successfully and load windows then its mean that RAM is working fine... There is some problem with OS settings.. So at XP booting press F8 for start-up menu and select Last known good configuration... Hope it will work...
Please Rate .... Thanks.
May 14, 2008 | Intel Motherboard
X-Micro Technology XWL-11gCAG 802.11g/b (xwl11gcag) Wireless Adapter Logo
379 people viewed this question
Top X-Micro Technology Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a X-Micro Technology Computer and Internet Expert? Answer questions, earn points and help others
