Question about RCA T13070WH 13 in. Combo
My screen Hi, the problem i'm having with my tv is that i hear the sounds but the screen either goes in and out or the screen stays blank and nothing shows up. I wanted to know why and what i should do to fix it because i've had it for a while with no problems it just started doing it all of a sudden. Thank you!
jomaru
  • 337 Answers
SOURCE: Blank Screen
The screen in your dvd might not be getting the volts it needs to work,the ribbon cable that comes from the base gets broken sometimes because of the hinge action of open and closing constanly.You need to call RCA at 877-794-7977 and ask for an estimate or an idea of how could cost to repair.Good luck.
Posted on Oct 17, 2006
  • 375 Answers
SOURCE: TV wont turn on and blank screen & no sound
this unit is dead ,possoble power supply problem. you must have warranty on this unit if its only 8 months old,if not contact place of purchase and ask wath is the life expectancy of their products and your tv set it start them thinking about repairing or replacing.
Posted on Aug 22, 2007
fwadley
  • 482 Answers
SOURCE: RCA Scenium 52 DLP
you should take it to a tv repair shop to look it over, they charge $50 and they will tell you want the problem is.
Posted on Dec 17, 2007
  • 905 Answers
SOURCE: 32in. rca lcd tv GOES BLACK
this is the conversion IC chip , it needs to be replaced
Posted on Oct 19, 2008
  • 346 Answers
SOURCE: tv screen goes blank with a line across middle
change the vertical output ic
Posted on Jan 05, 2009
TV SYMBOL COMES ON TV GOES BLACK NO SOUND OR ANYTHING HOW TO REPAIR THIS
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the ...the the tv turns on but there is no picture or sound and I can't seem to fix it the .... +tbones11234 I have the same on myHisense 55" TV,what did you ... The problem is when i turned it on it shows on the screen the sony logo three times then its ...
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Click Here to BUY TV REPAIR P... ... I Have a Hisense Tv in My Screen Is Not Working Right The brightness is ... Hi my TV shows the picture for a moment and then goes .... here the sounds but you cant see nothing and a sanyo flat screene.
Jan 16, 2016 | Hisense Televison & Video
The power light comes on but the screen stays blank there is no picture or sound
Hi Judy
How old is your unit?
Probably your unit has leaky capacitor or shorted driver transistor.
Jan 19, 2014 | Haier L32B1120 32 LCD TV
My hannspree tv screen goes black blank
If the picture shows a picture briefly upon power up then goes off after a few seconds, you have a back light fault. It could have a problem in the 24vdc circuit, failing back light inverter board, or a blown CCFL lamp.
Dec 05, 2012 | Televison & Video
Sanyo dp42848 turns on but blank screen
Replace the Main board if your not hearing any audio from the set.
Oct 27, 2012 | Sanyo DP42848 LCD TV
My tv turns on for about 30sec but will not stay on first it blanks out but you can still hear what is coming on then all 3light blink and the sound goes away then I have to turn it back on
The"LAMP"LED light indication stay lite or flashes on the tv front of the screen bazel panel?This is tv has not been replaced the projection lamp like 1 1/2 or 2 years,tv been on,an in used like 4 or 5 hours a day.The projection lamp life is over.
Oct 03, 2010 | Samsung HLN5065W 50" Rear Projection...
HI, I HAVE AN LG 42LB5D TV AND THE SCREEN GOES BLANK. tHE SOUND STAYS ON. THE INPUT BUTTON WORKS(YOU CAN HEAR IT CHANGE INPUTS) BUT THE SCREEN IB BLANK. IT WORKS SOMETIMES FOR A LITTLE BIT THEN GOES BLANK
Hi:
There are two capacitors on the power supply that needs changing, If you take off the back of the set the power supply is the large center board, look near the white connector the goes from the PS to the main board assembly, there are few Capacitors here the bad ones will look Puffy on the top of them. Replace them with the same values but higher voltage the norm values are 1000uf rated at 10 volts replace them with 1000uf rated at 16 volts, (Note the capacitors are polarized Neg and Pos this should be printed on the board if after you take one out, note the bold band on the board and on the Capacitor this is where the neg side of the cap goes other is the Posistive side. Replace them the same way they were installed this is important for your safety and the televisions proper operation.
Dec 16, 2009 | LG 42LB5D 42 in. LCD Television
My xbox 360 wont show a picture but it has sound
it might bea problem with your actual video cord that plugs into the tv.... umm my xbox has a lot of issues too but ive never had this. id suggest you let it say off for a while and try somebody elses cords that connect the xbox to the tv to see if its an issue with your xbox or if its with your cords. ill also suggest you call microsoft and they can troubleshoot...
please rate my solution :) thanks
May 31, 2009 | Microsoft Xbox 360 Console
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
RCA T13070WH 13 in. Combo Logo
26 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
