Question about Carrier Heating & Cooling
Rebuild gas value - Carrier Heating & Cooling
  • 182 Answers
No ,it's so unsafe that they dont even make the kit.
Posted on Nov 11, 2008
87 Firebird 350 motor heat problem?
THE TEMPERARTURE NEEDLE IS NOT SUPPOSED TO GO THAT HIGH, HAVE THE COOLING THOROUGHLY CHECKED ....FAILURE TO DO SO COULD END IN AN EXPENSIVE TOP END REBUILD OR COSTLY REPAIRS.
iT SOUNDS, AT FACE VALUE , LIKE AN OVERHEATING ISSUE....THIS CAN BE SERIOUS
Aug 16, 2015 | Cars & Trucks
It was cranking on 1st or second pull, ran out gas half way thru yard, put in gas, it cranked and ran 10 ft& cutoff. now it will try to fire but wont crank and stay cranked??
Many issues possible. I would try a gas stabilizer. This can clean out the carb. There is a needle value which can get clogged and thus cause the lack of gas. This happen when the gas runs out and the minerals on the bottom of the gas tank get in the carb. flushing the carb or rebuilding is obviously the next option.
Aug 15, 2014 | Garden
Engine is old
My personal preferrence would be to swap or get another car. This particular car in my opinion doesn't hold the value of cost to rebuild the engine. Just my opinion.
Nov 12, 2013 | 1999 Saturn SL
How to rebuild a 17hp briggs & strattion motor
Get the date code and model off the rewind cover, Jacks small engines sells kits complete along with others. If you are a hobbyist go for it but in the long run is it a greater value to purchase a short block instead.
Sep 23, 2012 | Garden
I have a 2002 YZ250F that probably needs a new top end? What is an approximate cost on repairs?
Hi mate if you can rebuild your self then parts would be about $200 for piston kit and about $80 for the gasket kit and to be extra nice to the bike then about $10 new oil and same again for new oil filter so parts only well under $400 with some change
you may want to consider new cam chain whilst you have it all apart unless it has been changed as over 8 years old would mean it is well an truely used to its potential if you include the cam chain then you won't get any change from $400 but this figure would be pretty close give or take $50
As for paying someone to rebuild it for you well sorry to say you well on the way to $900 in the shop for labour and parts but if you need this option shop around to find best value
My Moto X parts online store can help you with best value for the parts delivered to your door this could save you few dollars if you rebuild yourself or supply your own parts to the mechanic to rebuild?
May 20, 2011 | 2003 Yamaha YZ 250 F
Beta Trials bike 250 cc replace crank and con rod bearings instructions, with torque values for all bolting?
Hi Kieranrobbins, I am sorry you can't find the first and best tool you ever bought for your Beta but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
HOW TO REBUILD Bike Engine 250cc
YZ250 Two Stroke Rebuild
Motorcycle Bottom End Rebuild Part 1 of 3 Engine Teardown
http://www.lewisportusa.com/manuals.htm
http://www.betamotor.com/en/suhttp://www.lewisportusa.com/manuals.htmpport/manuals
Oct 14, 2010 | Beta RR 250 Motorcycles
I have a Coleman Powermate PRO-GEN 5000 (6250). It has been sitting for a year and the gas value was not shut off (oversite). When checking the oil, it smells like there is gas in the oil-is this possible?
when the engine sets for a long time the gas can seep bast in to the cylinder and their will be some gas you will need to change the oil and take the spark plug out and air i suggest you squirt a small amount of oil in the cylinder gas in the cylinder can wash out the lube to the rings and cause undo wear and start smoking turn the engine by hand slowly to allow lubing of the rings the gas seepage is most likely caused by a float that's not set correctly you may need to rebuild the carb with a kit around 20 bucks ans easy to do at least the clean it well to remove schlack that gas leaves behind when it dissipates and can cause issues.
replace with fresh gas and run the engine and it will smoke for a couple mins do to the oil in the cylinder remove the spark pug after running a couple mins and clean or replace the engine should be fine following the steps above. hope this helps
Aug 03, 2010 | Coleman Powermate Premium Plus 6250W...
What is error c=44
QuickBooks attempts to change a damaged transaction or record, you may receive a fatal or unexpected error that contains the value C=44. The C= value in the message indicates the type of error the program has encountered. Typical causes include system lockups and power failures while using QuickBooks. To resolve this issue:
  1. In QuickBooks, select the Window menu and select Close All.
  2. Select the File menu and select Utilities >Verify Data.
  3. If the message "Your data has lost integrity" appears, or the error also occurs while running Verify, select the File menu and select Utilities > Rebuild Data.
  4. When the Rebuild utility has completed, run the Verify utility again to ensure that all problems have been corrected (see step 2).
  5. If the error persists after rebuilding, restore a recent backup that does not generate the error.
Jul 30, 2010 | Intuit QuickBooks Simple Start Edition...
Heating & Cooling Logo
18 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
